Samsung LCD TV LNT4061F X/XAC Vertical Lines
  • runormal
    • Nov 2013
    • 7
    I have read that this could be multiple problems. I came home from university and saw my TV like this.
    I've heard it may be the panel, but from what I've read and hope is that is the TCON Board. I've done a bunch of searches, but I just want to make sure before I dump any more money into it.
    What I've tried so far
    1. On and Off
    2. Updating the Firmware (Which was a pain when I couldn't see half the screen)
    I once let it sit for awhile just to see if it would fix it self, and then colours spread across the screen. Like vertical colours almost like a rainbow. I had a picture on my old phone, but I'm not sure if I lost the pictures. I will have to check when I get home.
    Cheers, Seems like a helpful community.
    Oh and If i't turns out that it is the panel, would it be worth disassembling it and then parting it out?
    Thanks again,
    Eric
  • Sevenqi
    • Jul 2011
    • 292
    Re: Samsung LCD TV LNT4061F X/XAC Vertical Lines
    The vertical bar indicates the tab bond IC burnt and is not fixable.
    • runormal
      • Nov 2013
      • 7
      That was not what I wanted to hear..
      Oh well, thanks.
      • mmartell
        • Oct 2013
        • 3189
        I had a similar problem but my bar defaulted to grey it was most definitely repairable. Tab bond - mine was getting too hot and blowing air across it alleviated the symptoms.
        Worth a shot I would say. I will try to find the thread by budm that I used as a guide.
        • mmartell
          • Oct 2013
          • 3189
          Here you go...
          https://www.badcaps.net/forum/showthread.php?t=25371
          • runormal
            • Nov 2013
            • 7
            Thanks man, I really appreciate it. I will order some of that and see how it goes ha.
            • Falki
              Colorful LCD Vertical Lines on Samsung ue55es8090
              by Falki
              Hello there, ive recently found an older 55inch Samsung SmartTV.
              Sadly it has vertical lines at the left and one line in the middle-right.
              I have already tested out the connections and have looked at the soldered ribbons of the LCD panel to see if some contacts got loose by pushing them a bit but with no success.
              I have factory resetted the TV as well but also with no luck.
              I am afraid that it is indeed a LCD Panel issue but there are NO scratches or any impact-marks..
              A similar issue has been posted as well but also with no actual response ...
              08-12-2025, 04:19 AM
            • Stanley1843
              Screen Display Vertical Multicolor Lines
              by Stanley1843
              Hello, I have a screen in where sometimes when I open it pop-up vertical multicolor lines (I would say the most of them are green). If I tun off and turn on the screen the lines dissapear or if I leave open the screen after approximately five minutes the lines gone. I measured the below voltages on the main PCB and on the T-CON board and the voltages are the same when it doesn’t display the vertical lines and when it displays the vertical lines. Also, I cleaned all the connectors very good with IPA. I moved back and forth the connectors and the COF tabs but the vertical lines didn't displayed...
              06-29-2024, 11:54 AM
            • pni
              LG 49uf695v vertical coloured lines
              by pni
              Hi guys…I need your help. My cousin ask me to fix her tv. The tv when I went to pick up showed 3 horizontal black line. So I know it was a bad panel issue but I could try to fix with the tape method so I said her I could fix easy. When I come back to home, I turned on the tv and now the tv show vertical line colored….and the problem is that I unplug the ldvs cable, first the right side then the left side I still have the lines. The lines never disappear. When the right side is plug in I don’t have nothing on the screen only this vertical lines, when the right side is unplugged I have picture...
              11-14-2025, 03:15 AM
            • x_orange90_x
              Samsung UN46C8000XFXZA vertical bars/horizontal lines
              by x_orange90_x
              I posted about this previously but didn't get any response, and I have some troubleshooted a bit so I have more info.
              The screen is full of horizontal "gaps" or lines that distort the picture badly, and after about 10 seconds of powering it on the screen starts to fill with red vertical bars that take on the horizontal pattern. After the screen filled with the red bars, they instantly vanished and then slowly started to reappear. I initially thought it was tab bonding failure, but after getting down to them and pressing each one I find zero change in the picture. I went...
              09-04-2023, 12:09 PM
            • polaro
              Thin stable coloured vertical lines on Samsung UN65NU6900FXZC come and go
              by polaro
              Greetings,
              I've bought a used Samsung UN65NU6900FXZC LED TV. It worked fine for some time and then developed, at first, a single very thin (1 pixel) vertical stable blue line, from top to bottom, close to the left edge of the screen. Now it's 3 lines on the left. When I connect HDMI sources the number of the thin lines grow. After disconnecting and cold discharging I am back to 2 lines. The lines disappear at a rate of 15-20 minutes per line. So it does not look like a damaged LED panel. Any advice? Thanks...
              08-27-2022, 08:46 AM
