Samsung 55" lcd ln66c630 no backlight
  • Tdbueche1
    • 4
    Was watching tv, heard a small pop and picture went out while sound still works. Ordered and replaced inverter board but still have the same issue. Given the pop sound is it likely that one of the ccfl bulbs is bad and causing the entire issue? I have no light at all from the tv other than the power lcd light. Thought of trying a new tcon board but not sure. All caps look good and still have power/sound so thing the main board should be good to go.
    I know getting to the ccfl's is not going to be easy so wanted to get opinions before starting that. Tcon board would be easy but the pop then no picture makes me wonder if that is even the issue.
    Re: Samsung 55" lcd ln66c630 no backlight
    Can you please verify the model number?
    • Tdbueche1
      • 4
      Model is LN55C630K1F. Sorry about that.
      • Tdbueche1
        • 4
        Re: Samsung 55" lcd ln55C630 no backlight
        This is the correct model #
          OK, your TV uses power supply-inverter board and balancer board that gets the High Voltage outputs from the Power supply-inverter board and get distributed to each lamps.
          If one of the lamp is bad you still should see the backlights flash on for seconds before the inverter goes into shutdown due to bad lamp (the inverter will fire up the lamps first, if it detect too much current flowing in any one of the lamp the little lamp current sensing transformers on the balancer board will send the feedback signal to tell the inverter to go into shutdown, or if it detects that after the lamps are fired up but one or more lamp did not stay on, it will also go into shutdown. The detection will detect the problem in the first 3 seconds to make sure all are OK for the inverter to stay on.
          So look real close at the screen in the dark room to see if the lamps flash at all first.
          • Tdbueche1
            • 4
            Thanks! Tried that and the screen stays completely black. Back cover is off so tried also looking for some sign of light from the back of the unit and nothing there either. Does this point us in any sort of direction?
              That means the Inverter circuits ddi not even try to run.
              So next thing we need are really GOOD CLEAR FOCUSED pictures of the back side of the TV so we can see how all the boards are connected together, and then good pictures of the power supply board.
              • southernmd2
                • Feb 2014
                • 1
                • usa
                I too am have this same issue with this model. replaced the inverter with no change. I read that c1818 on the power supply board had been the fix for others with this problem. but upon inspection found the location for c1818 but no capacitor.
                • Ierwin
                  by Ierwin
                  05-13-2025, 03:31 PM
                • Tynan Dill
                  by Tynan Dill
                  Assuming...
                  11-22-2024, 01:46 PM
                • Cornito
                  Thomson 50UD6306 (TCL) Backlight Issue, starts then stops, led changed
                  by Cornito
                  Hello Team,
                  I'm back with another backlight issue that I thought was simple, but it turned out to be more complex than expected.
                  Let me provide a brief history: The TV was working well, then one day, the backlight started and shut down. I thought I had an LED issue leading to this behavior, so I replaced the LEDs with brand new ones. However, the issue remains the same.
                  Next, I replaced the electrolytic capacitors attached to the LED power supply, but the results were the same. I then replaced the driver, a OB3365RP, and did it twice due to the same result....
                  08-08-2024, 08:09 AM
                • totof
                  Samsung UE55JS9000 backlight issue
                  by totof
                  Hello.
                  I'm sharing with those in the know a problem I'm having with my Samsung UE55JS9000T TV, which has a backlight fault with halos of light on the sides (see my photos). This is a model with LED strip backlighting on the sides.
                  I took the TV apart to remove the panel and noticed that the "yellowish" film on the Plexiglas light diffusion plate was stuck to the LEDs. When I peeled it off, it left marks on the Plexiglas plate, which I cleaned as best I could with rubbing alcohol (see photo).
                  The result isn't perfect, but it still seems pretty good to me.
                  Today, 08:27 AM
                • TR103
                  by TR103
                  - it keeps rebooting
                  01-22-2025, 04:12 PM
