This one is pretty beat up from the out side, the setup menu looks OK, but the video is full of noise. This seems to be common problem when this TV came out, the fix was to replace the main board. So far it is no affected by hot or cold. I will be doing more checking.
Samsung LNS4695DX bad main board
http://www.badcaps.net/forum/showthread.php?t=24809Tags: None -
Re: Samsung LNS4695DX bad main board
This is a very common issue with Samsung DLPs, and I believe the main board is the same or very similar for these LCD TVs. One of those Samsung RAM chips has failed. You can remove and replace them.Last edited by tom66; 02-19-2013, 04:30 AM.Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
For service manual, schematic, boardview (board view), datasheet, cad - use our search. -
i have a recently given one of these to fix. Model # LN-S4695D to TOM66 you feel confident that the ram chips is the problem?Comment
Not certain, not done it myself....Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
For service manual, schematic, boardview (board view), datasheet, cad - use our search.Comment
My symptoms are pretty much just as pictured above.
one notable thing is ant menu driven on screen stuff looks fine.
it just goes wacky with hdmi input, all 4the same. and off air reception is same regardless of resolution it pics up.Comment
This one uses a mix of standard SDRAM and BGA type DDR(1/2).Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
I parted it out.Never stop learning
http://www.badcaps.net/forum/showthread.php?t=24809Comment
I used the spare parts to fix other TVs, I have way many TVs to fix up, when parts of one TV can be used to fix other 3 or 4 then it makes no sense to fix one. Did you try the new chips?Last edited by budm; 05-05-2014, 04:06 PM.Never stop learning
by Asraf AtbHi everyone,
Im looking for some advice regarding my Samsung UE55MU8000 TV with main board model BN94-11606C. The TV suddenly stopped turning on and now shows no signs of life at all not even the standby light at the bottom.
Initially, I suspected an issue with the PSU, so I took it to a repair center. They tested it and confirmed that the PSU works perfectly, even on other TVs. Based on that, I started investigating the main board.
I disconnected the main board from the PSU, and the backlight turned on, which seems to confirm the main board is the issue....1 Photo -
by mrautom8Schematics for the main board needed please. Sticker on board states BN94-07517A but the silkscreen says BN41-02157B. Cant find here or anywhere on the web.
Backlights work when main boards disconnected. When connected and power button switched, the relay on the PSU board turns on for one second then back off.
While relay is on, all voltage rails are present and steady (scoped) on main board.
I love a good logic puzzle but getting lost without any schematics.
No shorts on ANY capacitor main board.
Thermal camera shows 3.3V inductor getting warm instantly but...-
Channel: Schematics and Boardviews
10-19-2025, 06:32 PM -
by Dani_2024Hi and thanks in advance for any input you might provide!
Last Sunday I was watching a dvd and fell asleep for about half hour, when I awoke the tv screen was black and couldn't get the dvd menu to show, so I changed the input to antenna and had sound but no picture, turned it off. I then got online and found this great site! ....read many troubleshooting tips and this...5 Photos -
by ygorsanHi everyone,
Iām looking for help with a persistent issue on an LG TV model 55NANO77SRA, which uses the main board EBU66792103 (also used in LG UQ80 and NANO75/NANO80 series).
š§© Problem Summary:- The TV keeps scrolling through the menu or selecting items by itself.
- I removed the physical button board (the entire panel with power and volume buttons) and also disconnected the flat cable (CN202) from the main board.
- The remote control is not in use (batteries removed), and the TV still shows the same behavior.
- I
07-28-2025, 08:34 AM -
by Lee M.When plugged in it will click and cycle the BL on and off, no pic and does not respond to remote. When I disconnect the cable from the PS board to the main board and then plug it in the BL will come on and stay on. There are only two boards in this set, the LVDS cables from the panel driver boards connect directly to the main board. Since the BL comes on and stays on I'm thinking the PS board is ok and the problem is on the main board. Should I order another main board or do I need to do more testing? thanks, Lee
- Loading...
- No more items.
