Just Getting Started...
  • DJ4D
    • Nov 2013
    • 44
    I've been given a Baird 37" X37DTV that was apparently working fine but then one day whilst it was being watched it just went off and wouldn't power back on. It's my first Tv project and would be a good cheap upgrade for my son's 22" Tv that displays nothing other than Call of Duty and the Walking Dead on his XBox these days. It does have a VGA input as well so he could connect his laptop up to it.
    After doing some reading I removed the back and after clearing some of the dust and having a look around, I noticed a large slightly bulging cap on the PSU which I've removed and the top of it does indeed look likes its bulging. The other caps seem to be ok to the untrained eye but I've attached some photos juse in case.
    The cap is a Samxon 150uf 400v and upon removing it I can see some kind of residue on the bottom of it. I've cleaned the board with some rubbing alcohol just in case and removed the glue and everything looks nice and tidy ready for a new one.
    The trouble is, I can only find one Rubycon 400w 150uf cap on eBay - http://www.ebay.co.uk/itm/RUBYCON-40...item2a321130a7
    Everything else seems to be snap-on. The cap I would like to replace needs to have legs so that I can push the legs though the board, bend the cap over into position, solder it onto the board and then trim the excess from the legs.
    I went through the Maplin website and even gave them a call but they don't stock any 400w 150uf caps. I've had a look at RS Components and Farnell but I don't know if they sell to the public or if they're trade only [both are closed on a Sunday]. Their components did seem to have more competitive pricing but there were quite a few varients.
    I'm not really bothered where I get the replacement cap from providing its the right one and I don't have to wait weeks for it to come from China. Does anyone have any recommendations please?
    Also, I'd also like to stock up on a few of the components that regular fail inside a TV so I'm not buying them adhoc all the time and I can start up a little toolbox for TV related components and tools. I just need a few pointers as to the kinds of things I should be buying and where to buy them from please?
    I've attached some images of the large 400w 150uf cap that's bulging, and also some snaps of the other caps, some are a little hard to see so I've taken shots from a couple of different angles.
    [Edit]
    I've uploading some images but my broadband is currently down and uploading via my mobile isn't working well at the moment.
    [/Edit]
  • selldoor
    Slow Learner
    • Dec 2010
    • 7870
    Re: Just Getting Started...
    Too many questions in one post
    I will try and help with caps - Its very hard to tell other than by a straight on view of the side of a cap if it is bulged - your big cap does look bulged.
    Farnell and RS have outlets in Leeds - you do not have to be trade. If it helps you can go for a 450v 150uf cap. I have had a quick look and yes most are snap-in. That is not a huge problem you can just solder some legs on to it. CPC.com is another farnell outlet and they often have free post even on small orders
    There are a lot of fake caps on ebay so take care with that - I see someone with 30000
    feedback 100% has a nichicon if it will physically fit.
    If just that cap doesnt fix it you would be better posting in the Troubleshooting TV section
    • DJ4D
      • Nov 2013
      • 44
      Thanks very much for the info.
      I've found the supplier you suggested on eBay so I'll pickup one of those.
      I'll start a new thread in the Troubleshooting section as I'm still quite keen to buy some components in.
      Thanks again
      • shovenose
        Send Doge Memes
        • Aug 2010
        • 6575
        For smaller caps I'd recommend badcaps.net.
        For bigger caps you're fine on reputable sellers on eBay.
        • phuzzyday
          Sony KD-70X690E. Started with reset loops.. then it got more complicated. I'm at wits end!
          by phuzzyday
          First of all, thank you everyone who helps others in here! You guys are treasures! Please bear with me, this may be long. I have tried a LOT.
          First, my wife said the TV was turning off and on. When cold it would be fine for several minutes, then it would start resetting.
          I opened it up and noted there are two main lines coming out of the supply besides the backlight., The T-Con 12V line and the main 12V line.
          TRIED 1 - I scoped power coming from Power Supply while it was all still connected. I noted that just before it reset, the 12V line going to the T-Con was going...
          03-26-2025, 05:53 PM
        • ncoy1123
          Getting started repairing HP Chromebook 11a g8 EE Motherboards
          by ncoy1123
          Hello, I'm pretty new to component level repair and have only ever done things like replace headphone jacks or connectors, if those are even considered component level repairs. I have some Chromebook motherboards that are dead that I would like to practice on, but I'm not exactly sure where to start. I have HP Chromebook 11a g8 EE and HP Chromebook 11a g6 ee and their layout looks very similar. The issue that I have is there's power to the USB ports, but they don't actually turn on. There's no display output, and the way that usually flashes when it posts doesn't do anything. I was wondering how...
          10-21-2023, 09:16 AM
        • khalillll
          maxipower 400W Dead power supply repair
          by khalillll
          The power supply was completely dead. Voltage reached the main capacitors, but nothing after that.
          After checking, I replaced the UTC7606D IC to restore the 5VSB.
          I using SDC606U as a replacement, but it didn’t work — possibly the IC itself was faulty.
          Replaced it again with another UTC7606D.
          Result: 5VSB came back, but still nothing — no 12V, 5V, or 3.3V.
          After checking again, I think the issue was with the UTC7520D IC.
          Replaced it with a WT7520.
          Result: PSU fully working again
          09-27-2025, 05:06 AM
        • coasterghost
          Lenovo T14 Gen 2 Type 20XK Model 20XK0069US Odd Charging Issues
          by coasterghost
          For Badcaps Readers, Please note that I am hopefully going to present this same message to Lenovo to see if they have any insight to the matter as well and figured to share the entirety here for clarification. The System is out of warranty as it is but does have the option to have it extended.
          Model Information: T14 Gen 2 (Type 20XK, 20XL) Laptop (ThinkPad) - Type 20XK - Model 20XK0069US
          Board: T14 Gen 2 (Type 20XK, 20XL) - Type 20XK.
          System Hardware:
          Processor: AMD Ryzen 7 PRO 5850U
          Memory: 1x 16GB DDR4 3200 (Soldered on Board); 1x Crucial 32GB DDR4...
          09-08-2025, 10:46 PM
        • SaYHell0
          macbook pro a1989 macbook started But no screen on extern or intern display.
          by SaYHell0
          Hello i guess i have another logic board as the usual a1989?
          Iam new into smd fixing but i want to learn That because that makes so much fun
          I guess i Found my Problem?
          Problem was: macbook started But no screen on extern or intern display.
          Cpu/gpu was very Hot after trying a few commands with reboot...
          06-01-2023, 03:48 PM
