Enermax Liberty ELT400AWT making clicking noise but still running
  • Agent24
    I see dead caps
    • Oct 2007
    • 5037
    • New Zealand
    A couple of days ago I turned my old Athlon 64 machine on and soon after power-on I heard a loud clicking noise.
    It sounded very much like something knocking against fan blades, so I disconnected the case fan, put my finger on the CPU fan and a pencil in the PSU fan.
    No, the noise still happened.
    It seemed to be coming from the PSU itself. The PC was running 'perfectly' but as the PSU seemed to be the problem I immediately turned it off.
    I disconnected the PSU and powered it up with a jumper. It still made the clicking just not as much and maybe quieter.
    I found the higher the load, the faster and louder the clicking.
    Seems very odd that the PSU still runs while making such an 'bad' noise!
    I searched the forum and found a similar problem posted here: https://www.badcaps.net/forum/showthread.php?p=250827
    I also got this response:
    Originally posted by ben7
    Check the diode in the pfc circuit.
    But I want to start a separate thread here to avoid confusion.
    So, where is the PFC circuit and what kind of diode am I looking for?
    -David VanHorn
  • Behemot
    • 4845
    • CZ
    Re: Enermax Liberty ELT400AWT making clicking noise but still running
    PFC is usually on the primary side, either on separate heatsink, or with switching transistors.
    • ben7
      Capaholic
      • Jan 2011
      • 4059
      It will be mounted on the primary heatsink, its just a single diode, not a bridge-rectifier. You can track the leads from the PFC choke, and you will find that diode, and a mosfet.
      It will help if you temporarily remove the primary caps to get a better view behind them.
      Muh-soggy-knee
      • c_hegge
        • Sep 2009
        • 5219
        It looks like a transistor, but has two legs. In this picture, it's the part to the far right (the other two parts are the PFC transistors)
        • Agent24
          I see dead caps
          • Oct 2007
          • 5037
          • New Zealand
          Will have a look and post photos
          -David VanHorn
          • ben7
            Capaholic
            • Jan 2011
            • 4059
            That link is bad.
            Muh-soggy-knee
            • c_hegge
              • Sep 2009
              • 5219
              OK, Fixed. I attached it (it works here, though)
              • ben7
                Capaholic
                • Jan 2011
                • 4059
                Also there should be a high power low ohm resistor for the current sense in the pfc circuit, you might want to check that. If its value has gone up it could fool the control circuit into thinking there is a short circuit.
                Muh-soggy-knee
                • Behemot
                  • 4845
                  • CZ
                  Wouldn't it think its shorted when the resistance would go down?
                  • ben7
                    Capaholic
                    • Jan 2011
                    • 4059
                    No, remember, ohms law!
                    It uses a resistor to measure the current; the circuitry measures the current by measuring the voltage across the resistor. In fact, it wouldn't think its shorted when its a very low resistance, then it is possible for the mosfets to blow!
                    In the control circuitry there is a pre-defined trip voltage. Say the power supply primary has a max power of 100w. With a mains voltage of 120vac, that would be rectified into DC, around 165v. The max load of 100w with a supplied voltage of 165v would draw about 0.6A. We use E=IR to find the resistance of the current sense
                    resistor that we need. The voltage we want to trigger the overload at is 1v. 1v = 0.6A * R, so, R = 1.666. As the current goes to about 0.6A, the voltage across the current sense resistor will be about 1v. Then the protection circuit will kick in.
                    But, say if the resistors resistance increased to 3 ohms.
                    Finding the new trip current:
                    1v = I * 3ohm
                    so, I = 0.333A
                    That means that at only 0.333A, there would be 1v across the resistor, making the overload protection trip prematurely! The protection circuitry would think that there was an overload, but the power draw of the psu was really only around 54 watts!
                    Edit: and some psu's with PFC will actually work without the pfc running, but of course it will have a bad power factor.
                    Muh-soggy-knee
                    • Behemot
                      • 4845
                      • CZ
                      Didn't know how the resistor is used in there before, thanks
                      • ben7
                        Capaholic
                        • Jan 2011
                        • 4059
                        You are welcome
                        Muh-soggy-knee
                        • Agent24
                          I see dead caps
                          • Oct 2007
                          • 5037
                          • New Zealand
                          I got the thing open and figured out how to extract the board from the case...
                          I believe I've found the PFC diode, an I.R. HFA08TB60 - hidden behind the main capacitor, the PFC coil, and a little sub-board (The PFC control circuitry??) - see photo
                          There's a large (~1 watt size) resistor hidden under the primary-side heatsink just behind the HFA08TB60.
                          Coding seems to be Brown-Orange-Silver-Gold-Green which doesn't match up with any chart I know - what value do you suppose it should be?
                          EDIT: Totally missed another, larger resistor just below the PFC coil. Code is Orange-Blue-White-Gold-Green.
                          What should I be testing\checking the diode for?
                          -David VanHorn
                          • Behemot
                            • 4845
                            • CZ
                            Short or partial-open. Use diode tester, what does it read in both directions? If I am nto mistaken, ordinary diode should read arround 300 ohm minimum.
                            • Agent24
                              I see dead caps
                              • Oct 2007
                              • 5037
                              • New Zealand
                              Going by the datasheet this thing is a bit more interesting than an ordinary diode... that said...
                              Diode check on multimeter says nothing in reverse bias and "448" in forward bias.
                              Resistance test says infinite in reverse and 530k Ohm in forward.
                              A standard 1N4004 shows "587" on the diode test and 618k Ohm on resistance. (forward bias)
                              I do believe though that some faulty semiconductors will appear fine on a tester but fail in-circuit because of the higher working voltages. How to test that I am not sure.
                              The resistors both measure very low values:
                              * Brown-Orange-Silver-Gold-Green reads as 0.12 Ohm
                              * Orange-Blue-White-Gold-Green reads as 0.03 Ohm
                              -David VanHorn
                              • Behemot
                                • 4845
                                • CZ
                                It is more or less typical ultrafast to me…
                                The first resistor looks like non-standard 0,13 ohm. Silver seems to act like x0,01.
                                The second is 36.9 ohms, ± .5%, according to calculator.
                                • ben7
                                  Capaholic
                                  • Jan 2011
                                  • 4059
                                  I think the same. It's probably good.
                                  The BR-OR-SI-GD-GR resistor is supposed to be a 0.13 ohm 5%.
                                  The OR-BL-WT-GD-GR resistor is supposed to be a 36.9 ohm 0.5%.!?
                                  This will help with those odd 4 and 5 band resistors
                                  Muh-soggy-knee
                                  • Agent24
                                    I see dead caps
                                    • Oct 2007
                                    • 5037
                                    • New Zealand
                                    That second resistor (actually R14 on the board) is an oddly, very specific value... and shorted too?
                                    Maybe it's supposed to be 0.0369 ohms 0.5%... no, that probably makes even less sense.
                                    Even if that is the case.. where the heck do I get something that specific.. and WHY does it even need something that specific?
                                    Maybe it's time to draw out a schematic and try to figure out what that resistor does...
                                    Probably time to let you all in on a little secret... I actually have another Liberty 400 lying around... it was my friends and it blew a hole in a MOSFET. I didn't go any further than noticing that (and suspected the brown glue of death) but I guess I could have a look at its R14 resistor and see if it's the same.. of course it may well have had a similar problem, so that might be a waste of time.
                                    Aside from the resistor, could there be anything else that's easy to check?
                                    -David VanHorn
                                    • Behemot
                                      • 4845
                                      • CZ
                                      The marking should be right, we used two independent calculators. If you won't find exactly same, you can always buy 33ohm plus 3,9ohm in series, you should easily get these two.
                                      • ben7
                                        Capaholic
                                        • Jan 2011
                                        • 4059
                                        Try measuring the resistance of it the other way around.
                                        Also, what is this resistor connected to?
                                        Muh-soggy-knee
                                          Enermax Liberty ECO 400W [ELT400AWT] - from scraped to serviced
                                          by momaka
                                          Remember this pile of junk electronics I got last year? Well, that's where this Enermax Liberty ECO 400 Watt PSU came from. Like I mentioned, it had cut cables and many bulged caps on the DC output side. I stripped a few cables and did a quick temporary recap with whatever junk (but still reading OK) caps I could find, then performed a basic power test – the PSU passed. Thus, I knew I'd eventually go around to repairing it. One year later and we're here.
                                          First shown is the label below, so anyone reading can see what PSU we're dealing with here.
                                          02-15-2021, 01:05 AM
                                        • NConstantinou
                                          HP Z840 workstation power supply clicking noise
                                          by NConstantinou
                                          No power
                                          i have the above ps which i change the TOP258eg ic.
                                          Now i have power but is clicking and voltages are flutuating. I change all capacitors, i test all mosfets and all are ok.
                                          i am wondering what is the value of R901! I am getting 0.5Ohms. Is that correct!
                                          the colours look like R,R,W or silver,G Bl.
                                          Thanks...
                                          12-25-2024, 02:24 AM
                                        • tony359
                                          by tony359
                                          11-28-2023, 05:18 AM
                                        • MegaZAC
                                          Onkyo TX-SR805 noise in one channel
                                          by MegaZAC
                                          Surprisingly enough, this receiver doesn't have the DSP chip issue. The HDMI board does not get hot, and sound over HDMI works fine.
                                          Regardless of the input, the right channel has noise that is clearly noticeable even on average volume level. The only cases when there's no noise is when VCR input is selected (some tracks on the board are damaged, maybe that's why), or if HDMI input is selected but nothing plugged into it. In all other cases, even when no input is connected I still have the noise.
                                          There's some logic behind it. As soon as I select an input I get only left...
                                          04-23-2025, 10:09 PM
                                        • Sisko
                                          Onkyo-593 No power and now clicking sound
                                          by Sisko
                                          Hi all!!
                                          Ok just got a Onkyo SKW-593 sub woofer that has no power person told me that it smoked and that his GF let the volume full when she powered off the amp and when he came to turn it on the sub played but then suddenly smoke was coming out, didn't say from where. So opened it up and saw a resistor made of metal (pic) but can't see any writing on metal par so what ever was written on it was burnt. So I'm kinda stuck here with this. I did ask for a repair or schematics in the other group section and waiting for this but I hope someone here might lend me a hand to try and identify...
                                          10-03-2025, 02:18 PM
