panasonic lcd tv th-l32u20 10,blinks
  • guruji
    • Oct 2012
    • 120
    • India
    Can anyone help me with what is 10blink code it says the zwei2_sos, what do i need to troubleshoot first. Is a small board in the panel.
  • guruji
    • Oct 2012
    • 120
    • India
    Re: panasonic lcd tv th-l32u20 10,blinks
    I think the problem is with the p board the 2 relays come on for a while make dc 300volts but i see no auxillary power to a board like +12v and +17v absent only stdby 5v and 3.3v are there. The ssc9512 has vcc power but the reg voltage at pin 9 absent is that the cause. Board nos are tnp4g467 and tnp4g469
    • guruji
      • Oct 2012
      • 120
      • India
      Ok problem was with r7305 1mohm resisitor going to pin 1of ic ssc9512for acin detect signal.now the set is back to life thanks
      • Tynan Dill
        by Tynan Dill
        Assuming...
        11-22-2024, 01:46 PM
      • m1ch43lzm
        by m1ch43lzm
        05-12-2025, 08:37 PM
        Panasonic switching power supply daughter board has two 27uf @ 50 volt capacitors which I do not keep in stock
        by sam_sam_sam
        I did not have any 27uf @ 50 volt capacitors but one nice thing is that it has enough room for two capacitors in parallel a 22uf and a 4.7uf @ 50 volts 22 plus 4.7 equals 26.7uf which so very close to 27uf I will show some pictures of it sometime tomorrow
        This is one of the shit est boards I seen in a very long time and it was the daughter board the traces just lifting off the board I had to use the capacitor leads to repair the the traces and the main board is not any better because I had to repair several traces for the daughter board to the main board
        After all of...
        07-13-2024, 08:14 PM
      • canadaboy25
        Panasonic TC-P54VT25 No image. A or D board?
        by canadaboy25
        I have a Panasonic TC-P54VT25 that will power on and prime the display but there is no image at all.
        The panel is primed as there is a slight glow from the entire panel. This means the problem should be logic related. The service manual also confirms this and recommends replacing the A or the D board.
        I have tried to get the TV to display the test sequence but I have been unable to and I don't even know if this TV has a test sequence or not. I tried following tom66's instructions in post #3 on this thread https://www.badcaps.net/forum/showthread.php?t=26790. There was...
        01-17-2021, 01:06 AM
      • howardc64
        by howardc64
        07-24-2025, 05:17 PM
