Dell E193FPc - 2 Seconds to Black
  • jayoung
    • May 2011
    • 172
    I received a Dell E193FPc that has a 2 seconds to black issue. The top two ccfls light, the bottom two do not light. With four known good ccfls, the result is the same. All of the capacitors appear to be in good shape, I plan to replace them no matter what (1 - 33uf 50V, 2 - 150uf 25V, 2 - 470uf 25V, 1 - 1000uf 16V, and 1 - 1000uf 25V). There are 4 C5706 transistors with the following measurements in circuit. Q209 and Q210 run the top ccfls, Q211 and Q212 run the bottom ccfls.
    (black probe-red probe-result(ohms))
    Q209 B-C-NO READING, B-E-NO READING, C-E-80.5, C-B-NO READING, E-B-NO READING, E-C-NO READING
    Q210 B-C-NO READING, B-E-NO READING, C-E-80.9, C-B-NO READING, E-B-NO READING, E-C-NO READING
    Q211 B-C-NO READING, B-E-0, C-E-75.4, C-B-73.5, E-B-0, E-C-NO READING
    Q212 B-C-NO READING, B-E-0, C-E-NO READING, C-B-NO READING, E-B-0, E-C-NO READING
    Am I correct in saying Q211 and Q212 appear to be shorted? I can take these out of circuit and test if needed. These are the ones working with the ccfls that are not working. From what I have searched for in the forums, it appears that cracked solder joints to the transformers can cause the transistors to short out. I plan to resolder both transformers and replace all four C5706 with C5707. I have the 4 C5707 transistors now, would it be ok to replace the 4 transistors and then check the results before I replace the capacitors when I get them ordered and shipped to me?
    Is there anything else that I should be checking and/or replacing?
    Thanks in advance for all the help.
  • smason
    • 1652
    Re: Dell E193FPc - 2 Seconds to Black
    Sounds like you have this well-started.
    Yes it sounds like the 2 transistors are shorted, but just so we're clear, please define "no reading" and 0. When you touch both probes together do you actually get 0?
    I'd say it's safe to resolder the transformers, and replace the 5707s and test before the caps arrive. I'd also test the other transistors near the 5706s, are there any FETs nearby?
    • smason
      • 1652
      Oops guess I could have looked at the photos.... duh.
      You might want to get pinout info on Q204 and Q203 and check them, as well as Q 205 206 207 and 208 they may be involved in the circuit as well. Too tired to try to trace it at the moment.
      • jetadm123
        • 2169
        Excluding the large 450V cap, I count 8 small caps. You listed 7 small caps. Did you miss one?
        Also, re-solder the the two blue caps between Q209-Q212.
        • jayoung
          • May 2011
          • 172
          No reading - over the limit - setting of 200 ohms
          0 - just like the two probes were touching (actually about 0.3 ohms)
          Q203 and Q204 are BD5N18 - I cannot find the info that I can check - it has 4 pins on each side
          Q205 B-C-3950, B-E-8060, C-E-4190, C-B-3950, E-B-8050, E-C-4190
          Q206 B-C-3950, B-E-8010, C-E-4140, C-B-3950, E-B-8000, E-C-4140
          Q207 B-C-7170, B-E-8020, C-E-38300, C-B-38500, E-B-8030, E-C-8090
          Q208 B-C-7200, B-E-7960, C-E-38600, C-B-39400, E-B-7980, E-C-8030
          I did not list the start-up cap (?) 22uf 50V
          Should I do any checks on the transformers? One of them obviously works since two of the 4 bulbs light initially.
          • retiredcaps
            • Apr 2010
            • 9271
            A multimeter ALWAYS gives a reading. "1" IS a reading. "1" on the left hand side of the multimeter means it is out of range for the chosen range. So if your multimeter is set to 200 ohms, it means the reading is greater than 200 ohms.
            When testing for a shorted component, readings less than 30 ohms suggest the component might be shorted. If the multimeter shows "1" (i.e. ohmns > 200), then we know it is likely not shorted.
            When you report readings, we always want the actual reading. The difference between 0 and 0.3 ohms is significant.
            Anytime you report a multimeter reading, always include the measurement unit. We can only guess at what unit of measurement is above. If it is ohms, then the above components are likely not shorted.
            This small startup cap plays an important role in the SMPS startup process and can often fail without any signs of bloating.
            Yes. See
            https://www.badcaps.net/forum/showpo...1&postcount=14
            PS. Excellent clear focused pictures.
            --- begin sig file ---
            --- end sig file ---
            • jayoung
              • May 2011
              • 172
              Originally posted by retiredcaps
              I'm new to testing electronics and don't quite understand the measuring of the transformer. The youtube video in that link no longer works. In the link, it states "Number the pins on the transformers anyway you like." I have 2 pins on one side and 7 pins on the other side of the 80LL15T-7-YS 0523 transformer. Do I number from 1 to 9 or just 1 to 7 on the one side? The only information that I could find on the pin out of the transformer was a photobucket image stating "250 Ohms on the secondary side winding (pin 7 and 9)" I get 250 ohms PT202 and 249 ohms on PT201. Numbering from 1 - 9 and testing would give 36 readings. Is this correct?
              I just don't want to replace the C5707's and then have them short out because of a problem with something else.
              Thanks again in advance for the quick and knowledgeable responses.
              • PlainBill
                • Feb 2009
                • 7034
                You are over thinking the problem. You have already tested the transformers and they are probably good (249 vs 250 ohms).
                In essence, a transformer can be thought of as a black (or yellow) box with a number of pins. Some of the pins aren't connected to anything. Some are connected to another pin by a short coil of heavy wire (sometimes three pins may be connected by two coils of wire). And two pins will be connected by a long coil of very fine wire. That is the secondary, and they are prone to failure - either from shorting or the wire breaking. (Some transformers have two or more secondaries).
                By measuring the resistance from pin 1 to pins 2-9, from pin 2 to pins 3-9, pin 3 to 4-9, etc you can identify which pins are connected together, which is the secondary, and if the secondaries match. On inverters the primary (or primaries) will have very low resistance - less than an ohm.
                PlainBill
                • jayoung
                  • May 2011
                  • 172
                  Thanks for all the replies. Hopefully this weekend I will have time to be able to replace the 4 - C5707s and re-solder the two transformers and the two blue caps between Q209-Q212. I will check the results and replace the 8 capacitors when they arrive. I will update when that is complete. Thanks again to everyone.
                  • jayoung
                    • May 2011
                    • 172
                    I finally got the time to work on this monitor again this evening and wanted to give an update to it's status. I replaced all 8 of the caps and all four of the C5707s. I re-soldered both transformers and the two ceramic capacitors. With everything back together, I am writing this post using the monitor while I test it for a few hours. Thanks to everyone on this forum and especially to the ones that replied to my original post (smason, jetadm123, retiredcaps, and PlainBill).
                    • pm03
                      • Jul 2011
                      • 1
                      nice job!
                      • niranjanmondal
                        • Jul 2011
                        • 1
                        Man I am very much Upset My Lcd is not working properly.
                        the same 3 seconds issue of Benq Lcd Moniter.
                        _______________________________________
                        I think the picofuse is blown off ( not sure )
                        Because last time when I was facebooking My monter screen went extreme Bright and truned off .
                        Then I re stated my pc and seen the bios for 3 seconds and Microsoft logo for 3 seconds
                        then no response from the lcd.
                        when i pressed the power button on\off the screen was normal visible but goes off again after 3 seconds.
                        There any Idea what posibly had happned ( picofuse )
                        • PlainBill
                          • Feb 2009
                          • 7034
                          The picofuse is NOT blown; if it were you wouldn't be getting any backlights. That is elementary.
                          The usual problem is the solder joints on the transformers crack. This causes the transistors driving the transformers to short. You may have a different problem.
                          Disconnect all the CCFL leads except the one to CON201. Turn on the monitor. Do the backlights turn on for two seconds?
                          Disconnect the CCFL lead from CON201 and reconnect the one to CON202. Turn on the monitor. Do the backlights turn on for two seconds?
                          Disconnect the CCFL lead from CON202 and reconnect the one to CON203. Turn on the monitor. Do the backlights turn on for two seconds?
                          Disconnect the CCFL lead from CON203 and reconnect the one to CON204. Turn on the monitor. Do the backlights turn on for two seconds?
                          If all CCFLs but one turn on, you have a bad CCFL or CCFL wiring.
                          If both CCFLs in a pair turn on, while neither in the other pair turn on, you have the usual problem. Replace Q203 / Q204 on the side that is not lighting.
                          Check Q209 / Q210 or Q211 / Q212 on the 'dead' side for shorts. If any are shorted, replace all.
                          Resolder all pins on PT201 and PT202.
                          Replace all electrolytic caps except C904
                          PlainBill
                          • SuperAman
                            PS5 HDMI port diode reading?
                            by SuperAman
                            I did an hdmi port repair for a PS5 and I lost the small diode z71 SOD923 on the back of the port. I did a trace repair for pin 19 of the port as well. Without the diode I get no display at all. I tried replacing the diode twice but after I get flux on it the marking comes off so I can't tell if I have it on the right orientation. When I measure I get a reading of 1(open) and 923 in diode mode. Is 923 a normal reading for these and also which side should the reading be with regards to the arrow on the board?...
                            02-03-2024, 10:16 PM
                          • Fuzzy Fix
                            0.00 ESR reading on a capacitor
                            by Fuzzy Fix
                            Howdy all I have a 90uF Capacitor 200/275 VRMS and measured the ESR . Reading says 00.3 Ohms and about 1/2 a second later 00,0 and says low ESR (Really No Kidding).
                            I have checked it on the multimeter and reading is 94.7uF well within soec as ir has a 25% tolerance on it.
                            Can anyone advise me is this capacitor likely to fail in the near future or still good to use.
                            07-26-2024, 12:05 AM
                          • kalilinux25
                            no 3v and 5v section voltage reading
                            by kalilinux25
                            Hi my board is HUSK MB 11309-248.4TU05.021
                            The board is plugg and consuming 13 milliamp
                            measuring the 3v coil no reading and the 5v coil no reading
                            Ive measure the pins in PU4103 ( RT8223M)
                            1- NO READING
                            2- NO READING
                            3- 4.4V
                            4-NO READING
                            5- NO RADING
                            6- NO RADING
                            7-3.3V
                            8- 5V
                            9-19V
                            10- NO RADING
                            11-3.3V
                            12- 3V
                            13-
                            14
                            15
                            16-4.4V
                            17-3.3V
                            18- NO READ
                            19-5V
                            20- NO READING
                            21-2V
                            22-2V
                            23-NO READING
                            24- 5V
                            01-27-2020, 03:01 AM
                          • Thoa
                            Dell Latitude 5440 IDB40 LA-M401P reading the Bios-WSON8 UC2
                            by Thoa
                            Hello Community...
                            I am totaly disappointed, cause i bought a used Dell Latitude 5440 with a cracked display. I ve spend another 50 Euros for the new screen and it does his job very well. Then I reallized that a Bios-Passwort is set. First I bought the CH341A black edition with the clamp and was confidence, that it will do its job, realizing that this does not work. So I decided to buy a pogo-pin-tool to read the UC2 first of all (nothing tried on UC6 Yet). The outcome was very random when reading the WSON 8x6, so I decided to buy the XGecu T48, but it is the same. No reliable data....
                            08-12-2025, 04:05 PM
                          • camisao
                            APC Smart-UPS 3000 XL (SUA3000XLI) not reading voltages well
                            by camisao
                            Hello there,
                            I have a issue with a tower UPS 3000XL with also an external battery tower that has almost new batteries and very little use.
                            A week ago it started entering boost mode because the read line voltage was below 210VAC, when it was in fact near 225 VAC.
                            The battery voltage was also low (48 or 49), when in fact the batteries are fully charged to 55.1 VDC.
                            I opened it up up, cleaned and tried a reset.
                            I updated lower transfer voltage to 196 with apctest and then used the serial port to adjust the configuration with a terminal in Prog mode...
                            04-03-2025, 07:12 AM
