KDL-40W4100 Flickering
  • nomoresonys
    • 12276
    • U.S.
    Re: KDL-40W4100 Flickering
    Well damn, sorry to hear it, that's a shame I have one I shimmed 3 years ago, still working fine.
    • Jackching
      • May 2017
      • 127
      Ya i am pissed. Anyway thanks for your time and effort. It was much appreciated. Actually i might be able to sell the PSU and main from it.
      • nomoresonys
        • 12276
        • U.S.
        Glad to help, you might run across another, it's kind of a common thing to go bad, I think those older sonys have a good picture.
        • nomoresonys
          • 12276
          • U.S.
          • DrvLikHell
            Fixing an I-Inc IF281D for the 3rd time, now with added flickering!
            by DrvLikHell
            Hello everybody! It's been nine years and I'm back again with the same monitor that several people here helped me fix back then. The first time, I replaced two caps as was recommended here and the original problem was solved. Then it started acting up a few years later and I came back for a parts list and replaced a few more caps (I didn't make a post about that and don't remember which ones), and again the problem was solved. This time, however, I'm not sure if it's caps.
            The monitor stays on but certain colors will flicker. Generally it's darker colors like dark greys or dark blues,...
            07-05-2024, 02:54 AM
          • fixit007
            Samsung flicker - BN44-00932T board or else?
            by fixit007
            I picked up this TV that the prior owner said - just died.
            Tested the fuse - burnt. A dead capacitor is visible too on the hot side (CP801). Got the replacement power board (cheaply - used). Replaced the board - the TV turned ON!
            Now, about a month later (yesterday) I noticed the left side of the screen was flickering from time to time. That was already happening with the antenna input, not through HDMI.
            Also, some glitchiness with a Fire stick on HDMI3 - I hit an app with quick dark screen in stick, the TV goes - no input. Then I had to choose the stick...
            05-04-2024, 06:14 PM
          • reessi
            ACER BM320 Monitor - Horizonal Flickering Lines After a While
            by reessi
            The monitor started off showing flickering thin (1 pixel) lines horizontally every say 3mm..
            They are black on the right and gradually fade to nothing on the far left.
            They start either after 5 mins or up to 2 hours after so annoying for testing.
            They flicker continuously very fast! With a slight pause milli-second every second.
            Initially I cleaned the LVDS cable and connected to the T-Con and then it worked fine for 3 weeks but not sure if this was just co-incidence.
            I tested each half by removing the first the left flex from...
            06-03-2025, 09:58 AM
          • arctor
            LG 55uh661v flickering images and lines
            by arctor
            Hi, I have this tv a LG 55UH661V that show flickering images and lines. I tried to take off one at time the right and the left ribbon cable and put the tape for ask the pin…but nothing working. Or I stop to have picture or still flickering. Someone can help me to understand what pin I have to mask? What I notice the buffering board, the flat cable becomes very hot, I don’t think it s normal, I’m talking about the orange flat cable soldering on the buffering board, both side are very hot. I give you the photo with both the ribbon cable on and a photo with the right off and with the lefts...
            06-16-2025, 11:57 AM
          • Adenitz
            Cutting the jumper on Samsung TV to solve the flickering
            by Adenitz
            Hello to all,
            I have just seen this YT video about solving flickering issue on SAMSUNG TV. Reading many comments it seems this works.
            But I wonder what is done here and how this solved the issue. I'm not able to find the schematics so cannot explain to myself.
            Few years ago I had a flickering problem on one monitor in some factory which I managed to solve by inserting UPS between monitor and power outlet. I also notice on this occasion the flickering was gone if I put insulation tape on the power plug like shown in the attached picture to remove connection with the PE conductor...
            01-06-2024, 12:20 PM
