Samsung UE49KS7000SXXH - No standby light
  • B0r1s
    • Jun 2022
    • 21
    • Serbia
    Hi, my tv turned itself off and since than i can't turn it on. I have no standby light.
    I tried like i saw on few youtube videos to disconnect the cable that is coming from the main board and than to power on tv, to see if backlight will appear, it did appear but only for a second, and while power cable was attached I noticed small ticking sound from the middle of power board. Than i attached the main board cable again and ticking sound was still present. I guess sound is coming from transformer area, but not sure.
    Then i measured stby voltage on the board, and it is below normal value displayed on the board, and it is not stable (4v-5.7v), i got it on the video, when i detach main board cable values are a bit higher (5v-7.5v).
    I looked for swollen or leaked caps but didnt found any. What do you think? what should i look for next?
    Videos:
    1. Ticking sound
    https://www.veed.io/view/7aedcdf4-ba...ingWidget=true
    2. Standby voltage
    https://www.veed.io/view/ab30c28b-6b...ingWidget=true
  • nomoresonys
    • 12268
    • U.S.
    Re: Samsung UE49KS7000SXXH - No standby light
    maybe unplug the cable from powerboard to mainboard and the backlight cable, plug the power cord in and see if you get a steady standby voltage then.
    • dskall
      • Oct 2016
      • 2905
      • usa
      I would check output diodes.
      • B0r1s
        • Jun 2022
        • 21
        • Serbia
        Just tried, same unstable stby voltage
        Which diodes are output ones on board?
        • nomoresonys
          • 12268
          • U.S.
          go ahead and check all the diodes on top of board, do the round ones first.
          • nomoresonys
            • 12268
            • U.S.
            they will have the stripe at one end, the others that resemble diodes without the stripe are ferrite beads not diodes. Meter set to diode put probe on each end, then switch probes, one way should read ol, other should read .5 or so.
            • nomoresonys
              • 12268
              • U.S.
              looks like you have 4 others on the heatsinks, probably will check like this video, when in doubt look up the datasheet: https://www.youtube.com/watch?v=1KVBZSTY7FE
              • nomoresonys
                • 12268
                • U.S.
                so maybe check dm851c, dm852c, dm853c and those 3 caps cm854, cm856, cm857.
                • nomoresonys
                  • 12268
                  • U.S.
                  a good clear picture like the one above but of the underside of board might help.
                  • B0r1s
                    • Jun 2022
                    • 21
                    • Serbia
                    I checked following diodes with 20K ohm settings.
                    4 big round ones:
                    DM862C - .004 and .004 both directions.
                    DM864C - .004 and .004 both directions.
                    DM863C - 1.679 in correct direction and 1 in opposite.
                    DM861C - 1.679 in correct direction and 1 in opposite.
                    DM851C, DM852C, DM853C:
                    negative lead on middle leg, positive on other legs: .484
                    positive lead on middle leg, negative on other legs: 1
                    Positive lead on first leg and negative on third leg and vice versa: .004
                    I measured this while board was detached from tv frame.
                    Diode problem? But which one?
                    • Diah
                      • Feb 2013
                      • 6435
                      put your power boards alone on the table with out any socket connect to it only the wall socket power it on and messure yours STB V.
                      • nomoresonys
                        • 12268
                        • U.S.
                        4 big round ones:
                        go ahead and recheck those but use diode mode.
                        • Diah
                          • Feb 2013
                          • 6435
                          his Post#1 99.9% er hat shorted LED BL
                          • nomoresonys
                            • 12268
                            • U.S.
                            could very well be but why no steady standby on powerboard?
                            • Diah
                              • Feb 2013
                              • 6435
                              because bl socket in place .. pcb keep click.. if it has tongue he will hear Helllllppppp
                              • B0r1s
                                • Jun 2022
                                • 21
                                • Serbia
                                I measured stby voltage with disconnected backlight socket like nomoresonys told me, and stby was still unstable.. i will try in few hours to test power board detached from tv frame with only power cable attached like you said so..
                                • B0r1s
                                  • Jun 2022
                                  • 21
                                  • Serbia
                                  Ok i rechecked these diodes with diode mode. I have these two multimeters at the moment, and measurements are different on each one. I don't know which one to trust.
                                  Multimeter MT111:
                                  DM862C - on each measurement multimeter is changing settings from diode mode to ohm resistance and i get values - 0 ohms.
                                  DM864C - same like with DM862C
                                  DM863C - red lead on anode, black on cathode - 0.284 / when i switch leads - 0.794
                                  DM861C - same like with DM863C
                                  negative lead on middle leg, positive on other legs: 0.125
                                  positive lead on middle leg, negative on other legs: values are dancing between 0.630-0.700
                                  Positive lead on first leg and negative on third leg and vice versa: it's switching to ohm resistance - 0 ohms
                                  Multimeter DT-830B:
                                  DM862C - 003 both directions
                                  DM864C - 003 both directions
                                  DM863C - 288 in correct direction and 1 in opposite
                                  DM861C - 288 in correct direction and 1 in opposite
                                  negative lead on middle leg, positive on other legs: 129
                                  Positive lead on first leg and negative on third leg and vice versa: 002
                                  Also i measured voltage while board was detached from tv, with only power socket connected, same unstable voltage.
                                  • nomoresonys
                                    • 12268
                                    • U.S.
                                    DM864C - 003 both directions: it looks like one or both of these is/are shorted, take one out of circuit and recheck it, if ok or bad recheck the other one in circuit to see if it's ok or not, maybe only one is bad.
                                    • B0r1s
                                      • Jun 2022
                                      • 21
                                      • Serbia
                                      Sorry for delay. I ordered quicko t12-942 from china, and I'm waiting for it to arrive. In the meantime i bought electric desoldering pump and took out two diodes, and yes one is shorted.
                                      On the diodes it is printed:
                                      LT6 | 23
                                      SB5 | 50
                                      Searching trough google i figured out that this is sb 550 schottky diode. I only found sb 560 diodes to buy.
                                      While testing sb 550 and sb 560 diodes out of circuit i get different readings in diode mode:
                                      SB550: 0.350
                                      SB560: 0.195
                                      So can i replace diodes with the new ones?
                                      • nomoresonys
                                        • 12268
                                        • U.S.
                                        I think you're good to go, maybe replace all 4 so they are the same, hope you got more than 2.
                                        • Kaar3l
                                          Samsung QLED QE65Q7FNAT only standby light
                                          by Kaar3l
                                          TV: Samsung QLED QE65Q7FNAT
                                          PSU: BN4400940A
                                          MB: BN94-12832K
                                          I got the tv in spring 2024. At that time it started, then ran 60 sec and poweroff. Seemed like reboot issue. I didn't have time and room to check it in summer so I plugged it in and now the standby light is on. I press button on remote, standby light goes off and tries to start?. No picture or backlight on LCD. I thought about removing diodes like in this thread: https://www.badcaps.net/forum/troubl...sung-qled-q60r...
                                          09-24-2024, 01:35 PM
                                        • m1ch43lzm
                                          by m1ch43lzm
                                          05-12-2025, 08:37 PM
                                        • ohren
                                          Upgrading a Samsung ue55nu7096u with logic board from an ue55ru7105k -- good idea?
                                          by ohren
                                          I hope this is the right forum to post in despite not technically being a repair, but still a question of swapping boards.
                                          I thought I'd explore the possibility to upgrade an existing working Samsung ue55nu7096u with the logic board (and power board if needed) of a newer model (ue55ru7105k) of the same size and appearance (and resolution). The reason being I'd like the extra inputs of that board including component in, an extra HDMI port and bluetooth. Its panel is broken so I have no use for the board otherwise.
                                          The models launched in 2018 and 2019 respectively....
                                          09-08-2023, 05:24 PM
                                        • howardc64
                                          by howardc64
                                          Problem
                                          08-04-2024, 10:36 PM
                                        • Michael Long
                                          No Standby Light on Samsung UN65MU6300FXZA with Mainboard BN94-12440E
                                          by Michael Long
                                          I had a Dead Samsung UN65MU6300FXZA with Mainboard BN94-12440E
                                          Dead / No Power / No Standby Light results after power company had three
                                          consecutive power outages on/off/on/off/on/off after which TV was rendered unresponsive.
                                          After exploring the issue found Mainboard was the fault. Then with research on this site determined IC1604 was the suspect. The IC1604 is a surface mounted device (SMD) EEPROM, Winbond Model 25Q40CLSIP. A read on this EEPROM came back with all FF FF FF FF FF in all registers blank and empty of data. I had a spare mainboard with intact IC1604 and utilized...
                                          09-13-2022, 06:55 AM
