Vizio GV42LFHDTV10A no pic, no sound, wont shut off
  • myjeepsbigger
    • Mar 2011
    • 6
    Just as the title says, no picture but backlight is working, no sound and the TV won't shut off with the power button or remote.
    I have replaced the power supply and mainboard with one I purchased from TVpartsguy.com....however on further inspection I found that the mainboard is not the correct part number. Symptoms did not change at all with these "new" parts installed. I also tried my original mainboard with just the new power supply installed. Same. I seem to be getting all the correct voltages to the mainboard. So I moved on to checking the U33 regulator that I've read about here. It's reading 1.08, 1.87, 4.94 respectively on 1,2,and 3....which would indicate a problem. So just for kicks, I installed the new "wrong" board into it for a second time and measured the U33 on it....and voltages were very similar to my original board. (Also I've looked over all caps on both boards and cannot see any that are obviously damaged/bulged/leaking).
    I've already ordered a few new regulators from digikey, because at this point I don't feel like I have much to lose by swapping them out.....but I'm hoping someone can shed a little more light on this for me. Should I be looking at something else or does it seem like I'm on the right track? I'm definitely no electronics repairman, but I have been able to stumble through a few repairs (like the control board on my Hobart welder!).
    Any input would be appreciated.
  • myjeepsbigger
    • Mar 2011
    • 6
    Re: Vizio GV42LFHDTV10A no pic, no sound, wont shut off
    Other voltages I forgot to include:
    1 2 3
    U2 1.87 3.14 4.96
    U7 0 0.82 1.87
    U8 1.87 3.14 4.96
    U9 0 0.99 1.86
    U33 1.08 1.87 4.94
    As far as I can tell from what I've read here, only U2 and U8 look ok...but I'm really new at this. It concerns me that my input voltages on U7 and U9 seem to be really low compared to the others. Makes me think my problem is elsewhere. ????
    • retiredcaps
      • Apr 2010
      • 9271
      Voltage regulators are what people call "jellybean" parts and quite common on many boards.
      They usually have a part number like AL1117-33 where the suffix (-33) denotes the output voltage. So in this example, the output should be 3.3V DC. Most voltage regulators have a 1% specification. That is, the 3.3V DC should be
      3.3 x 0.99 = 3.267V DC
      or
      3.3 x 1.01 = 3.333V DC
      Anything above or below those values indicates that the voltage regulator is bad.
      So for your case, look at all the part numbers and it will tell you what the output voltage should be. If you can't tell, list them all here and we can help verify.
      --- begin sig file ---
      --- end sig file ---
      • retiredcaps
        • Apr 2010
        • 9271
        I forgot to mention that "common" output voltages are 3.3V, 2.5V, and 1.8V DC.
        • myjeepsbigger
          • Mar 2011
          • 6
          Got the parts today, ordered 4 in case I had multiples failing....but I only needed one! Replaced the U33 and it's working like new again!
          Now hopefully I can get them to take back the mainboard that didn't work....
          • ke1122
            • Mar 2011
            • 17
            I have the exact same TV with the exact same problem. What was the part number for the voltage regulators you ordered from DigiKey.com? I was about to order a new main board and power board from VizParts.com, but I found your post and thought I could save a lot of money by replacing the regulators (after I check the voltages of course).
            Thanks,
            William
            • myjeepsbigger
              • Mar 2011
              • 6
              It was from another thread here, but I can't find it now....and I don't have my invoice in front of me. Search for Vizio threads here, I'm sure that's were I got it.
              • ke1122
                • Mar 2011
                • 17
                I finally got around to testing some voltages and here's what I found:
                U2, U7, U8, U9, U33
                All had the 1st readout of a positive, 2nd readout of 0, and the 3rd readout of negative.
                I also tested P7, pins 2, 3, 4 and 10, 11, 12. I don't remember the exact readouts, but they weren't 12v and 5v, respectively. They weren't even close.
                Then I tested some of the connections on the boards to the left and right of the mainboard. Sorry, I didn't jot down the connection numbers, but they all had readings of around 17.5-18.5v, or 1.5v and around 5v. They were all consistent.
                With this info I'm guessing the Mainboard is the problem. Power seems to be getting to (and flowing through) the boards to the left and right, but not to all of the tested connections on the mainboard. I'm also going to get a new LVDS cable while I'm at it (this connects to J7).
                Unless anyone has any other ideas? I'm definitely open to suggestions since the mainboard cost about $180 plus shipping.
                • daimoku
                  • Feb 2011
                  • 85
                  Originally posted by ke1122
                  U2, U7, U8, U9, U33
                  What were the the actual readings?
                  • retiredcaps
                    • Apr 2010
                    • 9271
                    U2, U7, U8, U9, U33
                    You may not be testing the voltage regulators properly. A negative readout suggests you are using the wrong ground.
                    See PlainBill explain what and how to test a voltage regulator at
                    https://www.badcaps.net/forum/showpo...1&postcount=23
                    • ke1122
                      • Mar 2011
                      • 17
                      Sure enough, I wasn't testing them properly. So much for thinking I knew what I was doing.
                      I'm going to retest now.
                      • ke1122
                        • Mar 2011
                        • 17
                        Ok, here are the properly taken readouts:
                        U2: 2.76 3.51 5.56
                        U7: 0.03 1.29 2.82
                        U8: 2.88 4.85 5.57
                        U9: 0.00 1.43 2.76
                        U33: 1.71 2.90 9.3-9.7
                        I should note that the U2 reading was steady at those numbers. All other regulators were moving targets (+/- .05). U33 input was all over the place (it even dipped down to 8.9), which is why I put a range.
                        • retiredcaps
                          • Apr 2010
                          • 9271
                          U2: 2.76 3.51 5.56
                          U7: 0.03 1.29 2.82
                          U8: 2.88 4.85 5.57
                          U9: 0.00 1.43 2.76
                          Post the part numbers of each voltage regulator. Without them, we cannot tell if the voltages are correct or not.
                          Just by looking at the numbers themselves, I would say all the regulators are "off". This is assuming your multimeter is working properly. Do you have a fresh or new battery in the multimeter?
                          • daimoku
                            • Feb 2011
                            • 85
                            U2: 2.76 3.51 5.56
                            U7: 0.03 1.29 2.82
                            U8: 2.88 4.85 5.57
                            U9: 0.00 1.43 2.76
                            FYI...the proper output readings are:
                            U2: 3.3V
                            U7: 1.28V
                            U8: 3.3V
                            U9: 1.5V
                            U33: 3.3V
                            U8 & U33 appear suspect
                            • daimoku
                              • Feb 2011
                              • 85
                              Forgot to add that these are AMC1117 adjustable output regulators in the SOT-223 package.
                              • ke1122
                                • Mar 2011
                                • 17
                                According to the Service Manual:
                                U2: POWER MOS IRF7316TRPBF SMD 8PIN LF
                                U7: IC AP1117E18LA LF SOT-223
                                U8: IC AP1117E33LA LF SOT-223
                                U9: IC AP1117E18LA LF SOT-223
                                U33: IC SWITCH PI5C3257QE QSOP 16PIN LF
                                U2 and U33 are both 3 pin, like U7-9. Not sure why the part description says 8 and 16 pin.
                                The batteries are not new, but I've had it for maybe 5 years and rarely used it. It has a low battery indicator, which is not lit. It is a Radioshack 15-range multimeter, part# 22-810.
                                • retiredcaps
                                  • Apr 2010
                                  • 9271
                                  A non fresh battery can cause erratic readings. Straight from the 22-810 manual (note the wording "or the meter does not measure accurately") ...
                                  "When low battery appears on the display or the
                                  meter does not measure accurately, re-
                                  place the battery. If the battery power is
                                  extremely low, low battery does not appear."
                                  I suggest replacing the battery with a new one and taking new measurements. You would not be the first to get inaccurate readings on a weak battery on this forum.
                                  • Scenic
                                    o.O
                                    • Sep 2007
                                    • 2642
                                    my DMM measured a AA battery as 6.1 V once because of a semi-dead battery. no sign of the battery symbol on the display yet.. so much for that..
                                    • ke1122
                                      • Mar 2011
                                      • 17
                                      I just tested a brand new AA Energizer battery and it read 1.61V. I tested 2 used AA Energizers and they read 1.36V and 0.51V. Should I still get a new battery in the multimeter?
                                      • ke1122
                                        • Mar 2011
                                        • 17
                                        With a +/- 0.8% allowable variance in DCV according to the manual, I'm gonna say yes since 1.61 is ~8% higher than 1.5.
                                        DC VOLTS
                                        (2–20–200–500 V) .......... ± 0.8% of full scale,
                                        ± 1 in last digit
                                        • Tynan Dill
                                          by Tynan Dill
                                          Assuming...
                                          11-22-2024, 01:46 PM
                                        • Ierwin
                                          by Ierwin
                                          05-13-2025, 03:31 PM
                                        • ChaosLegionnaire
                                          by ChaosLegionnaire
                                          09-13-2022, 09:02 AM
                                        • Devonavar
                                          Vizio M43-C1 - How closely do I need to match the mainboard number?
                                          by Devonavar
                                          I have a Vizio M43-C1 stuck in a reboot loop with no backlight.
                                          I've tested all the voltage rails coming out of the power supply and they are "normal" for this model (PS_ON & DIM go high when turned on, BL_ON & 3D_ON are close to zero due to backlight power flowing through the mainboard, 5VSB is 5V, and 12V is 19V, which is apparently normal for this board).
                                          Basically, I get similar results to Garry in this post: https://www.badcaps.net/forum/showthread.php?t=80346
                                          So, I've ruled out the PSU for now.
                                          The reboot loop...
                                          08-14-2022, 08:46 PM
                                        • maricm
                                          Vizio P65 with P55 mainboard
                                          by maricm
                                          IH all, Got this vizio tv P65-E1 from FB marketplace hoping to be able to reflow mainboard as selerrstated that it was diagnosed with bad mainboard. However they must have tried to repair tv by putting another board in and they put P55 board in .
                                          Tv starts and responds to remote but screen does not look right , It looks like low resolution with some image ghosting. Now not having original board I dont know what to order ? Any advice how to figure out what exact board fits this tv ?
                                          And another question Would it be possible to adopt this board to this tiv by chagning eeprom or tcon...
                                          04-23-2024, 08:25 AM
