LG 50PA650T - possibly bad ribbon... (PDP50R4 panel)
    Hmm, I picked up this LG 50PA650T full HD 1080p 50" plasma. £50 bargain, so from never touching a single modern design LG plasma in a week, I've got two!
    Turning on, got Vs/Va, but -Vy and Vsc all over the place, no image on panel. Uses a PDP50R4 panel, which is a fairly significant change from PDP50R3 (the panel Vsc/-Vy is offset by some third, unknown voltage, which is very odd; will have to investigate this later. Had thought practically all R&D had stopped at LG PDP.)
    Remove top buffer, got picture on bottom half... good Vsc/-Vy too. Image is a little fuzzy but this is probably due to poor ERC (half panel connected = half capacitance so panel not properly sustained.)
    Top most buffer chip is shorted. Now I remember this thread from freakaftr8.
    https://www.badcaps.net/forum/showth...light=50pa5500
    He had a bad top buffer and a ribbon rubbing against the panel shorting the new buffer out.
    Here, I'm a little worried, because I can see a dimple in my top ribbon, not present in any other ribbons. However, I cannot find ANY shorts between Z-sus out and this ribbon or between this ribbon on chassis. Not even high ohm. All >66 Megohm on my meter.
    So, what could have happened?
    1. Maybe it's a random buffer board failure, this is a fairly new TV though, so it is a little unexpected. There are no heatsinks on the buffer ICs like in older LG panels.
    2. Maybe the ribbon is rubbing against the frame like in freak's case, but only when the panel warms up or if the TV is flexed slightly (side plastic is a little scratched and two screw mounts are damaged.) There are no cracks in the panel at all and bottom half will sustain image OK. AND, here's the important bit, when I check the buffer chip (top buffer IC) with my meter, the part which is shorted seems to correspond to this area of the panel. However, I don't believe that not addressing each line will blow a buffer as freak states. Case in point, unplug a ribbon, and it'll work for hours with it out. I did it accidentally for 10 minutes with this TV and no harm to the bottom board. So it must be a short that kills it.
    3. Maybe we have a panel failure like in PZ70 Panasonic though I can't see any blown pixels or shorts in ribbons apparently this only shows up after the panel gets warm.
    Potential fix:
    If it's (1) just replace the buffer and enjoy; (2) replace buffer and isolate the ribbon with some insulator - as Freak said it might be shorting? or (3) scrap the TV for parts - hopefully not as this is quite a nice TV!
    Re: LG 50PA650T - possibly bad ribbon... (PDP50R4 panel)
    Trying to get this buffer IC is proving difficult; want to preserve board!
    It's soldered to bottom of the board too. Tried hot air, with no luck. Will have to try some more, I guess. The thermal lug/pad is connected to the massive SUS OUT node. Half the board is connected to the same!
    • jorgesantis
      • Mar 2014
      • 1
      Hello, I have similar problem mate with exactly same TV. One day in the morning my wife said that there was not any picture on tv, just sound. I researched about it and many forums said that would be the buffers. I found reasonable prices in E-Bay selling both buffers. I change both but no fix. I bought a new Y-SUS and nothing neither. I found in YouTube how to test buffers and i found the top buffer was faulty (top IC as well was short-circuited). Because i had an spear top buffer, i replaced the IC and i got the picture on top as well, but with one thin black line which may be is because some of the pins was not soldered properly but i thought that i can survived with it. It was fine for a couple of days and BANG, the TV has not picture again.
      When i purchased the new buffers and the TV didnt work, i was wondering why the second Buffers has also the same IC faulty. Therefore, something is making to blow.
      Any help please would be so much appreciated. I cant afford repair and the FIFA world cup is coming over so would be bad no having my TV working for that.
      • wills123
        • Jan 2014
        • 72
        • england
        dont suppose you have access to an ir rework station tom66? would make removing the ic easy
        • Agent24
          I see dead caps
          • Oct 2007
          • 5096
          • New Zealand
          You may have to use a bottom heater to heat the board from the bottom side, and use a hot air nozzle that heats the entire chip at once
          Don't know what that epoxy\glue is but more than likely it's also gone under the chip as well. Hopefully heat softens it or you're going to have even more fun.
          -David VanHorn
            I have not been able to fix this. The damage to the panel appears to be fairly severe. I do not think it can be easily fixed. The ribbon would need to be transplanted from another panel. I believe freakaftr8 is having the same issue with a 50PA5500. I suspect the 50PA4500 (720p panel) may also be affected.
            It appears, essentially, the plastic posts around the edge of the Razor Thin panel break away, eating into the ribbons. There is no protection for the panel ribbons. This wasn't a problem on older TVs with thicker frames. Definitely appears to be a case of form over function. It's a real shame because it's actually quite well made inside, aside from this flaw.
            It's a serious design flaw with these. I posted on AVSForum and my post was pulled. I guess I upset the sponsors of that site there (LG do a lot of advertising on AVSForum.) Seems the newer models are still affected by this critical design flaw. Crazy. Don't buy razor thin LG plasmas. Bad panels are such a common issue with newer TVs. Foolish me thought plasmas were immune, at least somewhat.
            I don't yet have a board heater to pull off the buffer ICs, but I don't think it'd make any difference if the panel is bad.
            • freakaftr8
              • Oct 2012
              • 3743
              Yes this is absolutely verbatim by exact same issue. What a poor design flaw. The dimple you see in the ribbon actually cracked the connection in the ribbon. If the buffer is replaced you will see a few lines missing. These buffer ICs do not like this. They would either like to see all lines supplied or none at all. If otherwise, they short. Really odd.
              I attempted a ribbon repair to no avail. I ended up removing the cable from the panel, still looking for a donor.
              • diif
                • Feb 2014
                • 6978
                • England
                I got one yesterday. Top IC shorted, same dent. If you look at the space between the frame and ribbons there is a nice even space, apart from the top one that has a small lump sticking out right where the crease in the ribbon happens.
                • freakaftr8
                  • Oct 2012
                  • 3743
                  Yep that's how it happens. If you remove that top IC from the buffer board the rest of the screen will power up. Attempted repair mine with another ribbon cable and some of that 3m double-sided electronic safe but never went very far with it didn't seem to work.
                  What a crappy design completely destroys a perfectly good panel because of some stupid black plastic tab that doesn't need to be there
                  • ReeceyBurger123
                    Never Give Up !
                    • May 2014
                    • 7325
                    • Britain
                    Thats Lg for ya stupid pointless designs.
                    • diif
                      • Feb 2014
                      • 6978
                      • England
                      So the other end is bonded to the screen like LCDs, with nothing to solder to ?
                        I believe it's glued to the panel.
                        • freakaftr8
                          • Oct 2012
                          • 3743
                          Yes bonded to the panel and then glued on top of that. That part I might add is very solid.
                          Unfortunately their choice in a ribbon cable is very flimsy and thin unlike earlier plasma sets where the cables were very thick and hearty.
                          I believe this is partially led to the demise of the ribbon cable being cracked to begin with
                          • diif
                            • Feb 2014
                            • 6978
                            • England
                            Thanks, if you guys haven't been able to figure out a repair, looks like i shall part this one out.
                              Maybe take the ribbons off - there may be -some- way to reattach them to other panels.
                              • ReeceyBurger123
                                Never Give Up !
                                • May 2014
                                • 7325
                                • Britain
                                It is quite possible to reattach them ribbons. I have done so on a PS50C96HD where someone who I wont name was heavy handed and ripped the ribbon off. I was able to scrape back the mask and use very small solder braid to rebuild the connections. Not easy but possible, after I coated it with silicon to prevent shorts still working to this day. Wish I had images of it but never took any at the time it looked bodged but works and every row of the screen was working.
                                • ReeceyBurger123
                                  Never Give Up !
                                  • May 2014
                                  • 7325
                                  • Britain
                                  Tbh you might be able to do it it on this set depending on your solder skills ? It takes a long time and trust me alot of profanity will be said. What you think ?
                                  • freakaftr8
                                    • Oct 2012
                                    • 3743
                                    Interesting. You guys obviously have more patience than I lol
                                    • diif
                                      • Feb 2014
                                      • 6978
                                      • England
                                      If there is something to solder to then I'm up for giving it a go. Stupidly big thing is taking up half of my sofa.
                                      So remove the screen from the frame, remove the tab and resolder it, or leave the tab attached and just repair the broken connections ?
                                      • ReeceyBurger123
                                        Never Give Up !
                                        • May 2014
                                        • 7325
                                        • Britain
                                        It took a while to say the least and alot of effort. Wasn't too tricky to solder after removing the mask just tim the points then hold the sold braid on one side, tac it then the opposite side. Was hard though as I had to solder at least 8 copper traces which are tiny. I used a microscope and duck tape to hold everything in place.
                                        • howardc64
                                          by howardc64
                                          07-24-2025, 05:17 PM
                                        • NWArkGuy
                                          Samsung UN65TU8000 - Panel Issue [ hole in ribbon cable ]
                                          by NWArkGuy
                                          Well, I will be the first to admit that I screwed up...
                                          In attempting to replace the backlight in a UN65TU8000, I made a hole through one of the ribbon cables between the board that runs along the bottom of the back of the TV and the panel. This lead to a between a 1/4 to 1/2 inch vertical stripe running the full height of the image.
                                          I don't have the experience; personally, to solder a bridging wire for the paths that were cut. So, I have been on the hunt for other Samsung TV's of similar size.
                                          I have 2 that I have found and have in my possession. ...
                                          10-12-2023, 10:13 PM
                                        • howardc64
                                          Samsung QN75Q6FNA backlight no display, red LED blink 2x, fault in panel
                                          by howardc64
                                          • Prior owner tried a replacement main board. No difference.
                                          • Samsung 2x red blinking standby LED = panel fault
                                          • Jumpered FB_TRDY_1 (pin 1 CN1300 left. main tcon->left side buffer boards) and FB_TRDY_3 (pin 95 CN1301 right. main tcon->right side buffer boards) This allows testing individual T-Con (on main board) connection to panel on this Samsung. Found fault on left side (viewing from rear of TV)
                                          • Each side has 2 buffer boards, disconnected left side flex between 2 buffer boards. Fault is on the left most board.
                                          • Tape masking eventually isolated to CN1300 pin 15 (CKV4_GOA) Display
                                          07-19-2025, 10:54 PM
                                        • howardc64
                                          LG 49UJ6500 LCD panel lighter band that goes away
                                          by howardc64
                                          49UJ6500 LCD panel has a lighter band on top when first powered on. Goes away (or gets much fainter) after TV on for a few min. After powered off for awhile and power back on, same band appears. If powered on immediately after powering off, no or much fainter band. Running the latest firmware.
                                          Disassembled the TV and lifted the LCD panel during testing. Band is on the LCD panel (can see the band on the panel as I lift it slightly) Backlight is perfectly even at the top edge. Double checked LCD panel alignment in the frame and is perfect but since band moved with the panel, its on...
                                          02-19-2023, 12:13 AM
                                        • triplefour
                                          SAMSUNG UN50TU8000F rebooting, backlight ok. No 12v to panel boards.
                                          by triplefour
                                          TV flashes backlight then reboots over and over. no image. Client said it used to have image for a bit before rebooting. Got worse over time.
                                          tcon is built into mainboard.
                                          Only one cable goes to panel boards.
                                          there is a cable from one panel board to the other that links them.
                                          cost cutting measure that results in us having harder time to diagnose.
                                          removing the link to the second panel board allows TV to stay on with stable backlight but no image.
                                          used cut off tape method to mask 1 maybe 2 pins on the side of the cable that goes to that second panel board....
                                          07-28-2022, 07:59 PM
