I am not able to identify this element marked A22020. Some short indexes suggest it is a n-channel mosfet or a pnp transistor. I measured it and it looks to have only a very small capacitance between pins 2 and 3. Any suggestion would be very important. In my experience whatever it should be a dead component. The device is a level radar which looks no current consumption although 12V and 3.3v are ok at MCU and in the circuit but no data transmission?
Help identify 3 pin smd element marked A22020
Dear Great Sage thanks for your help. I am attaching a photo of pcb where the 3 pins element is connected. Referring to standard 3 pins smd pin numbering I see that pin 3 goes to Ground and pin 1 and 2 goes to these 2 identical chips above and measuring in the device terminal (RS-485 terminal 2 and 3) pins 1 and 2 of A22020 have a resistance of 9 Ohms each to respective RS-485 terminals so pin 2 and 3 in the output terminal. My Device (RLS hydrologic meter) doesn't transmit data anymore from pin 6 of the terminal but no short circuit anywhere in the circuit although all voltages look ok.Comment
The two preceding Bourns devices appear to be this (TBU-CA065-200-WH):
https://docs.rs-online.com/00c6/A700000006416237.pdf
https://ae-pic-a1.aliexpress-media.com/kf/S80d48d2208cf451794d7e96aac63d2a8K.jpg (photo)
It's an over-current protector. Page 3 shows them connected to two overvoltage protectors which are connected to ground. Therefore I expect that the mystery device has one ground pin and two input pins, probably two TVS diodes or two ESD protection diodes in the one package.
Something like this ...
https://www.diodes.com/assets/Datash...SD2CAN2SOQ.pdfLast edited by truclacicr; 01-25-2025, 12:22 PM.Comment
Thanks very much for your help. Yes, I think now A22020 is SPD and looks it is not defective as I thought yesterday. I am checking the circuit for any other issue, and I am seeing no signal in the MCU oscillator. Checking it out board and also its 2 small capacitors everything looks ok. Maybe MCU fault but it is another topic.
Thanks again for your help!Comment
by flyskyThere is a motherboard Gigabyte H610M S2H V2 (DDR5), I can't find boardview
Help to identify the element, marking on the element - C31PH. It stands next to the USB 3.0 and it looks like it is ESD Protect chip. We need a datasheet to this element. Maybe someone has already identified such an element. Help please.
by fraser34Hi,
Can anybody, please, help to identify this burnt element on ZOTAC GeForce RTX 2060 6GB 192BIT GDDR6?
It says something like "6UDN..." on it.
Thanks... -
by klynstronicHello. Could you help me identify the code for this component marked .11?
It belongs to the BMW X1 automotive gear selector circuit....-
Channel: Common Parts Library - Datasheets
by SS454vizio e650i-a2 (LWJAOZBP Serial) led backlight flashes then turns off, has video (via flashlight) and audio.
panel: au optronics T650HVN05.4
72 led total on 12 strips, 6 led per strip wired in three groups of 24 (led driver board has three anode and three cathode pins)
link to datasheet: https://datasheetspdf.com/pdf-file/8.../T650HVN05.4/1
Vizio 56.04219.641G (liteon PA-3231-01WN-LF) Power Supply Unit
https://www.shopjimmy.com/vizio-56-0...-power-supply/
Vizio 55.75J01.001G (91.75J10.004G) Main Board... -
by silver60618Hi i need help identifying this IC marked MZ8b. its coming off the DC jack for a mini pc. is there any measurements I can take to help identify it? looked online, found nothing
Thanks!... - Loading...
