I have this 27" FHD LED-LCD screen from an Acer LED-LCD TV to repair. My second LED TV. Let's hope it's not another bad panel
. Fault is the picture is jumpy, unstable, etc. with random (but non static) lines. Some slight (<0.5sec) image retention. No black bars or anything, just unstable picture. I don't see any shorts to ground on the VGL, either. About 20kohm one way, 40kohm the other.
I found some burn damage to the t-con on the part which generates VGL (-5V to -10V normally, I believe it to be approx -7.5V on this panel.) The t-con is permanently mounted to the panel, so can't be replaced unfortunately.
I traced out a part of the circuit, as best I could.
Anyone with a cracked screen panel like this who could read off voltages?
. Fault is the picture is jumpy, unstable, etc. with random (but non static) lines. Some slight (<0.5sec) image retention. No black bars or anything, just unstable picture. I don't see any shorts to ground on the VGL, either. About 20kohm one way, 40kohm the other.I found some burn damage to the t-con on the part which generates VGL (-5V to -10V normally, I believe it to be approx -7.5V on this panel.) The t-con is permanently mounted to the panel, so can't be replaced unfortunately.
