LG 60PH6608 YSUS repair
  • maces
    • Dec 2022
    • 11
    Hello all,
    I have a problem with my LG 60PH6608. The TV is only clicking and doesn't get started.
    I checked the power supply and measured that the 200V is shorted at the YSUS board.
    All IGBTs, the MOSFET K8A60DA and the diode D603 are shorten.
    So I replaced the parts. I checked the further parts for shorts and I was pretty sure that there is no further problem on the board.
    So I plugged it in. Directly, resistor R251 (2,2 Ohm) blowed out with a little spark. Immediately I disconnected the TV from supply.
    I checked the replaced parts (IGBTs, MOSFET K8A60DA and the diode D603), but they all seem to be functional. I'm not sure if I should replace the resistor and try it again. I thing there is a high chance to fail again or to damage further parts. I have no schematic found to check the function of R251.
    I would be happy about tipps how to go on.
    -Maces
  • nomoresonys
    • 12235
    • U.S.
    Re: LG 60PH6608 YSUS repair
    trace that resistor back to the most likely suspect.
    • nomoresonys
      • 12235
      • U.S.
      need to be vigilant in testing, test the buffer boards for shorts, check youtube, theres some videos there.
      • nomoresonys
        • 12235
        • U.S.
        example there, find the ground and test them, if they are ok thats good you can eliminate them and concentrate on the Y sus, the reason for testing them is if they are bad they can blow your Y sus and vise versa, thats just one of the reasons I hate plasmas, its SO easy for one bad board to take out a connected good board, happens in other types of tvs too of course but not nearly as often: https://www.youtube.com/watch?v=V6hxf9sARMY
        • maces
          • Dec 2022
          • 11
          Thank you for the quick and helpful answer. I checked the buffer board for shorts, like it is shown in the video. There is no short, so I assume that the buffer board is OK.
          Then I replaced the resistor. I turned the TV on and measured the current trough. It is about 50mA. So I suspect that the resistor was already damaged before.
          Now the TV turns on, but there is no picture, only the "backlight" turns on.
          From the YSUS board comes a noise, a kind of buzzing. I cannot localize it to a concrete part.
          • R_J
            • Jun 2012
            • 9582
            Note: Plasma TV's do not have a backlight, if the panel is lighting up but has no video, try this:
            with the tv off, the control board has two test points labeled EXT_AUTO_GEN (near P222) short these two points and plug in the tv, see if you have test patters on screen, If not, unplug tv, disconnect P231 from main board, short the test points and plug in the tv
            A buzzing noise from the y-sus board is normal
            • maces
              • Dec 2022
              • 11
              Thank you for the usful tip. The test image was good.
              Then I found the error by looking at the mainboard. There was a bad connection between power supply board and mainboard - the connector was not plugged in correctly. Now the TV is running since two hours.
              But now, I have the issue that the image is "noisy".
              Theres a kind of red noise I can see when the screen is white. It is not evenly distributed on the image. I tried to make a short video:
              https://www.dropbox.com/s/6fdn0a64u5...83337.mp4?dl=0
              • R_J
                • Jun 2012
                • 9582
                Make sure the voltages for VS and VA are correct, Also check the VSC voltage on the Ysus board, it is measured across the two points marked -VSC+, the correct values for the voltage are on a sticker on the panel. If the voltages are correct, or very close, you can try increasing or decreasing the VS voltage ay a few volts to see if the image gets better, Then Mark the positions of the SETUP and SETDN controls and slightly adjust each one while watching the picture and adjust for the lest amount of specks in the white and black areas, it will likely never go away completely. It's best to do the adjustments after the panel as been on for a while.
                Many of these LG plasmas usually required a software update to the control board to fix this issue, also this can happen as the panel ages.
                You can also check and/or re-solder the connections on the large coils on the Y-sus and z-sus boards, then make sure that all the ground screws are in place and fairly tight.
                • maces
                  • Dec 2022
                  • 11
                  VS and VA are correct.
                  VS is measured with 203V and VA with 55V, as noted on a sticker on the panel.
                  For VSC I cannot find a reference. The measured voltage across the two points is 149V. Is this a correct value for VSC?
                  • maces
                    • Dec 2022
                    • 11
                    I tried to increase the VS voltage up to 208V. This causes no positive effect, so I readjusted it to 203V.
                    The only positive effect I can see is if I turn the SETUP potentiometer complete to the left. Then the noise is nearly complete gone. The white gets a little "blue-gray" but it is better then the noise.
                    But I have doubts if I can leave the poti complete to the left in contineus operation.
                    • R_J
                      • Jun 2012
                      • 9582
                      below the Vs and Va voltages on the label it usually lists the other voltages like VSC
                      Post a picture of the label. I believe the VSC voltage is the third one listed
                      It might read N.A./ -180 / 150/ N.A./ 105 in this case 150 is the VSC.
                      Normally the Setup and Setdn are adjusted using a scope and adjusting for a proper waveform
                      You won't get it perfect so adjust it for minimum speckle and be done
                      • PlasMatt
                        LG 60PV450 Possible Bad YSUS Need help confirming Diagnosis
                        by PlasMatt
                        I have an LG plasma that after reading through a bunch of posts and doing some testing I believe has a bad YSUS board. The problem is that that doesn't make sense to me for some of the symptoms. The problem started yesterday. While watching a movie the TV just shut down like I pressed power. I have it hooked to a PC and use RS232 to turn it off and on so I thought maybe something had glitched there. I turned it back on and finished the movie with no problems. The same thing happened today so I checked logs to see if something in the control glitched and sent an off command but it didn't, After...
                        Yesterday, 06:50 PM
                      • Mark D
                        Samsung UN65JU67ODFXZA Version TD01 Schematic and Parts List
                        by Mark D
                        The TV is a Samsung UN65JU67ODFXZA Version TD01. I replaced the power source board and the TV is now working, but I decided to try and troubleshoot the old board to fix at the component level. Trying to get a schematic and a parts list has proven to be an issue. Trying on my own, I can't tell you how many times my Norton security has flagged sites as "malicious". I ordered a service manual from ServiceManuals.net, paid $16.99 and got 66 pages of everything BUT schematics and component parts list! Can anyone steer me in the right direction? Some of the surface mounted component parts...
                        10-29-2024, 03:15 PM
                      • legg
                        LG 42PC3 buffer output doesn't follow YSUS
                        by legg
                        LG42PC3D -UD originally with green lamp but no display or audio.
                        Owner says was working, then went 'pop'.
                        All 5V caps bulging. replaced.
                        All PSU output voltages within spec but -Vy is low on YSUS.
                        One of three parallel fets between SUS_OUT and SUS_DN is zenering,
                        eventually shorts DG. Replaced all 3 - -Vy now OK.
                        Y scan buffer test point does not follow YSUS output below -50V
                        Note: This unit seems to expect YSUS output to park at -Vy in between
                        drive signal pattern periods. A replacement drive signal board confirms this....
                        11-18-2021, 11:49 AM
                      • 2elw
                        SVOD4 PCB pictures + parts
                        by 2elw
                        Hey, I find it very absurd that the SVOD4 costs so much and has zero documentation. I had no other choice than to buy it to unlock ECs, if there was any documentation or firmware avalible I could've made it or something simmilar. Anyways here are some of the most important parts:
                        STM32H723VGT6 MCU - It's a microcontroller by STMicroelectronics and its the whole brain of the SVOD4. It has flash memory for the firmware which can be updated by the SVOD4 program. Its also powered by the AMS117 which converts 5v into 3.3V. 7€ on AliExpress.
                        GW1N-UV9UG169C6/I5 FPGA - Its a...
                        07-04-2025, 12:23 PM
                      • SurrealMustard
                        What parts can be salvaged from a plasma with a damaged display panel?
                        by SurrealMustard
                        I recently found myself the proud owner of a later-model Samsung plasma (the PN59D7000 for those keeping score at home) whose panel was, unfortunately, damaged in transport. I'm now preparing to part it out, but am curious as to whether or not any damage would have come to any of the components by attempting to power it up with the panel being broken. I read in one Avsforum thread (for whatever that's worth 😂) that the "scan driver boards" (by which I assume he means buffer boards) could be impacted by doing so. Is that actually the case? If so, since I don't intend on selling bad...
                        03-09-2025, 08:29 PM
