Hi folks, can anyone tell me what this component marked “V4” is and maybe if there is a way to test it?
Can you identify this component? Photo included
Re: Can you identify this component? Photo included
V4 looks like a gas arrestor or gas discharge tube. The others look like neon bulbs.
https://au.mouser.com/ProductDetail/...Z3W22c2g%3D%3D
https://my.rs-online.com/web/p/gas-d...-tubes/1670452Last edited by truclacicr; 10-16-2023, 06:58 PM.Comment
Thank you! You are exactly correct. Is there any way I can tell if it's good or not? I suspect it's probably good as I don't see any signs of leakage or physical damage.V4 looks like a gas arrestor or gas discharge tube. The others look like neon bulbs.
https://my.rs-online.com/web/p/gas-d...-tubes/1670452Comment
by Loki_FidoHi folks,
Hope everyone's doing well.
I have a HP ProBook 450 G9 came in for repair. This driver is shorted and im looking to buy a replacement. But i cant identify this chip.
I checked our BadCaps sticky on following site
https://www.badcaps.net/forum/troubl...and-datasheets
But the name of the chip is wrong. I checked based on GND on chip.
If you check on above link, you'll think this chip is SY8388ARHC, but if you search... -
by klynstronicHello. Could you help me identify the code for this component marked .11?
It belongs to the BMW X1 automotive gear selector circuit....-
Channel: Common Parts Library - Datasheets
by GentianI am not able to identify this element marked A22020. Some short indexes suggest it is a n-channel mosfet or a pnp transistor. I measured it and it looks to have only a very small capacitance between pins 2 and 3. Any suggestion would be very important. In my experience whatever it should be a dead component. The device is a level radar which looks no current consumption although 12V and 3.3v are ok at MCU and in the circuit but no data transmission?...
by silver60618Hi i need help identifying this IC marked MZ8b. its coming off the DC jack for a mini pc. is there any measurements I can take to help identify it? looked online, found nothing
Thanks!... -
by ZoOLfHi,
Please can you help me identify this IC which is obviously dead, for a HP omen 16.
It 16pin IC with B3FBE inscription.
Board : jpr6f la-m783p
Thx.... - Loading...
- No more items.
