Replacement suggestions
  • snoopsmsc
    • Apr 2012
    • 5
    I have an ML350 G5 with two bad caps. One is ruptured, and the other is pushing out the bottom, I think, because the cap was tilted on the motherboard, and when I tried to straighten it, it felt like it kind of broke loose, like the electrolyte had stuck between the board and the cap (not the cap leads, just the electrolyte dried between the cap and the PCB).
    Anyway, the caps in question are:
    • Rubycon MCZ 16v 1000uF 8mm D x 20 mm H, 2350 mA ripple, 12 mOhm ESR
    • Rubycon MCZ 16v 470uF 8mm D x 11.5 mmH, 1340 mA ripple, 21 mOhm ESR
    It seems like these caps are discontinued, so I'm looking for replacements. I've done a bit of research, and from what I've read, I should get caps with identical voltage and capacitance. For ripple and ESR, I should get equal or higher ripple, and equal or lesser ESR.
    I found one site listing the MCZ caps, saying that since they were discontinued, it suggested the following replacements:
    • Nichicon HN Series 16v 1000uF 8mmD x 20mmH, 2220 mA ripple, 12 mOhm ESR
    • Nichicon HN Series 16v 470uF 8mmD x 11.5mmH, 1300 mA ripple, 21 mOhm ESR
    However, upon looking through the Nichicon catalog, I found the HZ series, which has:
    • Nichicon HZ 16v 1000uF 8mm x 20mm, 2880 mA ripple, 9 mOhm ESR
    • Nichicon HZ 16v 470uF is 10mmD x 12.5 mmH - better specs, but physically too big
    On the 1000 uF cap, should I go with the Nichicon HZ or HN? For the general rule of getting a greater ripple rating and lesser ESR, are there limits to this rule? In other words, if I took that idea to the extreme, could it cause problems?
    Also, on the 470uF cap, is the Nichicon replacement, with 1300 mA ripple (vs original of 1340) going to be close enough?
    At this point, I am inclined to get:
    • Nichicon HZ 16v 1000uF 8mm x 20 mm, 2880 mA ripple, 9 mOhm ESR
    • Nichicon HN 16v 470uF 8mm x 11.5 mm, 1300 mA ripple, 21 mOhm ESR
    Or should I go with both from the HN series?
    Also, is there a difference between impedence and ESR?
    Am I on the right track here, or would you all recommend something else?
    This is going back into production, and can't really afford a mistake on this.
    Thanks,
    Monty
  • mariushm
    • May 2011
    • 3799
    Re: Replacement suggestions
    Either HN or HZ will work just fine.
    But chances are it's not just those 2 capacitors dead or dying... post a picture of the board if possible or search the internet for a picture that looks like your board and post it here.
    We might be able to suggest what should also be replaced even if it doesn't look bad.
    • snoopsmsc
      • Apr 2012
      • 5
      Sounds good. Thanks for the advice.
      As for yet-to-fail caps, I am trying to decide whether I should replace them. How hard is it? I have a decent amount of soldering experience, though not much on PCBs - stuff like patching wires, reattaching a wire pulled from a PCB. I would say on these items, I make pretty clean joints, so I don't expect to have TOO much problem, but...
      I guess my thinking on the matter is the fewer components I replace, the lower the likelihood will be that I screw it up.
      Perhaps I should practice on a few dead, junk boards before I go at it...
      Anyway, couldn't find a decent picture online. I'll post a pic or two here in a bit.
      Oh, also... Thanks for the help.
      • snoopsmsc
        • Apr 2012
        • 5
        Or ten... I opted for verbosity on the pictures. People complain my emails are the same way (which seems to be supported by my original post).
        Anyway, the two caps I've already mentioned are circled in red in some of the photos.
        Is there any way to know what role the capacitors play? I guess proximity is one clue... Any others?
        Let me know what you think.
        And again, thanks.
        Edit: One more thing - is there a better choice between the HN and HZ, or is the distinction irrelavent as long as the specs are met?
        • selldoor
          Slow Learner
          • Dec 2010
          • 7870
          Just in case it is missed, if any electrolyte has spilled out you should clean it all off as it
          will eventually corrode any metal its on.
          • snoopsmsc
            • Apr 2012
            • 5
            Duly noted.
            Thanks!
            • noox
              • May 2015
              • 1
              • Russia
              Good day! Subject old but it happened a few days ago, a server hp ml350 g5 not start, I changed the capacitors startonul server.
              Only strongly heated chips. In the photo below after 5 minutes of operation. And also heated Replaced kondensaror near a radiator near pamyati.Temperaturu took it tester MASTECH MY64
              All kondnensatory looked in all the blocks, for swelling.
              Prishol kaput motherboard, or even so there is still a chance it still work?
              • techweenie
                • Jun 2015
                • 10
                I happen to have a ML350 G5 that I have already replaced all the caps on. I used Nichicon HN series and the three that sit above the ram have failed again. I'm currently researching poly alternatives for that location. I have all 8 ram slots populated and that part of the board gets HOT. I did the first repair probably two years ago and it has been running 24/7 ever since.
                • metaltatorchip
                  • Jun 2015
                  • 3
                  Reading this post, what is the best thing to use to clean the electrolytic off the board? Rubbing alcohal?
                    • 31278
                    IPA - IsoPropyl Alcahol.
                    • DrewPhillips
                      Capacitor Diarrhea - Nichicon PL Series
                      by DrewPhillips
                      Hello All, I have on the bench a couple of PSU's which have some failed Nichicon PL series caps. They didn't "puke" their guts through the top, but instead "diarrhea'ed" corrosive brown electrolyte through the bottom, down the legs and onto the board. On one cap, the electrolyte rotted the cap right off the board leaving 2 little stubs, and also corroded a trace on the foil side.
                      The PSU's are Power-One MAP series and are ringing-choke topology. The semiconductors have date codes in 1993. The PSU's were used in a commercial application, fan-cooled. They had failed...
                      03-02-2025, 10:18 PM
                    • Perry Babin
                      Lowest ESR capacitors, preferably liquid electrolytics but polymer also welcome
                      by Perry Babin
                      I'm looking for suggestions for electrolytics that are 10mm diameter and up to 25mm tall, through-hole radial capacitors with 5mm lead spacing. The value needs to be in the range of 330uF to 470uF. I typically use 35v caps due to their lower ESR vs 16v caps. Currently, the Panasonic FC is being used but the FM series is under consideration.
                      This is for the primary side of a switching power supply in a car audio amplifier.
                      Is there a way to calculate power dissipation in a capacitor to predict which will operate at a lower temperature? For example, a 470uF may have a...
                      10-16-2025, 05:20 AM
                    • withalligators
                      Looking for best replacements for Capxons, but can't find data sheets
                      by withalligators
                      Recapping the power supply board for a Samsung 305T monitor, everything is Capxon except 2 Rubycons. I can't find data sheets matching these online, so don't know what ripple numbers, impedence, etc, to look for. There are a few different looking GL series data sheet PDFs, but the listing that matches the capacitance and voltage is a much bigger case size. I've narrowed down selections with lead spacing and case diameter, and what's in stock at Digi-key
                      1 x Capxon 1000uf35v GL C720(is this a part number or batch number, can't find it anywhere) 105c
                      1 x Capxon 1000uf35v...
                      03-25-2022, 02:30 PM
                    • nick3092
                      Mid/late 80's Nichicon Yellow Caps
                      by nick3092
                      I recently acquired a set of Bose Roomate speakers from the mid to late 80's. Basically the right speaker cabinet is completely passive, and the left one has the power transformer and amplifier circuit in it. Out of curiosity, I opened it up to see what the circuit looked like. Looks like they used all Nichicon VX (2x 4700uF/16v for smoothing off the bridge rectifier), a couple random Nichicon SE series sprinkled on the board, and what really caught my eye - 2 yellow sleeved Nichicon caps (both 1uF/50v with no real series marking. Below are pictures of the caps. The only thing not shown in these...
                      08-28-2022, 03:56 PM
                    • chth96
                      Is it no harm to replace with capacitor without ripple current rating?
                      by chth96
                      When I tried to repair LG 29 inch CRT TV, I found that the ESR value of samyoung SMS capacitor(160v 2.2uf), which is very close to D1879 transistor, is 6 ohm.
                      Judging from above ESR Meter Table,I think It is necessary to replace this sms capacitor.So I visited local electronics shop,and I purchased 160v 2.2uf rubycon YK capacitor.
                      But when I browse through rubycon YK datasheet,I found that there is no ripple current rating for 160v 2.2uf specification. But On the contrary, I found 39 mA ripple current rating for 160v 2.2uf SMS capacitor.
                      Rubycon YK DataSheet (b...
                      04-19-2024, 05:19 AM
