Philips 42PFL9603H chassis Q529.1E LA wont power on
  • jbfr_54
    • Dec 2012
    • 52
    • France
    Hi All,
    I have a problem of powering this set. When pluging main's cord, the light guide (center bottom LED) flashes during a few seconds then nothing else happens.
    The red standby light is off and te remote does not operate. Pushing the Power button on side keyboard does the same. Still no Stdby LED !
    I verified all the power supplies from the PSU and inside the SSB board, they seem to be OK (using voltmeter and oscilloscope).
    When I electrically touch around DC/DC converters of the SSB board, using the Power button allows sometimes the set to Start and run normally. I discovered that possibility accidentally ! In that case, the set being working normally, if I turn it off to standby using the RC, the set stops and the red LED is ON indicating Standby status. In such case I can restart and stop the set using the RC without any fail as many time as I wish.
    From the working status or the Stdby status, if I unplug the main's cord, the set recovers normally when the cord is plugged back.
    If, from the Standby status (red LED ON) I push the Power key, the sets shuts off the standby status to go to POWER OFF status, red LED going off as expected.
    At this point, I cannot restart the set as described at begining.
    It seems that from the POWER OFF status, I cannot swith to STANDBY STATUS.
    I updated to the latest firmware, check the option codes in the Service Menu, no change in behavior.
    Any idea ?
    Regards.
    Jean
  • jbfr_54
    • Dec 2012
    • 52
    • France
    Re: Philips 42PFL9603H chassis Q529.1E LA wont power on
    Hi Guys,
    No one has ever fixed this set or this type of problem ?
    Please help !
    Regards.
    Jean
    • jbfr_54
      • Dec 2012
      • 52
      • France
      Hi All,
      Just in case someone gets interested in this case later !
      I finally solved the problem which was due to a lack of power on the 3.3 v stdby supply. When hitting the Power switch, the 3.3v stby supply was droping down to 3.15v (3.4v during normal operation). This was detected by the 7HD0 IC (NCP303LSN30) thus generating an undue Reset-stdby signal which is supposed to happen only at mains plugging. The resest-stdby signal was forcing the controler to remain at the Off state instead of going to Standby status when pushing the power on button.
      The 3.3vstandby power line is generated separately than the other supplies in the PSU. It's circuit is powered by the main line through two caps in parallel (100 + 22nF) labeled 2165 and 2179. Their values were 67 and 17 nFarad respectively. Replaced by a new MKP 0.12uF has solved the problem.
      The tricky thing is that the 3.3vstdby supply was OK when set was either working or in standby and only droping when pushing the Power button.
      Hope this ca help someone as I spent hours of intensive search for this problem.
      Regards.
      Jean
      • majortom
        • Dec 2012
        • 3
        • israel
        Originally posted by jbfr_54
        Hi All,
        Regards.
        Jean
        would never have thought about it . many thanks
        • acinfo64
          • Jan 2010
          • 3
          Thank you very much! It was exactly what I was looking for, thanks!
          • jbfr_54
            • Dec 2012
            • 52
            • France
            Glad it helped !
              There is similar bulletin on these caps.
              • jbfr_54
                • Dec 2012
                • 52
                • France
                Well, if I had that on hand, it would have saved me a lot of search time ! Thanks for this added information.
                Jean
                • N-P-Rhodes
                  • May 2015
                  • 2
                  • Denmark
                  Well this thread did the trick! Thanks guys! I followed the instructions in the .pdf above. The components cost me just around 5 DKK = ÂŁ0.50 = $0.75. Postage was 12 times this amount! Removed the existing caps and replaced with the new ones. TV worked first time! Certainly cheaper than buying a new one. Thanks again everyone.
                  • chini7236
                    • Nov 2014
                    • 1
                    • spain
                    Thank you very much! It was exactly what I was looking for, is the fault I had, thank you very much
                    • Gil
                      • Sep 2014
                      • 2
                      • Italy
                      • alekosrepair
                        • Apr 2018
                        • 1
                        • Greece
                        Another successful repair, thank you very much guys!
                        • Moost
                          • Mar 2021
                          • 1
                          Thank you very much! As discribed in the posted PDF I replaced the capacitor 2165 from 22nF (it had only 18nF) to a 47nF and the capacitor 2179 (it had only 56nF) to a new 100nF.
                          Now the TV works perfectly again!
                          • alro7779
                            Philips 32PFL4901/F8 BA4GF0F0102 2 Not getting standby led
                            by alro7779
                            Hello, guys!
                            The same 32" Philips TV I was having video issues, but now I don't have standby led at all. Someone here shared with me the schematic of the power supply, and checking the voltages, I see right after the resistor R604 I'm getting 1.6 v which is too low for enabling the Gate of the Q601 mosfet (the diagram says 4.2). On the R614 resistor I'm getting 181 V in and 117 V out, then through R603 I'm getting the same 117 V in and 59.9 V out, finally getting the latter voltage in the R604 BUT getting just 1.6 V out, which is the voltage that goes on to the Gate of the Q601...
                            09-14-2025, 12:25 AM
                          • Bad_IC
                            Philips TV 37pfl5604h/12 no standby voltage
                            by Bad_IC
                            I have a problem with this TV, the standby voltage is not present. I have checked the components around the IC fsq510's area and they seem to work, also replaced this IC but the problem persists.
                            These are the voltages in some pins of IC fsq510:
                            Vcc=18v
                            D=320v
                            Vstr=154v
                            Unfortunately, I couldn't find the schematic
                            What else could I check?
                            Is it possible to provide standby voltage from an external source to allow the TV to turn on?
                            Thank you​...
                            11-08-2024, 01:07 PM
                          • jasonbay13
                            Philips 37HFL5682L/F7 no standby light, incomplete service manual?
                            by jasonbay13
                            picked up a tv and when the power is plugged, the standby light flashes real quick then goes off. of 3.3, 12, 24v is all there but i couldnt find any 5v on the back-end board. ON/OFF is low, which it seems is what turns on the backlight so i removed the wire at the back-end board and put a 10k resistor to the 3.3v, which when plugged in brings on the backlight for a split second and also a blue light "LED1" on the inverter board, which goes off after a short time.
                            am i missing something to bring on the backlight or is the inverter/ccfl gone bad? would that cause the inverter board...
                            12-01-2023, 09:55 PM
                          • DynaxSC
                            ASRock B650M PRO RS - BIOS CHIP 25Q256JW BLOCKED BY STATUS REGISTERS
                            by DynaxSC
                            Hi
                            I have then desoldered the chip, backupped the contents, and tried to earease the chip in order to program stock image, but the chip is locked by status registers SREG2 (TB) and SREG6...
                            08-04-2025, 12:20 PM
                          • tvguy12012012120
                            by tvguy12012012120
                            02-07-2025, 05:13 PM
