Need help deciding what to replace my caps on my motherboard with.
  • arwinbones
    • 8
    I have 7 G-Luxon 6.3 1500uf capacitors that need to be replaced and was wondering what kind should I replace them with. They came off a AM35 Rev. A3 motherboard. And I've had a hard time finding any G-Luxon capacitors to match except for ones I have to order from China and Japan.
  • PCBONEZ
    Grumpy Old Fart
    • Aug 2005
    • 10661
    Re: Need help deciding what to replace my caps on my motherboard with.
    G-Luxon are junk. - You want a good brand with the same or better ratings for ESR/Ripple.
    You should replace all the G-Luxon 6mm Diameter and larger.
    You may have other band brands in the board too so what elese do you have?.
    What are the other markings on the can and what diameter for the G-Luxon?
    Mann-Made Global Warming.
    - Dr Seuss
    • arwinbones
      • 8
      The other caps are teapo and the caps that are bad are are 8mm by 13mm i believe.
      • arwinbones
        • 8
        The markings on the can are G-luxon correction from 1500uF to
        1000uF 6.3v
        LZ 105C
        1034(M)
        • PCBONEZ
          Grumpy Old Fart
          • Aug 2005
          • 10661
          Okay, I dunno how much you have read up on the topic.
          Those are low ESR caps.
          When you replace low ESR caps you want caps rated with:
          - The same or more Ripple (mAmps)
          - The same or less ESR (Ohms) - ESR is often called Impedance at 100kHz in data sheets.
          The LZ data sheet [attached] only shows a 10x20mm for 6.3v 1500uF.
          - Are you SURE these are 8mm x about 13mm? [probably 8x14mm looking at LZ data sheet.]
          - Can size matters big time in choosing replacement low ESR caps.
          Your 8x13mm [8x14mm] in 6.3v/1500uF are apparently a custom ordered size.
          As the ESR and Ripple are VERY dependent on the can size [and not dependent on uF or volts at all] we need to look for caps with that can size in the LZ specs sheet and use the specs from that cap.
          This will be wrong if you gave the wrong can size wrong...
          The nearest 8x14 has ESR 0.087 Ohms and Ripple 840 mA.
          [That is really crappy specs for a 1500uF on a mobo by the way.]
          So:
          You need caps with:
          8mm diameter, 1500uF, 105C Temp
          Volts rating 6.3v - or more
          ESR rating 0.087 Ohms - or less
          Ripple rating 840 mA - or more
          That should not be too hard to find.
          This site has an international population and you didn't enter your location in your profile so I really can't make suggestions as to where to get them without listing every place on the planet.
          Any Teapo that are 6mm or larger diameter should go. [You need to 'spec' them too.]
          [Some say 8mm and up but I don't like ordering caps twice or 'reworks' for one board.]
          Teapo don't have a good history on motherboards but the 4mm and 5mm rarely fail.
          - Dr Seuss
          • c_hegge
            • Sep 2009
            • 5219
            These would work, but are overkill (and more likely to have heat issues like Chemi-con KZG and KZJ). These are probably a more exact match. (Not that I generally encourage buying from Fleabay, but this seller is one of very few that sells genuine caps)
            • arwinbones
              • 8
              I have one of the seven caps I took off and I was mistaken about the 1500uF. It is really a 1000uF 6.3v G-Luxon cap.
              • arwinbones
                • 8
                There are 22X G-Luxon Caps that are 8mm to 10mm in diameter. 10mm is the largest I have on this motherboard. 11X 1000uF 6.3v, 7X 2700uF 6.3v, and 4X 1500uF 10v on my motherboard.
                • brethin
                  • Dec 2008
                  • 1907
                  Are you still asking what caps to use for replacements or just stating what is on the board.
                  • arwinbones
                    • 8
                    Asking what would be the best to replace them with.
                    • brethin
                      • Dec 2008
                      • 1907
                      Almost anything would be better than G-Luxon and Teapo. My guess is since you did not post what board you have (Make and Model#) it is crap and you need to replace all the caps on it. Read the other replies they are telling you what to get to replace the ones you are asking about but you can not just replace a few if they all suck.
                      • PCBONEZ
                        Grumpy Old Fart
                        • Aug 2005
                        • 10661
                        That depends on what series they are.
                        G-Luxon makes a lot more than one series.
                        Are they all LZ?
                        - Dr Seuss
                        • arwinbones
                          • 8
                          What is LZ in particular? I know that they are green with the negative has a gold band.
                          • PCBONEZ
                            Grumpy Old Fart
                            • Aug 2005
                            • 10661
                            They have an LZ on them, or they should....
                            It's the "LZ" you posted in post #4.
                            Do they all have that?
                            I'm uploading the LZ data sheet so you can learn what to look for.
                            - Dr Seuss
                            • PCBONEZ
                              Grumpy Old Fart
                              • Aug 2005
                              • 10661
                              Look at the data sheet.
                              See where it says "Ripple"?
                              That's the amount of Ripple Current the cap can handle without overheating.
                              The units are mA [milliamps]
                              ** Your replacements should have the value of the original cap or more.
                              See where it says "Z"?
                              Z stands for Impedance. Impedance is like resistance but it is for AC only.
                              - Layman Definition: ESR is the 'resistance' to ripple [which is AC] passing through the cap.
                              In this data sheet Z is specified at 20°C and 100kHz. [That is standard for low ESR caps and most others.]
                              In a cap Impedance is made up of Capacitive Reactance, Inductive Reactance, and ESR.
                              At 100kHz the Capacitive Reactance & Inductive Reactance cancel each other out so at 100kHz, Z = ESR.
                              - Since one of the caps main jobs is to short the Ripple to ground to keep the DC power nice and 'clean' we want the 'resistance' to be low.
                              ESR units are in ohms.
                              ** Your replacements should have the value of the original cap or less.
                              The voltage rating is a -max limit- not an operating parameter so going to a higher voltage is just fine.
                              Going down in volts is only okay if you check the actual circuit voltage and don't use a cap rated for less volts.
                              ----- Motherboard Exception...
                              The only voltages on motherboards are 3.3v, 5v, 12v, or less than 3.3v.
                              .. Neither a 6.3v or a 10v would be found in a 12v circuit.
                              .. That means all 6.3v and 10v mobo caps are on actual voltages of 5v or less.
                              .. That means you can safely use 6.3v and 10v rated caps interchangeably.
                              Have I managed to confuse you yet?
                              - Dr Seuss
                              • mockingbird
                                • Dec 2008
                                • 5484
                                0.087 caps around a VRM? Either it's a really old P3 board, or they skimped. I think it should be safe to use something like HM around the VRM and FC/PW everywhere else. I just recapped an AN78X with Samxon GC for VRM and Nichicon PW everywhere else.
                                • PCBONEZ
                                  Grumpy Old Fart
                                  • Aug 2005
                                  • 10661
                                  Depends on how many are in the VRM.
                                  - I have a 'late' Slot A board with 18 2200uF VRM caps.
                                  That wasn't too unusual for AMD for a while.
                                  Back then AMD was having CPU issues with cheap PSUs and I think their fix was to uF the VRM to death.
                                  With so many caps the individual caps didn't need to be especially low ESR.
                                  Board in question is a socket A @ PC2100 so it's not that much never than the one I mentioned.
                                  - Dr Seuss
                                  • arwinbones
                                    • 8
                                    Im a electronic geek so I understand every bit of it. I see what you are referring too.
                                    • Pyr0Beast
                                      • Feb 2009
                                      • 406
                                      Recap with 2200uF LowESR Pannys and you are good to go
                                      • PCBONEZ
                                        Grumpy Old Fart
                                        • Aug 2005
                                        • 10661
                                        That brings up another point.
                                        Terms like 'low ESR', 'ultra low ESR, 'very low ESR' have no -real- meaning.
                                        - There is no Industry Standard that defines any of those terms.
                                        As such the various manufacturers can tag their product with one of those terms regardless of how good or bad the caps are.
                                        Is 'ultra low' lower than 'very low'? - Depends on who made it.
                                        And brand X's Super Whamodyne Low might be equivelent to brand Y's Kinda Low.
                                        - Dr Seuss
