Optiquest Q9 Board "ILPI-025"
    I've had this for some time and I took out all of the caps when I didn't know better and now I want to know which caps and series come with this board.
    ILPI-025
    REV: E
    2007.01.15
    Anyone who is repairing this can you help me out?
    Re: Optiquest Q9 Board "ILPI-025"
    Looks like no one is playing with one of those.
    - Google is your friend.
    http://www.google.com/#sclient=psy&h...46a2d5a887ccfe
    First hit at time I looked:
    http://www.ccl-la.com/blog/index.php/tag/ilpi-025/
    Doesn't list all the caps but it has some.
    Mann-Made Global Warming.
    - Dr Seuss
      I just opened up an Acer with this board (ILPI-025 RevB). Mine has 4 big caps, in an arc. Starting with the one closest to the AC inlet, mine are 470uf, 25v (C502); 470uf, 25v (C817); 1000uf, 25v (C815); 1000uf, 25v (C818). There are also 3 small caps (6mm), which are: 47uf 25v (C820)(C827)(C807).
      Hope this helps.
      (not sure what's wrong with my board - caps "look" good. Did you find anything interesting on yours?)
        Originally posted by brock-s View Post
        (not sure what's wrong with my board - caps "look" good.)
        What is wrong? Does the power LED come on? With a computer connected, can you see the display if you shine a flashlight on it?
        --- begin sig file ---
        --- end sig file ---
          Can you list me also the brands and series for each cap:
          C501
          C817
          C815
          C818
          C820
          C827
          C807
          C702
          C713
          C701
          C707
          C705
          In total there are 13 caps on the board (Including the big primary cap).
          Much obliged.
            Ok, here's a picture, I thought I could make it easier, since our board revisions are slightly different and the board numbering seems to be off:
            1) C501
            2) C817
            3) C815
            4) C818
            5) C820
            6) C827
            7) C807
            8) C702
            9) C713
            10) C701
            11) C707
            12) C705
            Ignore the capacitors that are there. I replaced them with inedequate parts when I knew no better.
            Attached is a higher resolution photo.
              As promised:
              1) C501 - Su'scon 470uF 25V SG105°C 0705(M)
              2) C817 - Su'scon 470uF 25V SG105°C 0705(M)
              3) C815 - Su'scon 1000uF 25V SG105°C 0703(M)
              4) C818 - TEAPO 1000uF 10V SY105°C 0703 A3T1
              5) C820 - Su'scon 47uF 25V SH125°C 0701(M)
              6) C827 - Su'scon 47uF 25V SH125°C 0701(M)
              7) C807 - Su'scon 47uF 25V SH125°C 0701(M)
              8) C702 - Su'scon 470uF 25V SG105°C 0705(M)
              9) C713 - TEAPO 10uF 25V SH105°C 0643 A3T2
              10) C701 - TEAPO 220uF 16V SH105°C 0704 A3T2
              11) C707 - Su'scon 470uF 16V SK105°C 0705(M)
              12) C705 - Su'scon 470uF 16V SK105°C 0705(M)
                Thank you very much, I really appreciate it. Here are suitable replacements, all by Panasonic (Except for the primary), from Digikey, all in stock:
                1) http://search.digikey.com/scripts/Dk...name=P12388-ND
                2) http://search.digikey.com/scripts/Dk...name=P12388-ND
                3) http://search.digikey.com/scripts/Dk...name=P12379-ND
                4) http://search.digikey.com/scripts/Dk...name=P11203-ND
                5) http://search.digikey.com/scripts/Dk...&name=P5151-ND
                6) http://search.digikey.com/scripts/Dk...&name=P5151-ND
                7) http://search.digikey.com/scripts/Dk...&name=P5151-ND
                8) http://search.digikey.com/scripts/Dk...name=P12388-ND
                9) http://search.digikey.com/scripts/Dk...&name=P5161-ND
                10) http://search.digikey.com/scripts/Dk...me=P10370TB-ND
                11) http://search.digikey.com/scripts/Dk...&name=P5543-ND
                12) http://search.digikey.com/scripts/Dk...&name=P5543-ND
                And the primary, if you're interested in replacing it too:
                http://search.digikey.com/scripts/Dk...me=565-1481-ND
                Highest length I went was 20mm, which is the height of the two larger heatsinks, so they should fit just fine.
                On my board C701 is "Suscon SK" not "Teapo SH". I still have that one original on my board. Not to worry, they're both general purpose caps anyways, most likely interchangeable, all I had to do was either match or slightly exceed the ripple with a higher quality part.
                  I found the caps I removed, it appears that they did indeed use the Teapos and Suscons interchangeably (And probably why yours lasted longer than this one - a testament that Teapo is in fact superior to Suscon). Just to compare to your list:
                  1) C501 - Su'scon 470uF 25V SG - 10mm x 17mm
                  2) C817 - Su'scon 470uF 25V SG - 10mm x 17mm
                  3) C815 - Su'scon 1000uF 25V SG - 13mm x 20mm
                  4) C818 - Su'scon 1000uF 10V SG - 10mm x 17mm
                  5) C820 - Su'scon 47uF 25V SH - 6.3mm x 11mm
                  6) C827 - Su'scon 47uF 25V SH - 6.3mm x 11mm
                  7) C807 - Su'scon 47uF 25V SH - 6.3mm x 11mm
                  8) C702 - Su'scon 470uF 25V SG - 10mm x 17mm
                  9) C713 - TEAPO 10uF 25V SH - 5mm x 11mm
                  10) C701 - Su'scon 220uF 16V SK - 6.3mm x 11mm
                  11) C707 - Su'scon 470uF 16V SK - 8mm x 11mm
                  12) C705 - Su'scon 470uF 16V SK - 8mm x 11mm
                    To followup, the sizes you listed are identical to mine.
                    Thanks for the links. I've quoted you over in my thread for thoroughness.
                    Really appreciate your help.
                      Thanks to mockingbird for the Digi-Key links! I'd been about to buy a $12 capacitor kit from this page:
                      http://www.ccl-la.com/blog/index.php...q19wb-monitor/
                      That's where I found simple instructions & videos on how to perform this repair. But I saved five bucks by ordering the seven capacitors that I needed from Digi-Key using the links that I found here. So all in all this li'l project cost me $25 for a 40W soldering iron, lead-free solder and desoldering braid from Radio Shack, plus about $7 including tax & shipping for the seven capacitors from Digi-Key. I could've bought a new ILPI-025 board on eBay for about $25, but what fun would've THAT been?
