KDL-40W4100 Flickering
  • Jackching
    • May 2017
    • 127
    I get a black flicker on the screen regardless the input. It doesn't matter if a HDMI cord is plugged in or not, you can still see the flicker. It used to come out of it after about 20 minutes of viewing but now it seems to always stay there. Here is a video: https://www.veed.io/view/26c0999a-e3...bc?panel=share
  • nomoresonys
    • 12323
    • U.S.
    Re: KDL-40W4100 Flickering
    no video there, just some audio.
    • nomoresonys
      • 12323
      • U.S.
      go ahead and heat up those electrolytic caps with a hairdryer, start with those 4 by the connector there, heat them up for a few minutes, then try the tv, don't wait til it cools down, try it while its still hot, see if there's any change.
      • Jackching
        • May 2017
        • 127
        Are you serious or are you wanting a picture of the boards? If you're serious, the four caps on the PSU?
        • nomoresonys
          • 12323
          • U.S.
          what part of the suggestion are you having trouble with, is there 4 electrolytic caps by the connector on the psu or not. Pictures should always be the first thing posted when there's a doubt about what the issue is, my crystal ball is broken so I can't see what you see there.
          • Jackching
            • May 2017
            • 127
            Ok I heated the 4 caps by the PSU connecter then hooked it back up. It seems to be way better then what it was. Im noticing if I move the tv around though that it seems to make it flicker some but i find it's only happening half as much after I heated them. I tested the caps with a cap tester and they all seemed to test good.
            • nomoresonys
              • 12323
              • U.S.
              if moving or tapping lightly on back of tv effects the picture it could be a bad connection in the backlight circuit or a bad solder joint on bottom of psu board, maybe look them over very closely, magnified if possible and reflow any suspect solder joints, careful not to bridge any, examples of bad joints there: https://www.google.com/search?q=bad+...ih=607&dpr=1.5
              • nomoresonys
                • 12323
                • U.S.
                as for the caps, if the picture goes back to being worse and is better when they are warmed, I would switch them out, might be the only issue, just to eliminate them as the problem, why not, they are actually only meant to last about 10 years, even tho some are still good after 50 years.
                • Jackching
                  • May 2017
                  • 127
                  Okay, I already had the PSU out and checked for bad solder joints but can go over it again. Any chance of it being a ribbon cable? When i touch right above the top right ribbon cable, it seems to flicker. Are there any videos on getting the bezel off this tv to access the ribbon cables? I can get the top part off but dont want to start taking everything apart without knowing what im doing.
                  • nomoresonys
                    • 12323
                    • U.S.
                    its ccfl tv, they're easier to work with than a lot of the later made led tvs, should be pretty straight forward for tearing it down, suppose you want to check the tab bonds.
                    • nomoresonys
                      • 12323
                      • U.S.
                      another thing to try, go into display settings and set Random noise reduction to off.
                      • nomoresonys
                        • 12323
                        • U.S.
                        plus the simple reset, with tv unplugged hold power button on tv in for 30 seconds, plug tv back in and try it, if you havent already.
                        • Jackching
                          • May 2017
                          • 127
                          I turned off noise reduction and did the reset and still the same thing. When i lean the tv ahead or back at certain angles, it will work fine until i move it a touch either way then it will start flickering again. I went over all of the PSU another two times with a magnifying glass and it looks as good as new.
                          • nomoresonys
                            • 12323
                            • U.S.
                            Ok, seems like possible tab bond issue: https://www.youtube.com/watch?v=purk_SyiT44&t=5s
                            • nomoresonys
                              • 12323
                              • U.S.
                              here's a super low tech tab bond fix, whatever works right: https://www.overclock.net/media/no-title.4154762/full
                              • Jackching
                                • May 2017
                                • 127
                                Im thinking tab also. That last option with the clamp is funny lol. Ill try stripping it down a little further to access the tabs then.
                                • Jackching
                                  • May 2017
                                  • 127
                                  Ok it is indeed the tabs. It is the one on the left. Im just not sure the best way to secure it where i need it. I dont want the tape to fall off or something after i get it all back together. Any suggestions on holding it where i want it?
                                  Edit: So when the metal frame was put back on, that's when the picture would cut out and flicker. I needed a way to keep the tab out when i put the frame back on so i found some sill plate gasket for houses and cut a strip off it. I had to stog that behind the tab to keep it out when i pushed the metal frame back on. I can move the tv and tap the back of it now without it even flickering.
                                  • nomoresonys
                                    • 12323
                                    • U.S.
                                    you just need a little steady pressure on that, see where you hold it lightly down and it gets good contact and screen clears up, just put your shim over that, that nice metal frame will hold it in place, you can tape whatever you use as a shim in place if you want: https://www.youtube.com/watch?v=zqcdTNoOoN0
                                    • nomoresonys
                                      • 12323
                                      • U.S.
                                      here's a tip, after you put the screws back in your metal frame, try the tv to make sure there is no lines, sometimes if the screws are a little tight you can get lines on the screen, then you would just loosen the screw a little, doesn't happen a lot but I have run across the issue.
                                      • Jackching
                                        • May 2017
                                        • 127
                                        So anyway when the frame was on i could notice the gasket i put in behind the display when the screen was turned on so i went to move the gasket and must have tore the ribbon or something because now i cant get it back to how it was. Also there's a line going down the screen. So thats all she wrote. To the dump it goes
                                        • DrvLikHell
                                          Fixing an I-Inc IF281D for the 3rd time, now with added flickering!
                                          by DrvLikHell
                                          Hello everybody! It's been nine years and I'm back again with the same monitor that several people here helped me fix back then. The first time, I replaced two caps as was recommended here and the original problem was solved. Then it started acting up a few years later and I came back for a parts list and replaced a few more caps (I didn't make a post about that and don't remember which ones), and again the problem was solved. This time, however, I'm not sure if it's caps.
                                          The monitor stays on but certain colors will flicker. Generally it's darker colors like dark greys or dark blues,...
                                          07-05-2024, 02:54 AM
                                        • fixit007
                                          Samsung flicker - BN44-00932T board or else?
                                          by fixit007
                                          I picked up this TV that the prior owner said - just died.
                                          Tested the fuse - burnt. A dead capacitor is visible too on the hot side (CP801). Got the replacement power board (cheaply - used). Replaced the board - the TV turned ON!
                                          Now, about a month later (yesterday) I noticed the left side of the screen was flickering from time to time. That was already happening with the antenna input, not through HDMI.
                                          Also, some glitchiness with a Fire stick on HDMI3 - I hit an app with quick dark screen in stick, the TV goes - no input. Then I had to choose the stick...
                                          05-04-2024, 06:14 PM
                                        • reessi
                                          ACER BM320 Monitor - Horizonal Flickering Lines After a While
                                          by reessi
                                          The monitor started off showing flickering thin (1 pixel) lines horizontally every say 3mm..
                                          They are black on the right and gradually fade to nothing on the far left.
                                          They start either after 5 mins or up to 2 hours after so annoying for testing.
                                          They flicker continuously very fast! With a slight pause milli-second every second.
                                          Initially I cleaned the LVDS cable and connected to the T-Con and then it worked fine for 3 weeks but not sure if this was just co-incidence.
                                          I tested each half by removing the first the left flex from...
                                          06-03-2025, 09:58 AM
                                        • arctor
                                          LG 55uh661v flickering images and lines
                                          by arctor
                                          Hi, I have this tv a LG 55UH661V that show flickering images and lines. I tried to take off one at time the right and the left ribbon cable and put the tape for ask the pin…but nothing working. Or I stop to have picture or still flickering. Someone can help me to understand what pin I have to mask? What I notice the buffering board, the flat cable becomes very hot, I don’t think it s normal, I’m talking about the orange flat cable soldering on the buffering board, both side are very hot. I give you the photo with both the ribbon cable on and a photo with the right off and with the lefts...
                                          06-16-2025, 11:57 AM
                                        • Adenitz
                                          Cutting the jumper on Samsung TV to solve the flickering
                                          by Adenitz
                                          Hello to all,
                                          I have just seen this YT video about solving flickering issue on SAMSUNG TV. Reading many comments it seems this works.
                                          But I wonder what is done here and how this solved the issue. I'm not able to find the schematics so cannot explain to myself.
                                          Few years ago I had a flickering problem on one monitor in some factory which I managed to solve by inserting UPS between monitor and power outlet. I also notice on this occasion the flickering was gone if I put insulation tape on the power plug like shown in the attached picture to remove connection with the PE conductor...
                                          01-06-2024, 12:20 PM
