I have 7 G-Luxon 6.3 1500uf capacitors that need to be replaced and was wondering what kind should I replace them with. They came off a AM35 Rev. A3 motherboard. And I've had a hard time finding any G-Luxon capacitors to match except for ones I have to order from China and Japan.
Need help deciding what to replace my caps on my motherboard with.
Tags: None
Re: Need help deciding what to replace my caps on my motherboard with.
G-Luxon are junk. - You want a good brand with the same or better ratings for ESR/Ripple.
You should replace all the G-Luxon 6mm Diameter and larger.
You may have other band brands in the board too so what elese do you have?.
What are the other markings on the can and what diameter for the G-Luxon?Last edited by PCBONEZ; 05-01-2011, 01:52 PM.Mann-Made Global Warming.
- Dr Seuss
The other caps are teapo and the caps that are bad are are 8mm by 13mm i believe.Comment
The markings on the can are G-luxon correction from 1500uF to
1000uF 6.3v
LZ 105C
1034(M)Comment
Okay, I dunno how much you have read up on the topic.
Those are low ESR caps.
When you replace low ESR caps you want caps rated with:
- The same or more Ripple (mAmps)
- The same or less ESR (Ohms) - ESR is often called Impedance at 100kHz in data sheets.
The LZ data sheet [attached] only shows a 10x20mm for 6.3v 1500uF.
- Are you SURE these are 8mm x about 13mm? [probably 8x14mm looking at LZ data sheet.]
- Can size matters big time in choosing replacement low ESR caps.
Your 8x13mm [8x14mm] in 6.3v/1500uF are apparently a custom ordered size.
As the ESR and Ripple are VERY dependent on the can size [and not dependent on uF or volts at all] we need to look for caps with that can size in the LZ specs sheet and use the specs from that cap.
This will be wrong if you gave the wrong can size wrong...
The nearest 8x14 has ESR 0.087 Ohms and Ripple 840 mA.
[That is really crappy specs for a 1500uF on a mobo by the way.]
So:
You need caps with:
8mm diameter, 1500uF, 105C Temp
Volts rating 6.3v - or more
ESR rating 0.087 Ohms - or less
Ripple rating 840 mA - or more
That should not be too hard to find.
This site has an international population and you didn't enter your location in your profile so I really can't make suggestions as to where to get them without listing every place on the planet.
Any Teapo that are 6mm or larger diameter should go. [You need to 'spec' them too.]
[Some say 8mm and up but I don't like ordering caps twice or 'reworks' for one board.]
Teapo don't have a good history on motherboards but the 4mm and 5mm rarely fail.
.Attached Filesif you find these attachements useful please consider making a small donation to the site
- Dr Seuss
These would work, but are overkill (and more likely to have heat issues like Chemi-con KZG and KZJ). These are probably a more exact match. (Not that I generally encourage buying from Fleabay, but this seller is one of very few that sells genuine caps)I love putting bad caps and flat batteries in fire and watching them explode!!
Office PC: HP ProLiant ML150 G3, 2x Xeon E5335 2GHz, 4GB DDR2 RAM, 120GB Intel 530 SSD, 2x 250GB HDD, 2x 450GB 15K SAS HDD in RAID 1, 1x 2TB HDD, nVidia 8400GS, Delta DPS-650BB 650W PSU, Windows 7 ProComment
I have one of the seven caps I took off and I was mistaken about the 1500uF. It is really a 1000uF 6.3v G-Luxon cap.Comment
There are 22X G-Luxon Caps that are 8mm to 10mm in diameter. 10mm is the largest I have on this motherboard. 11X 1000uF 6.3v, 7X 2700uF 6.3v, and 4X 1500uF 10v on my motherboard.Comment
Asking what would be the best to replace them with.Comment
Almost anything would be better than G-Luxon and Teapo. My guess is since you did not post what board you have (Make and Model#) it is crap and you need to replace all the caps on it. Read the other replies they are telling you what to get to replace the ones you are asking about but you can not just replace a few if they all suck.Comment
- Dr Seuss
What is LZ in particular? I know that they are green with the negative has a gold band.Comment
They have an LZ on them, or they should....
It's the "LZ" you posted in post #4.
Do they all have that?
I'm uploading the LZ data sheet so you can learn what to look for.
- Dr Seuss
Look at the data sheet.
See where it says "Ripple"?
That's the amount of Ripple Current the cap can handle without overheating.
The units are mA [milliamps]
** Your replacements should have the value of the original cap or more.
See where it says "Z"?
Z stands for Impedance. Impedance is like resistance but it is for AC only.
- Layman Definition: ESR is the 'resistance' to ripple [which is AC] passing through the cap.
In this data sheet Z is specified at 20°C and 100kHz. [That is standard for low ESR caps and most others.]
In a cap Impedance is made up of Capacitive Reactance, Inductive Reactance, and ESR.
At 100kHz the Capacitive Reactance & Inductive Reactance cancel each other out so at 100kHz, Z = ESR.
- Since one of the caps main jobs is to short the Ripple to ground to keep the DC power nice and 'clean' we want the 'resistance' to be low.
ESR units are in ohms.
** Your replacements should have the value of the original cap or less.
The voltage rating is a -max limit- not an operating parameter so going to a higher voltage is just fine.
Going down in volts is only okay if you check the actual circuit voltage and don't use a cap rated for less volts.
----- Motherboard Exception...
The only voltages on motherboards are 3.3v, 5v, 12v, or less than 3.3v.
.. Neither a 6.3v or a 10v would be found in a 12v circuit.
.. That means all 6.3v and 10v mobo caps are on actual voltages of 5v or less.
.. That means you can safely use 6.3v and 10v rated caps interchangeably.
Have I managed to confuse you yet?
.Last edited by PCBONEZ; 05-03-2011, 08:08 AM.Mann-Made Global Warming.
- Dr Seuss
0.087 caps around a VRM? Either it's a really old P3 board, or they skimped. I think it should be safe to use something like HM around the VRM and FC/PW everywhere else. I just recapped an AN78X with Samxon GC for VRM and Nichicon PW everywhere else.Comment
Depends on how many are in the VRM.
- I have a 'late' Slot A board with 18 2200uF VRM caps.
That wasn't too unusual for AMD for a while.
Back then AMD was having CPU issues with cheap PSUs and I think their fix was to uF the VRM to death.
With so many caps the individual caps didn't need to be especially low ESR.
Board in question is a socket A @ PC2100 so it's not that much never than the one I mentioned.
.Last edited by PCBONEZ; 05-03-2011, 11:45 AM.Mann-Made Global Warming.
- Dr Seuss
Im a electronic geek so I understand every bit of it. I see what you are referring too.Comment
That brings up another point.
Terms like 'low ESR', 'ultra low ESR, 'very low ESR' have no -real- meaning.
- There is no Industry Standard that defines any of those terms.
As such the various manufacturers can tag their product with one of those terms regardless of how good or bad the caps are.
Is 'ultra low' lower than 'very low'? - Depends on who made it.
And brand X's Super Whamodyne Low might be equivelent to brand Y's Kinda Low.
- Dr Seuss
by Mini1Hey. I have a Fujitsu U757 motherboard with number CP732277. And i want to replace it with U758 motherboard like with CP755900 or whatever U758 series motherboard. U747/U757(7th gen CPU) all motherboards look exactly same so i'm sure it won't matter which one to use. But i would like to upgrade a bit and get U748/U758(8th gen CPU) motherboard. Motherboards all look exactly same layout as U747/U757, but i found one chip is soldered on U747/U757 which U748/U758 doesn't have. It is STM32F103 MCU which is near screen connector. And i'm not sure will U748/U758 motherboard will work with my U757 laptop....2 Photos01-28-2024, 05:01 PM
by glovecapsHello,
I have a Asus ROG Strix Scar 15 (G533QM) that had a dead motherboard (Graphics card dead) and after trying to fix the motherboard with no success, I bit the bullet on a sale for a new motherboard. I ordered a motherboard for the 15 inch model which is the one that I have, and when the motherboard arrived it wasn't for a little while that I saw it was from the 17 inch model.
My question is, can I update the Bios on this G733 motherboard to a G533 Bios.
The reason for wanting to do this is that the keyboard isn't working as it should, and I think this... -
by DocusHi everyone 😀,
I'm here today to ask for help with repairing the motherboard of a Lenovo Legion Y540 17IRH.
To give you some context, I'm passionate about computer repair so much so that I've invested in a lot of tools and started practicing on dead and old hardware. I've been learning how to solder and desolder components, mostly focusing on phone repairs.
Recently, I bought a broken Lenovo Legion Y540 17IRH for just €150, and there are two main reasons why I made this purchase:- I already own the exact same model, but its plastic chassis is badly damaged.
by sopik78Hello everyone,
I would like to ask if it is possible to replace the motherboard for the Lenovo Legion 5 16ACH6H NM-D562 with the NM-D601, which has a less powerful RTX 3050 chip. Has anyone tried this? NM-D562 is significantly more expensive than NM-D601.
Thank you.
by acedogblastThis is a guide that I am writing for helping others to replace their MEC1503 EC chip if it breaks (or to get around an inconvenient prompt to the BIOS). This forum has been extremely helpful to me so I would like to contribute to help others. I will tell you right now that this task is very difficult to do. You MUST have experience and tools to do precision micro-soldering, BGA reballing, trace repair, and general laptop repair skills.
There are some specialty tools needed to do this task. The replacement MEC1503 chips can be acquired from Aliexpress. Do not buy the bare chips as... - Loading...
