LG 42PC1D Y-sus?
  • caspermccormack
    • Mar 2012
    • 112
    • Ireland
    LG 42PC1D Y-sus?
    Well I taught my luck was in getting a 42PC1D that doesn't work for €30 thinking that the boards my be compatable with my 50PC1D tv but they are different. So I may as well try get this one sorted while I am waiting on parts for the 50 inch.
    Stripped it down and found a blown fuse on the y-sus board, replaced it and still shuts down after 5 secounds. The tv will power up if the y-sus is disconnected from the PSU, I have done the AC Decect job that Tom66 has posted here before but still no joy. What should I look for on the Y board now or is there something I'm missing?
    Cheers.
    Re: LG 42PC1D Y-sus?
    Cheers.
    Check the hybrid's Vs to GND for shorts. Check from both ends of fuse to case you should see >500 ohms.
    • caspermccormack
      • Mar 2012
      • 112
      • Ireland
      I have the board out, one side of the fuse is OL. and the other is 000.3
      • caspermccormack
        • Mar 2012
        • 112
        • Ireland
        Checking the hybrid, I am getting beebs back from the DMM between GND, SUS OUT, ER UP, ER DN, and VS.
          You need a new one: http://www.ebay.co.uk/sch/i.html?_sa...o&LH_PrefLoc=2
          These are difficult to replace: I've never had the pleasure, thankfully.
          • caspermccormack
            • Mar 2012
            • 112
            • Ireland
            I have fun having a go!!!!
            • Vizor
              • Nov 2011
              • 215
              i broke a board trying to get one of those out its a pain
              • caspermccormack
                • Mar 2012
                • 112
                • Ireland
                Got it out, took a while with the heatsink, but out and the board looks fine.
                I can see some damage to the hybrid I'll stick up some photos.
                • cadiman
                  • Mar 2010
                  • 397
                  I drill holes in the board now to get at the screws to remove the heat sink.
                  • caspermccormack
                    • Mar 2012
                    • 112
                    • Ireland
                    That was my next trick
                    • alltronix
                      • Apr 2012
                      • 2
                      I cut slot in the end of the screws that hold the heat sink on and screw them out that way. You dont drill through any traces that way. To remove the old IC, I use a dremell tool to cut all the legs off, then pull each leg out with a hot iron. You never damage a trace that way. The ICs are available on ebay.
                      • PowerAmpFreak
                        • 982
                        • Sweden
                        One word of caution; be sure to check that supply voltage to the IPM is stable +15V (or +18V) and of correct level. A bad supply could cause the new IPM to blow. This is because the supply is used for all gate drive circuits in the IPM and a too low gate drive voltage could cause too high power dissipation in the IPM power FET's.
                        Sometimes I use to add a 47uF cap directly between +15V supply and GND to improve ripple rejection close to the IPM.
                        I have managed to replace several IPM's without having to drill or do any special tricks. Having a good soldering station is all what's needed.
                        • cadiman
                          • Mar 2010
                          • 397
                          The traces are 1" wide so it`s really not an issue. I do this to inspect solder joints directly under the chip after soldering and you need alot less heat to remove and install the ipms.
                          I would like to have a soldering station.
                          I have a wife instead and I am lucky she lets me do anything that doesn`t involve her.
                          • PowerAmpFreak
                            • 982
                            • Sweden
                            A little bit off topic, but it really is possible to have both a wife AND a soldering station , but I understand exactly what you mean - it's not popular business to not involve them
                            • caspermccormack
                              • Mar 2012
                              • 112
                              • Ireland
                              Ah, the fun police or as I call her, wife!
                              • tibimakai
                                • Jan 2012
                                • 3680
                                Sell some TVs and hand over her some money and then you can do your hobby. I even involve her in what I'm doing, at a degree.
                                • cashkennedy
                                  • Aug 2011
                                  • 668
                                  I wouldnt mind having someone to hold down the reset buttons on this damn sharp im working on... granted i think it would be very hard to find a girl willing to sit there doing it for 2 hours while i test voltages.
                                  Fixed so far 12 lcd's , 1 plasmas, 5 monitors, 0 dlp's (plan to keep the dlps at 0). and 3 atx power supplies, and 2 motherboards.
                                  • caspermccormack
                                    • Mar 2012
                                    • 112
                                    • Ireland
                                    New part in, BINGO!!!
                                    Thanks for all the help!!
                                    Now back to the 50" fingers crossed!
                                    • PlasMatt
                                      LG 60PV450 Possible Bad YSUS Need help confirming Diagnosis
                                      by PlasMatt
                                      I have an LG plasma that after reading through a bunch of posts and doing some testing I believe has a bad YSUS board. The problem is that that doesn't make sense to me for some of the symptoms. The problem started yesterday. While watching a movie the TV just shut down like I pressed power. I have it hooked to a PC and use RS232 to turn it off and on so I thought maybe something had glitched there. I turned it back on and finished the movie with no problems. The same thing happened today so I checked logs to see if something in the control glitched and sent an off command but it didn't, After...
                                      09-20-2025, 06:50 PM
                                    • legg
                                      LG 42PC3 buffer output doesn't follow YSUS
                                      by legg
                                      LG42PC3D -UD originally with green lamp but no display or audio.
                                      Owner says was working, then went 'pop'.
                                      All 5V caps bulging. replaced.
                                      All PSU output voltages within spec but -Vy is low on YSUS.
                                      One of three parallel fets between SUS_OUT and SUS_DN is zenering,
                                      eventually shorts DG. Replaced all 3 - -Vy now OK.
                                      Y scan buffer test point does not follow YSUS output below -50V
                                      Note: This unit seems to expect YSUS output to park at -Vy in between
                                      drive signal pattern periods. A replacement drive signal board confirms this....
                                      11-18-2021, 11:49 AM
                                    • Truncatedhose
                                      Help repair this relic? Philips 42PF7220A/37, pulsing buzz from YSUS
                                      by Truncatedhose
                                      Greetings all!
                                      Originally this set had the usual messed up video symptoms such as: horizontal lines, weak, grainy video, bottom and top of picture differ in intensity of problem. It also seemed to slow to turn on or show the messed up picture.
                                      Seemed like must be YScan/buffer board failure. Ordered buffer boards from my distributor which were supposed to be original/new and also from another distributor, I ordered the YSUS because I wanted to replace it for preventative maintenance. (also, the YSUS had a bulged cap, so there was even more reason to suspect it could...
                                      07-04-2018, 10:59 AM
                                    • zwarder
                                      eax61319402 50PJ350 YSUS
                                      by zwarder
                                      Hi
                                      Had shorted YSUS
                                      Q24 RPJ63F3
                                      C726 cap
                                      Q11 K3667
                                      R528 & R529 2.2 ohm
                                      replaced all of these but still trips psu VS & VA are a bit low when ysus disconnected. IC301 does look a bit burnt however
                                      ZSUS is also good as far as I can tell
                                      Anyone could help me out on this one
                                      10-23-2023, 08:11 AM
                                    • maces
                                      LG 60PH6608 YSUS repair
                                      by maces
                                      Hello all,
                                      I have a problem with my LG 60PH6608. The TV is only clicking and doesn't get started.
                                      I checked the power supply and measured that the 200V is shorted at the YSUS board.
                                      All IGBTs, the MOSFET K8A60DA and the diode D603 are shorten.
                                      So I replaced the parts. I checked the further parts for shorts and I was pretty sure that there is no further problem on the board.
                                      So I plugged it in. Directly, resistor R251 (2,2 Ohm) blowed out with a little spark. Immediately I disconnected the TV from supply.
                                      I checked the replaced parts (IGBTs, MOSFET...
                                      12-11-2022, 02:21 AM
