I get a black flicker on the screen regardless the input. It doesn't matter if a HDMI cord is plugged in or not, you can still see the flicker. It used to come out of it after about 20 minutes of viewing but now it seems to always stay there. Here is a video: https://www.veed.io/view/26c0999a-e3...bc?panel=share
KDL-40W4100 Flickering
Re: KDL-40W4100 Flickering
no video there, just some audio.Quit because THIS SITE LETS A ROGUE MEMBER TYPE ANY GARBAGE HE PLEASES AND THE POWERS THAT BE NEVER DO ANYTHING ABOUT IT SO HE NEVER QUITS. THEN YOU GET A PENALTY FOR RESPONDING TO HIS ATTACKS. BEEN GOING ON FOR WAY TOO LONG. DONE SUPPORTING A SITE THAT ALLOWS THIS BS. -
go ahead and heat up those electrolytic caps with a hairdryer, start with those 4 by the connector there, heat them up for a few minutes, then try the tv, don't wait til it cools down, try it while its still hot, see if there's any change.Quit because THIS SITE LETS A ROGUE MEMBER TYPE ANY GARBAGE HE PLEASES AND THE POWERS THAT BE NEVER DO ANYTHING ABOUT IT SO HE NEVER QUITS. THEN YOU GET A PENALTY FOR RESPONDING TO HIS ATTACKS. BEEN GOING ON FOR WAY TOO LONG. DONE SUPPORTING A SITE THAT ALLOWS THIS BS.Comment
Are you serious or are you wanting a picture of the boards? If you're serious, the four caps on the PSU?Last edited by Jackching; 02-22-2023, 03:57 PM.Comment
what part of the suggestion are you having trouble with, is there 4 electrolytic caps by the connector on the psu or not. Pictures should always be the first thing posted when there's a doubt about what the issue is, my crystal ball is broken so I can't see what you see there.Last edited by nomoresonys; 02-23-2023, 05:59 AM.Quit because THIS SITE LETS A ROGUE MEMBER TYPE ANY GARBAGE HE PLEASES AND THE POWERS THAT BE NEVER DO ANYTHING ABOUT IT SO HE NEVER QUITS. THEN YOU GET A PENALTY FOR RESPONDING TO HIS ATTACKS. BEEN GOING ON FOR WAY TOO LONG. DONE SUPPORTING A SITE THAT ALLOWS THIS BS.Comment
what part of the suggestion are you having trouble with, is there 4 electrolytic caps by the connector on the psu or not. Pictures should always be the first thing posted when there's a doubt about what the issue is, my crystal ball is broken so I can't see what you see there.Attached FilesLast edited by Jackching; 02-23-2023, 08:06 AM.Comment
if moving or tapping lightly on back of tv effects the picture it could be a bad connection in the backlight circuit or a bad solder joint on bottom of psu board, maybe look them over very closely, magnified if possible and reflow any suspect solder joints, careful not to bridge any, examples of bad joints there: https://www.google.com/search?q=bad+...ih=607&dpr=1.5Quit because THIS SITE LETS A ROGUE MEMBER TYPE ANY GARBAGE HE PLEASES AND THE POWERS THAT BE NEVER DO ANYTHING ABOUT IT SO HE NEVER QUITS. THEN YOU GET A PENALTY FOR RESPONDING TO HIS ATTACKS. BEEN GOING ON FOR WAY TOO LONG. DONE SUPPORTING A SITE THAT ALLOWS THIS BS.Comment
as for the caps, if the picture goes back to being worse and is better when they are warmed, I would switch them out, might be the only issue, just to eliminate them as the problem, why not, they are actually only meant to last about 10 years, even tho some are still good after 50 years.Quit because THIS SITE LETS A ROGUE MEMBER TYPE ANY GARBAGE HE PLEASES AND THE POWERS THAT BE NEVER DO ANYTHING ABOUT IT SO HE NEVER QUITS. THEN YOU GET A PENALTY FOR RESPONDING TO HIS ATTACKS. BEEN GOING ON FOR WAY TOO LONG. DONE SUPPORTING A SITE THAT ALLOWS THIS BS.Comment
if moving or tapping lightly on back of tv effects the picture it could be a bad connection in the backlight circuit or a bad solder joint on bottom of psu board, maybe look them over very closely, magnified if possible and reflow any suspect solder joints, careful not to bridge any, examples of bad joints there: https://www.google.com/search?q=bad+...ih=607&dpr=1.5Last edited by Jackching; 02-23-2023, 09:24 AM.Comment
its ccfl tv, they're easier to work with than a lot of the later made led tvs, should be pretty straight forward for tearing it down, suppose you want to check the tab bonds.Quit because THIS SITE LETS A ROGUE MEMBER TYPE ANY GARBAGE HE PLEASES AND THE POWERS THAT BE NEVER DO ANYTHING ABOUT IT SO HE NEVER QUITS. THEN YOU GET A PENALTY FOR RESPONDING TO HIS ATTACKS. BEEN GOING ON FOR WAY TOO LONG. DONE SUPPORTING A SITE THAT ALLOWS THIS BS.Comment
another thing to try, go into display settings and set Random noise reduction to off.Quit because THIS SITE LETS A ROGUE MEMBER TYPE ANY GARBAGE HE PLEASES AND THE POWERS THAT BE NEVER DO ANYTHING ABOUT IT SO HE NEVER QUITS. THEN YOU GET A PENALTY FOR RESPONDING TO HIS ATTACKS. BEEN GOING ON FOR WAY TOO LONG. DONE SUPPORTING A SITE THAT ALLOWS THIS BS.Comment
plus the simple reset, with tv unplugged hold power button on tv in for 30 seconds, plug tv back in and try it, if you havent already.Quit because THIS SITE LETS A ROGUE MEMBER TYPE ANY GARBAGE HE PLEASES AND THE POWERS THAT BE NEVER DO ANYTHING ABOUT IT SO HE NEVER QUITS. THEN YOU GET A PENALTY FOR RESPONDING TO HIS ATTACKS. BEEN GOING ON FOR WAY TOO LONG. DONE SUPPORTING A SITE THAT ALLOWS THIS BS.Comment
I turned off noise reduction and did the reset and still the same thing. When i lean the tv ahead or back at certain angles, it will work fine until i move it a touch either way then it will start flickering again. I went over all of the PSU another two times with a magnifying glass and it looks as good as new.Comment
Ok, seems like possible tab bond issue: https://www.youtube.com/watch?v=purk_SyiT44&t=5sQuit because THIS SITE LETS A ROGUE MEMBER TYPE ANY GARBAGE HE PLEASES AND THE POWERS THAT BE NEVER DO ANYTHING ABOUT IT SO HE NEVER QUITS. THEN YOU GET A PENALTY FOR RESPONDING TO HIS ATTACKS. BEEN GOING ON FOR WAY TOO LONG. DONE SUPPORTING A SITE THAT ALLOWS THIS BS.Comment
here's a super low tech tab bond fix, whatever works right: https://www.overclock.net/media/no-title.4154762/fullQuit because THIS SITE LETS A ROGUE MEMBER TYPE ANY GARBAGE HE PLEASES AND THE POWERS THAT BE NEVER DO ANYTHING ABOUT IT SO HE NEVER QUITS. THEN YOU GET A PENALTY FOR RESPONDING TO HIS ATTACKS. BEEN GOING ON FOR WAY TOO LONG. DONE SUPPORTING A SITE THAT ALLOWS THIS BS.Comment
Edit: So when the metal frame was put back on, that's when the picture would cut out and flicker. I needed a way to keep the tab out when i put the frame back on so i found some sill plate gasket for houses and cut a strip off it. I had to stog that behind the tab to keep it out when i pushed the metal frame back on. I can move the tv and tap the back of it now without it even flickering.Attached FilesLast edited by Jackching; 02-23-2023, 02:41 PM.Comment
you just need a little steady pressure on that, see where you hold it lightly down and it gets good contact and screen clears up, just put your shim over that, that nice metal frame will hold it in place, you can tape whatever you use as a shim in place if you want: https://www.youtube.com/watch?v=zqcdTNoOoN0Quit because THIS SITE LETS A ROGUE MEMBER TYPE ANY GARBAGE HE PLEASES AND THE POWERS THAT BE NEVER DO ANYTHING ABOUT IT SO HE NEVER QUITS. THEN YOU GET A PENALTY FOR RESPONDING TO HIS ATTACKS. BEEN GOING ON FOR WAY TOO LONG. DONE SUPPORTING A SITE THAT ALLOWS THIS BS.Comment
here's a tip, after you put the screws back in your metal frame, try the tv to make sure there is no lines, sometimes if the screws are a little tight you can get lines on the screen, then you would just loosen the screw a little, doesn't happen a lot but I have run across the issue.Quit because THIS SITE LETS A ROGUE MEMBER TYPE ANY GARBAGE HE PLEASES AND THE POWERS THAT BE NEVER DO ANYTHING ABOUT IT SO HE NEVER QUITS. THEN YOU GET A PENALTY FOR RESPONDING TO HIS ATTACKS. BEEN GOING ON FOR WAY TOO LONG. DONE SUPPORTING A SITE THAT ALLOWS THIS BS.Comment
So anyway when the frame was on i could notice the gasket i put in behind the display when the screen was turned on so i went to move the gasket and must have tore the ribbon or something because now i cant get it back to how it was. Also there's a line going down the screen. So thats all she wrote. To the dump it goesComment
by DrvLikHellHello everybody! It's been nine years and I'm back again with the same monitor that several people here helped me fix back then. The first time, I replaced two caps as was recommended here and the original problem was solved. Then it started acting up a few years later and I came back for a parts list and replaced a few more caps (I didn't make a post about that and don't remember which ones), and again the problem was solved. This time, however, I'm not sure if it's caps.
The monitor stays on but certain colors will flicker. Generally it's darker colors like dark greys or dark blues,...-
by fixit007I picked up this TV that the prior owner said - just died.
Tested the fuse - burnt. A dead capacitor is visible too on the hot side (CP801). Got the replacement power board (cheaply - used). Replaced the board - the TV turned ON!
Now, about a month later (yesterday) I noticed the left side of the screen was flickering from time to time. That was already happening with the antenna input, not through HDMI.
Also, some glitchiness with a Fire stick on HDMI3 - I hit an app with quick dark screen in stick, the TV goes - no input. Then I had to choose the stick... -
by reessiHello,
The monitor started off showing flickering thin (1 pixel) lines horizontally every say 3mm..
They are black on the right and gradually fade to nothing on the far left.
They start either after 5 mins or up to 2 hours after so annoying for testing.
They flicker continuously very fast! With a slight pause milli-second every second.
Initially I cleaned the LVDS cable and connected to the T-Con and then it worked fine for 3 weeks but not sure if this was just co-incidence.
I tested each half by removing the first the left flex from...-
by arctorHi, I have this tv a LG 55UH661V that show flickering images and lines. I tried to take off one at time the right and the left ribbon cable and put the tape for ask the pin…but nothing working. Or I stop to have picture or still flickering. Someone can help me to understand what pin I have to mask? What I notice the buffering board, the flat cable becomes very hot, I don’t think it s normal, I’m talking about the orange flat cable soldering on the buffering board, both side are very hot. I give you the photo with both the ribbon cable on and a photo with the right off and with the lefts...
by AdenitzHello to all,
I have just seen this YT video about solving flickering issue on SAMSUNG TV. Reading many comments it seems this works.
But I wonder what is done here and how this solved the issue. I'm not able to find the schematics so cannot explain to myself.
Few years ago I had a flickering problem on one monitor in some factory which I managed to solve by inserting UPS between monitor and power outlet. I also notice on this occasion the flickering was gone if I put insulation tape on the power plug like shown in the attached picture to remove connection with the PE conductor... - Loading...
