Dell Laptop Charger
  • bluestone
    • Jun 2011
    • 343
    • Ghana
    Dell Laptop Charger
    Hi guys, anybody got any work-around for dell Charging Problems,. i have a lot of them at my shop when i plug in Charger i get a message saying;
    "the Charger cannot be Recognized.
  • selldoor
    Slow Learner
    • Dec 2010
    • 7870
    Re: Dell Laptop Charger
    This is a fairly well documented problem. Are you using a proper DELL charger.
    If so is the middle pin in good condition - clean/straight. Are the sockets clean.
    Try cleaning is isopropyl alcohol.
    I dont know of a workround as the chip is proprietary.
    • bluestone
      • Jun 2011
      • 343
      • Ghana
      I think it is a wattage issue with the dell adapters, the message always displays like, "the Ac adapter cannot be determine use 90wats or 60wats adapter, if i could know which ic on the circuit determines the adapter may be we could get a work-around those problems.
      • selldoor
        Slow Learner
        • Dec 2010
        • 7870
        No it isnt. It is simply that the laptop does not recognise the adapter.
        Originally to prevent the use of a non-dell adapter it can become a problem even with a dell adapter.
        There is a chip in the adapter which sends a signal voltage via the power
        cable centre pin to a receptor in the laptop. We even have the part numbers for the chips.
        So it could be a problem with the adapter chip ( proprietary data chip) so could only perhaps be swapped from another adaptor. The cable ( centre wire is quite thin and snaps) The plug ( clean or replace). The Socket clean
        or resolder or replace, or the receptor in the laptop (Proprietary ) replace from another laptop.
        Have you tried any searching at all - even in these forums? or Dell forum
        Have you tried another REAL dell adaptor to establish if it is the adaptor or the laptop.
        • b700029
          Banned
          • Sep 2010
          • 640
          Look here
          https://www.badcaps.net/forum/showthread.php?t=21494
          • LDSisHere
            • May 2012
            • 727
            • U.S.A.
            I have some experience with these Dell power adapter problems and solutions. I had originally posted this on a Dell forum and I am too lazy to retype it so if some of this information is redundant I apologize. I also may have a an easier to program option to the DS250x series that does not require 12V but I have not got around to confirming it as I still have plenty of DS2502's on hand. Hopefully this is useful and if anyone has any questions I will do my best to answer them.
            I am sorry if this post is too long, but what it covers took me a lot of time and effort to discover. I will try and explain what I know of the Dell power adapters from my experiences. I am no expert, but I think I have a good grasp on how they work.
            I started learning about Dell power adapters about 18 months ago when the power jack on my wife's laptop became loose, would only run at half speed and would not charge. I ran across many sites with people having the same problem but not much in the way of answers other than buy a new adapter or new motherboard. I did find one story on several sites about a guy that found the “identification chip” on the power supply, suggested that he had managed to read it and even proposed that it could be mounted directly to the motherboard so you would never get the laptop adapter message again. I saw it as a challenge of my computer abilities to see if I could do this and if it would work. It took much, much time and effort but I did succeed.
            On older Dell power adapters the “chip” is a DS2501 OTP EPROM 512 bit Onewire device made by Dallas Semiconductor / Maxim. I know this chip is in the PA-15 I have and in the PA-** that are rated at 60W and 90W, which I do not have handy to get the exact numbers. I found finding real information on this chip hard to come by nor could I find any for purchase. I could find more information on the DS2502 which is the big brother of the DS2501 with twice the memory, and these could be bought. If the chips were bought they would have to be programmed. This meant a programmer and the correct data to put on it.
            I had to opt for cheap and there is no challenge in buying a prebuilt programmer except paying for it. I found APP177 on the Maxim site for a serial Onewire programmer. They have software for Java and Window available for download that supports the serial programmer. The parts for the programmer can be sourced. I built the serial programmer on a solderless breadboard. I then discover that the software will not support a DS2501, it will not recognize nor read it. It would read the DS2502 so the programmer worked; the problem was in the software. I ended up having to modify their open Java software to read the DS2501 by making a container for it based off the DS2502 container then adding it to the program. I finally got it to work.
            I read the power adapter DS2501, programmed the DS2502 with the same information, and then soldered it to the laptop motherboard power jack. I powered on the reassembled laptop, no adapter warning, the BIOS is reported a 90W adapter connected and the battery charged again. I have since modified my E1705 and a few other Dells. Recently I etched` a PCB and I now have my Onewire programmer permanently mounted so I can now program the DS2502s I have on hand when needed. I would posts pictures but I have discovered that links to images are not displayed in this forum.
            This is other relevant information. My E1705 with a 256 MB GO7900GS came with a 90W power adapter. When I would play WOW it would get so hot you could cook on it. I then read on a forum that you could use a PA-15 150W adapter for the E1705. I got one and it worked great until the center wire went bad, that was when I modified it. I recently had the chance to work on a M15X with a PA5M10, which is also a 150W power supply. This adapter came with a DS2502. I tried the PA5M10 adapter in my sons E1705 (unmodified) and it accepted this much newer adapter without issue.
            I think that the laptops only care that the power supply tells them they are from Dell and of certain wattage. If the wattage of the power supply equals one the ones in the BIOS then it passes. If it does not match or does not detect then the laptop runs half speed and no charging. I also think that the DS2501 are out of production so will it only be on older power supplies.
            This is the link to my original post if it matters.
            http://en.community.dell.com/owners-....aspx#20141184
            • b700029
              Banned
              • Sep 2010
              • 640
              Have you considered using DS2431 instead? Same capacity as a 2502, slightly different write characteristics (closer to regular EEPROM), about 66% cheaper.
              • LDSisHere
                • May 2012
                • 727
                • U.S.A.
                The DS2431 was the chip I have been wanting to try, I just have not got around to ordering any. The capability to program these have just been added to the "OpenProgrammer" that I prefer to use over the serial one in need for the DS2502. The DS2431 can be programmed with 5V where the DS2502 needs a 12V spike to write to the chip so programming it is simpler. The OpenProgrammer will read a DS2502 when set to read a DS2431 as reading only requires 5V. When I get a chance I am going to see if it can read a DS2501 from an old dell adapter as getting the data off of a DS2501 was the hardest part of getting all this to work. Since the newer adapters seem to have the DS2502 in them it may not be a problem much longer anyway. The following links are for the OpenProgrammer home page and its' Source Forge page if anyone is interested. I have built two of them and have plans to build a third.
                http://openprog.altervista.org/OP_eng.html
                http://sourceforge.net/projects/openprogrammer/
                • nigelmercier
                  • Mar 2014
                  • 1
                  This is also handy: http://forum.arcadecontrols.com/inde...topic=118584.0
                  • amstel
                    • Mar 2013
                    • 16
                    Dell notebook power adapter dell containing chip DS2501.
                    Car charger DC adapter Special DC adapter for Dell:
                    ********* DEAD LINK **********
                    Tested and working.
                    • flat-earther
                      ASUS X54H laptop thinks it's always charging even with charger unplugged
                      by flat-earther
                      The charging indicator light on my ASUS X54H laptop is always on even when the charger is disconnected.
                      Windows also shows ''Plugged in'' when charger is not connected.
                      This problem started year ago gradually, when unplugging the charger the charging light took several seconds to disappear, then minutes, and now almost always on even when unplugged for an entire day.
                      Strangely, before sometimes immediately when plugging in the charger the charging light went away, and later came back with it connected.
                      If I let battery run out and say it has 3% Windows will...
                      06-24-2025, 09:32 AM
                    • serious_electron
                      Strange! Acer laptop not powering on but charging the battery (orange light on when charger and battery plugged in).
                      by serious_electron
                      Hello Everyone!
                      I have an Acer Aspire A315-42 laptop. I generally leave it on for long time by closing down its lid (so it enters the sleep mode). Recently, it rained quite heavily in out area. And the humidity and moisture seem to be high. So one late evening, after I opened the lid and turned on the laptop, it did power on as the blue light turned on but after it booted to the desktop screen, just 5-10 seconds after both the screen and blue light went out and laptop shut down (the blue power light turned orange). And after 2-4 seconds that orange light went off and the laptop died.
                      06-28-2025, 02:57 PM
                      ISL6257HRZ ISL6257HRZ-T Laptop Battery Charger Datasheet
                      Highly Integrated Narrow VDC Battery Charger for Notebook Computers
                      The ISL6257HRZ ISL6257HRZ-T is a highly integrated battery charger controller
                      for Li-Ion/Li-Ion polymer batteries. ISL6257 is designed for
                      Narrow VDC applications where the system power source is
                      either the battery pack or the regulated output of the charger.
                      This makes the max voltage to the system equal to the max
                      battery voltage instead of the max adapter voltage. Operating
                      at lower system voltage can improve...
                      11-05-2024, 04:43 PM
                      ISL88739AHRZ ISL88739 Laptop Battery Charger Datasheet
                      The ISL88739 & ISL88739AHRZ are a highly versatile combo battery charger
                      configurable for operating as either a Hybrid Power Boost (HPB)
                      charger or a Narrow VDC (NVDC) charger, supporting 2-, 3-, or
                      4-cell batteries. Both configurations allow the battery to work with
                      the adapter together to supply the system load when it exceeds
                      the adapter capability, referred to as system Turbo mode. HPB
                      charger configuration reverse-boosts battery energy to the system
                      bus to help the adapter provide the system power in Turbo mode.
                      NVDC charger configuration...
                      11-05-2024, 03:28 PM
                    • mikey5791
                      Dell laptop model PP24L won't start from ac adapter
                      by mikey5791
                      Dear all,
                      Bought this used Dell laptop PP24L(studio 1435) in Jan 2022. It was running smooth on 64 bit Windows 7 pro from processor Intel core Duo T6400@2Ghz with 2GB RAM. The laptop battery was charging and working fine until few months back the opening screen will display something like "replacing the battery warning", press F1 to continue. Normally i press F1, the laptop will proceed to Windows and i can use as normal.
                      But last week, after i pressed F1, the laptop just shut down. I suspected the laptop battery is dead. So i pulled out the battery and...
                      03-24-2023, 09:06 PM
