Msi K7t Turbo2
  • Dodo
    • Dec 2003
    • 2
    Msi K7t Turbo2
    Unfortunately I cant provide pictures of it actually broken as my webcam doesnt have winxp drivers, doesnt like the 2k ones and is broken (my fault). Anyway, the caps that broken are the 4 big green ones around the cpu socket.
  • Topcat
    The Boss Stooge
    • Oct 2003
    • 16955
    Saying the 4 big green ones doesn't help... HEH... I have a K7T Turbo ver3 here, and they should be similar. I assume you're referring to the 4700uF 6.3v caps. Those failed on the one I have here as well.
    <--- Badcaps.net Founder
    Badcaps.net Services:
    Motherboard Repair Services
    http://folding.stanford.edu/
    Team : 49813
    Join in!!
    Team Stats
    • chth96
      Is it possible bridging tiny broken trace
      by chth96
      When I assembled dreamcast I mistakenly fastened long bolt and It resulted in
      cutting tiny trace.
      This tiny trace(Total width of white coating is 5.5mm) is between R337,R343 and IC101 and it is covered with white coating in the below screenshot.
      Firstly I tried to bridging tiny broken trace with my own eyes...But it is totally impossible..So a week ago, I ordered G1200 Digital Microscope and I magnified this tiny broken trace with it.
      But It seems that It is really very tiny trace So I plan to order 0.1mm coper wire from aliexpress in order to bridging...
      12-03-2022, 11:32 PM
    • ArchangelGabriel
      Aorus 17G YD laptop, broken display, could not switch to external monitor
      by ArchangelGabriel
      Hello guys! I need a little help, I have one laptop for repair, it is an Aorus 17G YD, gaming laptop. Broken display, some cable ripped form daughter board connector, case broken, battery discharged and probably locked, etc. After I did the most tedious job I ever did on soldering back the broken cables (shielded cable) , I measured resistance on CPU and GPU core, 3 and 5 v ps and any coils I find on the board, everything seems to be fine. After I plugged the charger I don't get the power led light on from the charger connection maybe because the battery is locked , but on power button I have
      11-23-2023, 03:55 AM
    • corrize
      Resonator - quartz broken - how to find the same (same frequency) ?
      by corrize
      Hello, I have a Fujifilm hybrid camera with an issue : the time don't run. I set 12:00 and 3 min later, the same : 12:00
      I saw an obvious root cause : a broken quartz (resonator). But with the box broken, I can't read the marking code. Probably : 464… or A64…
      I found on the web a picture of the same camera board but with marking code very different. Probably : A7…5N
      I'm searching another one for compare…
      Do you have an idea or another way for find the frequency of this resonator please ?
      (I did not found the manufacturer of this component ? And I did not found the...
      03-27-2025, 09:20 PM
    • emeskay
      Lenovo Yoga 710 15ISK, 80U00002US battery cable wire broken.
      by emeskay
      We have an Lenovo Yoga 710 15ISK that we use as a secondary laptop. To cut a long story short, around May 2023, while traveling, I connected the laptop into an electrical outlet that was already switched on. Something made a "pfft" sound and the laptop refused to turn on after that. After getting back home, I gave the the laptop for repair to an informal repair person. He replaced the adapter and an internal motherboard part, but after he returned it I noticed that the LCD did not look normal. Essentially, every alternate horizontal line on the screen had gone missing. The laptop was...
      08-06-2024, 07:13 AM
    • chth96
      How can I test coil whether it is really broken or not?
      by chth96
      I have old game console which have connected to 220v outlet by previous owner and It is not able to turn on.
      I checked continuity of fuse in PSU unit with a multimeter which is shown in the below picture with a orange circle around it, and It seems that fuse became open circuit.
      I also found that as well as bulging capacitor, there is unidentified coil which has residue all over its surface
      I want to replace this round black fuse and unidentified coil if it got broken.
      02-20-2024, 01:07 AM
