Zalman ZM600-HP / Beginner
  • lemonadesoda
    • Mar 2013
    • 5
    • Switzerland
    Hello all, new at BC.net and FP. I came here via google.
    I have been using Zalman ZM600-HP without issue for 4 years in a s771 dual Xeon system. ASUS DSEB-DG. 4x FB-DIMM and 2x E5420. (FSB 533, 2.5Ghz).
    I run a FireGL v3750 which doesnt need additional power (power from PCIe slot). So power consumption/load is not high on this system.
    Recently upgraded (within last month) to 2x E5472 (FSB 800, 3.0GHz).
    This weekend I started getting unpredictable shutdowns. Sometimes when just at desktop, ie no load on CPUs or GPU.
    Today I can't even get the PC started. Between 30 secs and 3mins after boot I get a shutdown. ie. will shutdown even within F2-BIOS utility.
    I reseated FB-DIMMS. I reset CMOS. I removed one CPU and reseated the other. Same problem, no improvement.
    I'm guessing MB failure/chipset or PSU Zalman ZM600-HP. Perhaps the higher FSB and new Xeons stressed the system. Or perhaps it is just natural aging of MB or PSU. Quick google of ZM600-HP brought me to this forum. So I thought I'd say hello and ask from your experience.
    I don't have the equipment (scope, caps or soldering) to test or fix the PSU myself. But are there some visual inspections I can make to see if it was the PSU? I will then go out and buy a replacement. Any suggestions? Am I OK to stick with the same model, or would you advise different PSU for the dual xeon workstation?
    Thanks for any pointers.
  • cheapie
    null
    • Jul 2010
    • 849
    Re: Zalman ZM600-HP / Beginner
    Have you looked on the motherboard and in the power supply to see if there are any bad caps?
    • lemonadesoda
      • Mar 2013
      • 5
      • Switzerland
      I've made a visual inspection of the mainboard.
      - There are no obvious bulging caps, no explosion/bursts, no burnt or overheated discolourations.
      I opened up the PSU since it's over 3 years old, I guess the warranty sticker means nothing.
      Shame. A visual clue would have helped.
      I've tried booting with just one CPU and one stick of FB-DIMM. And without HDD attached. While I can get to the BIOS menu, and disabled things like Speedstep etc for the CPU, if I leave it at the BIOS menu, sure enough after (randomly) a minute or so the machine reboots.
      Any pointers welcome. New dual socket mainboards + EPS PSUs aren't cheap... so obviously want to target whatever has failed, and not have to buy both!
      I should have mentioned in OP:
      ASUS DSEB-DG
      2x Xeon E5472
      4x FB-DIMM 2GB=8GB
      FireGL v3750
      Is there any change a defective/failing GPU could damage a system/chipset? I swapped out the v3750 for an older v3400 and had identical issues. But could the v3750 have damaged the PCIe lanes in the chipset causing this. Am I fishing at straws?
      • digge
        • Apr 2006
        • 296
        Try to get another PSU to try with, maybe borrow one or something. That would be the easiest thing to do compared to start measuring components and stuff. If that doesnt work you can start to dig deeper into the problem.
        • selldoor
          Slow Learner
          • Dec 2010
          • 7870
          As Above and /0r post really good pictures of the PS -experienced members may spot something. The caps may have pushed out the bungs at the bottom - if as in other posts regarding this PS they are Capxon caps then after 3 years they are probably done so changing them might fix it. They are not easy to work on so depending on equipment and skill level and the cost of parts may not be worth it unless you want the experience.
          • lemonadesoda
            • Mar 2013
            • 5
            • Switzerland
            All caps are mounted with their bottoms on the PCB, so no obvious bottom farts.
            Here are some pictures. The "yellow" you see on top of the caps in the first picture is deceptive. They are shiny silver, and are reflecting the colour of the yellow cables behind them.
            Yes, they are CapXons. PSU over 3 years old. I'll start by replacing the PSU then.
            • lemonadesoda
              • Mar 2013
              • 5
              • Switzerland
              Replaced PSU with SilverStone Strider Plus 1000W (somewhat limited options at the PC store...I would have preferred a 600-750W PSU). Workstation stable so far. (30 minutes + OpenGL tests). The old Zalman PSU had obviously developed a problem. Shame. Had worked well until last week. Expensive bit of equipment for relatively short life.
              What should I do with the Zalman? Is it worth fixing, or is it for the bin?
              • selldoor
                Slow Learner
                • Dec 2010
                • 7870
                If you have all the equipment you could change the caps but then you have no use for it, so a waste of time?
                If you have a Freecycle where you are someone might like it for free to try and fix up.
                • Mess
                  Beginner question. Did I find a short?? HP dax31mb1aa0 REV A motherboard
                  by Mess
                  Hi beginner here, so I'm not sure of I've done this right 😅 trying to diagnose my laptop's motherboard (dax31mb1aa0 rev a). I don't quite know how to read the schematic, so I'm attaching the pictures of the motherboard and the measurements.
                  I was attempting to measure resistance to GND on inductors. I disconnected motherboard and used "continuity testing" setting on my multimeter. I put black probe to Ground & red probe on an inductor. Did I measure this right? Am I correct to think that 0.3 ohm measurement indicates a short circuit? Thank you for your help!...
                  09-15-2024, 09:56 AM
                • Mess
                  Motherboard diagnostic beginner advice
                  by Mess
                  To save you some time: the most important bits are in bold.
                  Some further examples/explanations or to the side & in grey - you can probs skip them if it's TLDR for you. Sorry, I've got ADHD & tend to over-explain stuff - just like I'm doing right now 😅 Briefness is for poets not me 🙈
                  Please help!! 🎶I'm just a girl in a world that wants to scam me out of lots of money for any tech stuff/repairs 🎵 Seriously tho, I'm poor&I can't afford to get laptop diagnosis, especially if it ends up needing a new motherboard. Where I live, all the tech shops are run by very...
                  09-12-2024, 07:02 PM
                • dbuergi
                  MacBook Pro A2338 liquid damage repair for a beginner?
                  by dbuergi
                  i have a A2338 with water damage on the logic board. Cleaning it showed some heavier corrosion around U7000 and surrounding caps. Some are totally broke.
                  I get 5,2v when using both USB-C Ports but until now i didn't make any more tests.
                  Since i'm a beginner i want to know next possible steps. I'm not afraid replacing the intersil 9240hi but the other parts with 1mm or 2mm scare me and i don't know where to get replacements.
                  I fixed other laptops but this ist my first apple device ....
                  07-24-2024, 09:48 AM
                • Bladiblad
                  HP RTX 3060 with bad cap (beginner project)
                  by Bladiblad
                  I have an interesting project here. I have a HP RTX 3060 12GB VRAM GPU with a shortcircuit between a (what I believe is) a coil and a cap. The short circuit is so bad that it will trigger a failsafe on the PSU.
                  I'm a beginner in this field and have managed to do only very simple board repairs so far. I have basic understanding of the components (mosfets, caps, nand chips) but completely diagnosing a board with schematics would be challenging. In this case though, I'm going to hope that replacing only the two shorted components will bring the card back to life (if none of the IC's...
                  06-14-2024, 06:42 AM
                • CanukTuk
                  Beginner Tutorial for using RCUnlocker to remove BIOS password?
                  by CanukTuk
                  Kinda new to this, so hoping you will all give me a bit of a pass.
                  I came to this forum because need to remove the BIOS password on an HP EliteBook 850 G1.
                  I understand that I need to dumpt the BIOS to a dump file, process the dump file with RCUnlocker, then write the modified BIN file back to tthe BIOS chip.
                  Is there a beginner guide anywhere that describes the entire process for doing this?
                  I am reallly in the dark regarding which tool or tools are required to extract the BIOS dump file, then write the modified BIN back to the BIOS chip. The guides I have...
                  03-24-2024, 02:54 PM
