i am thinking about recapping my thermaltake tr2 430w while i am working on the monitor killing 2 birds with one stone so to speak i was woundering if anyone knows if all these have the same caps in them or are some different and does anyone know what caps are in it just dont feel like opening it up tonight i will crack it open tommorow. as a side note ive recapped it before with spares ive had in my collection so i am just wanting to replace those with good Rubycons.
My Computer.
AMD APU A4-3300 2.5ghz 1mb cache
Motherboard GigaByte GA-A75M-S2V
Kingston HyperX Blue DDR3 8GB (2x4GB)
SB Audigy 2 ZS [B800] Sound Card
500GB WD Caviar® Blue™
1 Terabyte WD Caviar® Black™
2 Terabyte WD Caviar® Black™Tags: None -
Re: thermaltake tr2 430w
680uf 200v x2
470uf 6v x3
1000uf 6.3v x1
1000uf 10v x2
2200uf 16v x1
2200uf 6.3v x3
10uf 50v x3
22uf 25v
4.7uf 50v
1uf 50v
some of the smaller ones are pretty hard to seeAttached Filesif you find these attachements useful please consider making a small donation to the site
My Computer.
2 Terabyte WD Caviar® Black™ -
anyone have any advice on what to get if i want to increase wattage of the psu above 350w?My Computer.
2 Terabyte WD Caviar® Black™Comment
It's a HEC OEM design... a review is here: http://www.hardwaresecrets.com/article/332
Not much you can do about increasing over 350 watts, in the review the 12v ripple was already at 85 mV at 16A load on 12v
Might get it a bit smaller by using a 3300uF 16v capacitor instead of the 2200uF 16v capacitor.
Other than that, like i said, not much you can do. It's an old design optimized for 5v which was tuned to up the 12v that's needed for new systems.
15-16A on 12v is still reasonable, enough for using it in a system with a video card that doesn't require a pci express connector, or even a card with a single 6pin pci express connector, that you know it won't use more than 80-100 watts when playing games.
That would leave 80-100 watts for the processor and fans, which is enough for single and dual core processors, even some quad core processors.Comment
ive read that.. figured as much i might not be able get much past 350w.It's a HEC OEM design... a review is here: http://www.hardwaresecrets.com/article/332
That would leave 80-100 watts for the processor and fans, which is enough for single and dual core processors, even some quad core processors.My Computer.
should i bother changing out the smaller caps or just leave them?My Computer.
You can leave Teapo and OST, they are not so bad in well cooled psus.
The primary caps are only good enough for 350W max. For 400W+ it should have 820uF.
Check if the 12V line of the power supply uses only 1 cap. If 1 of the 470uF caps is used for 12V you need to replace that cap with 1000uF or 2200uF.
Judging from the photos you posted it seems that 5v and 3.3V each use 1x1000uF and 1x2200uF. Another possibility is that 1 of them uses 2x2200uF and the other 2x1000uF. Either way I would at least replace the 1000uF caps with 2200uF.Comment
5vAttached Filesif you find these attachements useful please consider making a small donation to the site
My Computer.
With good enough silicon, even 470uF/560uF primaries can do 350W, though of course we'd be talking about more heat output + 7x% efficiency. I think it depends heavily on the rest of the components, similar to how a 35 size transformer can do 500W with good enough components. It also looks like there's conductive glue near the 5VSB output; I'd recommend getting rid of it.Originally posted by goodpsusearchThe primary caps are only good enough for 350W max. For 400W+ it should have 820uF.Last edited by Wester547; 10-06-2012, 12:07 PM.Comment
the yellow glue or white?With good enough silicon, even 470uF/560uF primaries can do 350W, though of course we'd be talking about more heat output + 7x% efficiency. I think it depends heavily on the rest of the components, similar to how a 35 size transformer can do 500W with good enough components. It also looks like there's conductive glue near the +5V output; I'd recommend getting rid of it.My Computer.
My Computer.
some of that glue is in the middle of alot of sensitive parts i dont want to damage anything.Attached Filesif you find these attachements useful please consider making a small donation to the site
My Computer.
well think i got rid of most of it
i reversed he fans i hope hat improves cooling.My Computer.
Reversed the fans? I thought a PSU was only meant to have the fan blow air one way (effectively out). I'd suggest keeping it where it was by default unless the PSU by default blows air into the computer and PSU (unless you mean case fans).Last edited by Wester547; 10-06-2012, 12:07 PM.Comment
i figured it would help if the psu fans were sucking cool air in.My Computer.
i just put them back the way they wereMy Computer.
by objecttothisI had a desktop form factor mini-server die on me a few weeks ago. Through my initial diagnostics, I was convinced it was the motherboard because when I shorted the Green wire on the ATX connecter, the multimeter gave me all the correct voltages on the various pins of the ATX connector and 5VSTB was also correct. To my surprise the replacement motherboard wouldn't turn on with the case power button either. I threw in another PSU and it turned on right away. This is an 80 Plus EVGA 430W PSU with PN:100-W1-0430. I pulled the cover off and don't see any immediately obvious blown caps or scorch...
by roddDear all,
I am trying to repair the ATX power supply.
First I fixed the +5V stby, which was zero due to a shorted TNY279 and an open 2R2 resistor.
Just in case I replaced the PWM control IC (PS223) and the PFC control IC (CM6800).
Now the supply turns on, the +3.3V is fine, but the +5V measures only 2.5V and there is no +12V.
I have checked every diode I could find with a DMM (in circuit) and all the capacitors (in circuit) no shorts, low ESR.
In despair I removed the low voltage diodes which were all mounted on the same heatsink... -
by AresROChttps://www.amazon.com/gp/product/B00NW6W2C8
I have a Thermaltake TR2 80+ Bronze that's been doing strange things. It would cause the computer to shot down randomly, and measures low voltage on the 12 volt rail. From 11.5 to 11volt.
I put it on the bench with a harddrive as load, and it outputs fine with low load:
5v - 5.17v
12v - 12.17v
It has all Japanese caps, but only 1 large cap for the Input supply. No obvious signs of overheating burns or bulge. Anyone know where I should start to troubleshoot? I guess I don't want to just start by replacing... -
by delturciousI have an older Thermaltake PSU that has a squealing noise whenever it's plugged in, even when totally disconnected from everything else. It automatically powers on the 5V and 12V rails with full voltage, but the +5VSB circuit only has 0.9V on it. I would assume this is my first place to start troubleshooting?
There is nothing obviously burnt/leaking that I can identify.
I've tried to take some decent photos of the 5VSB area. Components of notes:- U8 at the back is marked AZ431
- C38 is 102
- C47 is 104
- C34 is a Teapo 330uF 16V (I think all the cylindrical caps are
PSU: Thermaltake Litepower 500W Model: LT-500AL2NC
PCB: G08-CGPA462-PA00 Rev:A
I have this PSU installed in my PC for several years.
The problem is one day my PC cannot detect an external HDD so i think maybe the PSU caps already bad.
So i decided to open the case and found some of the secondary caps already bulging.
Then i recapping all the caps except the primary one (because i tested it with an esr meter and its still good) and i already tested all the new caps too before i soldered them.
After that the psu is good and my pc can... - Loading...
- No more items.
