Dynex DX-32L150A11 Standby Blink
  • ohmmy
    • 182
    This Dynex just gives a blinking standby light.
    Measured ouput voltages from psu and only one 5v rail labled 5V1 has a reading, a very low wavering reading. Highest it reaches is 1v
    When I disconnect psu from main board and remeasure voltages the same line "5V1" now gives a 5.20v reading, still nothing from the others.
    I then tried loading that line with a 12v car lamp and the wavering voltages mentioned originally came back (not sure if the load was too much for it?)
    No bulged caps, everything looks fine visually. I've attached some pics, if you need any others of specific areas please let me know. What should I do next?
  • ohmmy
    • 182
    Re: Dynex DX-32L150A11 Standby Blink
    I can also hear a very faint ticking sound from the psu. Any suggestions? Would like to get this up and running.
    I've ESR'd the caps on the standby rail coming from the smaller transformer and they all tested good. As well as the diode on that rail.
      That is indicative of several possible faults:
      - shorted secondary diode
      - bad startup capacitor (not necessarily bulging!)
      - bad startup charge ckt
      • ohmmy
        • 182
        I've tested all secondary diodes (in circuit) and they all seemed to test fine.
        I've direct replaced what seemed like the startup capacitor, c525 47uf 50v with no change. (in attached picture next to N501)
        Where would the startup charge circuit be?
          Check the voltage across that capacitor in the fault condition and when working (main b/d unplugged). What do you get? You may have a short on main board. A 12V car bulb may draw too much (60W headlamp or 12W brakelight? Those are at 13.5V, but for 5V, will still be about 1/4 power, maybe more.)
          • ohmmy
            • 182
            It was headlamp bulb.
            voltage at cap with main board unplugged: 13.6v
            voltage at cap with main board plugged in: jumps around from 8-15v
              OK, do you have a spare brakelight or similar? May work better as load for 5V. Looks like main board has short on it.
              • ohmmy
                • 182
                I don't, anything else I could maybe use? What about a small computer fan?
                Also, how would I go about finding a short on the main board?
                • ohmmy
                  • 182
                  I used a 12v 220ma CPU fan on that 5v rail and it powered up, voltage measured a steady 5.20v
                  Should I try with a higher watt load or safe to say there's a problem on mainboard?
                    PC fan ~100mA is fine for a standby type load, yes it indicates a short on the main board.
                    What you need to do is either try tracing for shorts using an ohmmeter, or try my favourite method which involves freeze spray. You freeze spray parts of a board whilst passing a small current (around 1 amp) through it. The parts that melt the freeze spray likely have the short.
                    • ohmmy
                      • 182
                      How would I trace for shorts using an ohmmeter?
                      When I have mainboard plugged in, every component seems cold to the touch, in the past I'd at least notice some warmth on a faulty component.
                      Wouldn't know how to exactly only pass 1amp to the entire board while freeze spraying
                        Shorts are traced by testing resistance along the board, looking for low readings, it can be very difficult on a meter with only one decimal point which is why I suggest the current method, but that requires a constant-current constant-voltage lab power supply.
                        • ohmmy
                          • 182
                          Would the short be on that 5v line or anywhere? I could try tracing it on the mainboard
                            It would be on that 5V line.
                            • ohmmy
                              • 182
                              I traced it to a couple smt capacitors and a couple voltage regulators. Do I need to check them off board for shorts? They don't test low ohms as of now, neither do the caps
                                What resistance did you measure at the 5V terminal directly on the main board, compared to those at the caps/Vreg?
                                • ohmmy
                                  • 182
                                  I'll have to retest and get back to you. Just left my house. What should I be looking for exactly?
                                    Low resistance: generally less than 10 ohms is a concern.
                                    • ohmmy
                                      • 182
                                      So I'm looking for the same reading I get from the 5v terminal to ground when checking others components to ground?
                                      • ohmmy
                                        • 182
                                        From the 5v terminal to ground I get a reading of 134ohms. I found the same exact measurement on a smt cap on both ends. It's a shade of grey. No clue what the rating would be. Could this mean it's shorted?
                                        • Cookybaby
                                          Samsung UN60ES6500FXZA Power Supply Issue
                                          by Cookybaby
                                          Hello Everyone, this is my first post and I am excited to be a part of such a great community. I've been reading these forums for awhile and there really is some good friendly people here. No bashing and being rude like 90% of other forums Ive been to. Lets get to the good stuff.
                                          I have two years of college in Electronics Engineering Technology. Ive been tinkering with electronics sine about 1990. I know enough just to be dangerous, so be gentle.
                                          Make: Samsung
                                          Model: UN60ES6500FXZA
                                          Power Supply P/N: BN44-00525A
                                          Symptoms: The TV was...
                                          08-20-2023, 12:26 PM
                                        • cloo
                                          Panasonic ZT60 plasma tv with strange behavior and 8 blink code
                                          by cloo
                                          I recently got my hands on a 60" Panasonic P60ZT60 plasma tv (european model) that has some strange issues along with an 8 blink code.
                                          It know this tv is getting old but it was once considered one of the best plasmas ever made, and i think it is still holds on to that even by todays standards.
                                          So, long story short. When i first got the tv it had a very bright washed out picture with very raised blacks in all picture modes and i couldn't find the cause in the picture setting menus.
                                          After doing a factory reset this problem was gone and the picture was back to...
                                          01-06-2025, 06:02 AM
                                        • tvguy12012012120
                                          by tvguy12012012120
                                          02-07-2025, 05:13 PM
                                        • EazyBone
                                          Un50cu7000 2 blink oddity *partially solved
                                          by EazyBone
                                          I write this to maybe help another with this TV.
                                          So I aquired this TV a 2023 model. It started the 2 blink reboot problem which indicates bad panel. It was still under warranty and the repair man came by.
                                          The Samsung repairman brought a brand new panel and switched my original boards to the new panel. The new panel then had the 2 blink error code. The repair guy said he has seen this and the MAIN board on this model will cause the 2 blink. He then replaced the main/power board (they are both connected) and put it back onto my original panel. Voila it worked.
                                          03-18-2024, 10:24 PM
                                        • fharris1977
                                          Vizio D50u-D1 Dead Set No Standby
                                          by fharris1977
                                          Hi. I got a Vizio with no power or standby, and won't turn on with remote or button. I checked the voltages on the connector and all read 0.00V or nearly 0(0.050 ON/OFF pin). None of the pins are labeled STB for standby although I do see some 5V pins. Other than the obvious standby led, which isn't coming on, is there a way to check for standby voltage on this PS. I'm trying to see if my problem is the PS or mainboard. Some Vizios I have fixed with no standby led me to think it was the PS but it turned out being the mainboard. Any experience with this set would be greatly appreciated.
                                          12-28-2023, 10:25 AM
