Enermax Liberty ELT400AWT making clicking noise but still running
  • Agent24
    I see dead caps
    • Oct 2007
    • 5037
    • New Zealand
    Re: Enermax Liberty ELT400AWT making clicking noise but still running
    Same resistance both ways.
    With my Blue ESR meter I get 0.03 ohms. With my multimeter I get 0.3 ohms which makes sense since it can't measure below 0.1 ohm and besides, the test leads give 0.3 ohms when shorted anyway.
    The resistor is connected in series between the negative side output of the bridge rectifier and the rest of the PSU... I'll draw out a picture to make this a bit easier...
    EDIT: Same resistance (0.03 ohms) of the R14 resistor from the other PSU.
    -David VanHorn
    • Agent24
      I see dead caps
      • Oct 2007
      • 5037
      • New Zealand
      OK here's a drawing of part of the primary side
      There are more connections that what I have shown, of course. Namely the rest of the pins to that primary-side sub-board. But I think you get the idea...
      -David VanHorn
      • Behemot
        • 4845
        • CZ
        Well if the resistor is connected directly to the -, I guess it can't be 37 ohm, due to the high voltage and current it would vaporize…so guess the little resistance (0,03 ohm) is OK.
        • Agent24
          I see dead caps
          • Oct 2007
          • 5037
          • New Zealand
          It definitely goes in line with the negative rail, and it makes perfect sense it should be a low value as you say, but I don't understand then how the colour code is wrong. I've attached a photo of R14 and it clearly shows the gold band. Doesn't make sense.
          Also, I've edited the schematic, I forgot to add connections to the resistor and sub-board, which contains an LM393 and UCC3817 PFC controller IC.
          I guess R14 is basically a current shunt and helps with some kind of feedback to the PFC controller.
          -David VanHorn
          • ben7
            Capaholic
            • Jan 2011
            • 4059
            Wtf, its strange. orange = 3, blue = 6, white = 9, gold (multiplier) = 0.01, green = 20ppm. So I get 3.69 ohms
            What does it measure out of circuit?
            Muh-soggy-knee
            • Behemot
              • 4845
              • CZ
              #26
              Gold is x0,1, silver is for x0,01.
              • Agent24
                I see dead caps
                • Oct 2007
                • 5037
                • New Zealand
                #27
                0.03 Ohms is what it measures out of circuit. Sitting on the bench as per the photo is about as out of circuit as you can get
                It doesn't make sense to me either, but the numbers don't lie.
                PSU label says it can run from 100-240 volts and draws between 6 and 2.5 amps.
                The resistor is in series with the whole PSU. Assuming the best case of 2.5 Amps, if it were the 36.9 ohms as the chart suggests, it would have to dissipate at least 230 watts, which is clearly wrong. By the size it can probably do 4 watts maximum.
                -David VanHorn
                • rogfanther
                  • Jul 2006
                  • 458
                  • Brazil
                  #28
                  the third band seems silver to me, that would give 0.38 ohms, for a 2W resistor in the 230W consideration. Could that be ?
                  But that doesn´t explain why both your meters measure much lower ...
                  • Behemot
                    • 4845
                    • CZ
                    #29
                    Definitelly white, silver would reflect light…
                    • ben7
                      Capaholic
                      • Jan 2011
                      • 4059
                      I don't understand why the color coding would be different. But I agree, its not 39 something ohms xD
                      Ah, now I think I got 0.369 ohms, which is about what it reads.
                      Have you checked the PFC mosfets?
                      Muh-soggy-knee
                      • Behemot
                        • 4845
                        • CZ
                        #31
                        Man, how? You have something different every time. Clearly code is for 36,9 ohm.
                        • ben7
                          Capaholic
                          • Jan 2011
                          • 4059
                          How would a resistor go short circuit? :S
                          Muh-soggy-knee
                          • Behemot
                            • 4845
                            • CZ
                            #33
                            Error in Matrix?
                            • goodpsusearch
                              • Oct 2009
                              • 2850
                              • Greece
                              #34
                              :conspiracykeanu:
                              • Agent24
                                I see dead caps
                                • Oct 2007
                                • 5037
                                • New Zealand
                                #35
                                No, how should I do that?
                                Probably from a severe manufacturing defect. I don't see how a resistor would go short circuit by itself, unless it was overloaded and somehow melted or something.
                                A wire-wound one could if the insulation broke down, I suppose.
                                I would assume some physical evidence of the latter, and for the former it doesn't really explain why the resistors from both PSUs are the same value.
                                -David VanHorn
                                • Agent24
                                  I see dead caps
                                  • Oct 2007
                                  • 5037
                                  • New Zealand
                                  #36
                                  Didn't do anything with this since it wasn't a big priority, but I found some of that brown shit glue on the MOSFET legs and scraped it off, and blew some dust out of the PFC board.
                                  Decided to try again and was going to swap PFC controller board from the other PSU to see what happened, but this time no clicking.
                                  Maybe the glue was the problem, maybe the dust was full of moisture from winter... Will see what happens I guess.
                                  -David VanHorn
                                  • Phaihn
                                    • Jan 2009
                                    • 842
                                    is there s good solvent that you can use to remove that glue?
                                    would thermal paste remover work?
                                    My Computer.
                                    AMD APU A4-3300 2.5ghz 1mb cache
                                    Motherboard GigaByte GA-A75M-S2V
                                    Kingston HyperX Blue DDR3 8GB (2x4GB)
                                    SB Audigy 2 ZS [B800] Sound Card
                                    500GB WD Caviar® Blue™
                                    1 Terabyte WD Caviar® Black™
                                    2 Terabyte WD Caviar® Black™
                                    • Agent24
                                      I see dead caps
                                      • Oct 2007
                                      • 5037
                                      • New Zealand
                                      #38
                                      I don't know about solvent, didn't try. There wasn't very much on the leads, so was easy to remove with a knife.
                                      It was bridging on some (they used it to secure ferrite beads to the leads) - I removed the bridges and cleaned up the bits sticking out. Left the rest to keep the ferrite beads on.
                                      I have ripped bigger chunks of that glue off other things before, it seems to hold together better than it sticks to things (unless it's really baked), so probably knife\pliers might be better, less messy anyway.
                                      -David VanHorn
                                      • ben7
                                        Capaholic
                                        • Jan 2011
                                        • 4059
                                        You might have bumped a cold solder joint too.
                                        I guess the clicking sound could have been from the glue breaking down and arcing.
                                        Muh-soggy-knee
                                        • Agent24
                                          I see dead caps
                                          • Oct 2007
                                          • 5037
                                          • New Zealand
                                          #40
                                          Yeah, no idea at this point. Will investigate more if it happens again I suppose
                                          -David VanHorn
                                            Enermax Liberty ECO 400W [ELT400AWT] - from scraped to serviced
                                            by momaka
                                            Remember this pile of junk electronics I got last year? Well, that's where this Enermax Liberty ECO 400 Watt PSU came from. Like I mentioned, it had cut cables and many bulged caps on the DC output side. I stripped a few cables and did a quick temporary recap with whatever junk (but still reading OK) caps I could find, then performed a basic power test – the PSU passed. Thus, I knew I'd eventually go around to repairing it. One year later and we're here.
                                            First shown is the label below, so anyone reading can see what PSU we're dealing with here.
                                            02-15-2021, 01:05 AM
                                          • NConstantinou
                                            HP Z840 workstation power supply clicking noise
                                            by NConstantinou
                                            No power
                                            i have the above ps which i change the TOP258eg ic.
                                            Now i have power but is clicking and voltages are flutuating. I change all capacitors, i test all mosfets and all are ok.
                                            i am wondering what is the value of R901! I am getting 0.5Ohms. Is that correct!
                                            the colours look like R,R,W or silver,G Bl.
                                            Thanks...
                                            12-25-2024, 02:24 AM
                                          • tony359
                                            by tony359
                                            11-28-2023, 05:18 AM
                                          • MegaZAC
                                            Onkyo TX-SR805 noise in one channel
                                            by MegaZAC
                                            Surprisingly enough, this receiver doesn't have the DSP chip issue. The HDMI board does not get hot, and sound over HDMI works fine.
                                            Regardless of the input, the right channel has noise that is clearly noticeable even on average volume level. The only cases when there's no noise is when VCR input is selected (some tracks on the board are damaged, maybe that's why), or if HDMI input is selected but nothing plugged into it. In all other cases, even when no input is connected I still have the noise.
                                            There's some logic behind it. As soon as I select an input I get only left...
                                            04-23-2025, 10:09 PM
                                          • Sisko
                                            Onkyo-593 No power and now clicking sound
                                            by Sisko
                                            Hi all!!
                                            Ok just got a Onkyo SKW-593 sub woofer that has no power person told me that it smoked and that his GF let the volume full when she powered off the amp and when he came to turn it on the sub played but then suddenly smoke was coming out, didn't say from where. So opened it up and saw a resistor made of metal (pic) but can't see any writing on metal par so what ever was written on it was burnt. So I'm kinda stuck here with this. I did ask for a repair or schematics in the other group section and waiting for this but I hope someone here might lend me a hand to try and identify...
                                            10-03-2025, 02:18 PM
