Sony KD-55X8505 not able to start
  • PowerAmpFreak
    • 982
    • Sweden
    Sony KD-55X8505 plug it in, PFC starts up at 390VDC, DC/DC kicks on seem to supply mainboard with +12.7VDC.
    No led backlight, no supply to T-con...
    Any clue?
  • nomoresonys
    • 12214
    • U.S.
    Re: Sony KD-55X8505 not able to start
    do you get backlights with cable from powerboard to mainboard unhooked?
    • PowerAmpFreak
      • 982
      • Sweden
      No, when PSU/MB harness disconnected, the PSU is kept in standby.
      It's not like the Samsung's when full backlight will be on when cable disconnect.
      • dskall
        • Oct 2016
        • 2905
        • usa
        So what is ps-on, bl-on? Did you heat up processor?
        • PowerAmpFreak
          • 982
          • Sweden
          Heat up processor on MB ?
          BL_ON is low constantly. Independent of MB. PS_ON goes high and PSU starts up.
          Do you have the service manual or perhaps how the start-up sequence should be ?
          Also, no led activity at all. "Smells MB" ??
          I tried to force BL_ON high to +3V3 (first disconnect that wire to MB) but there is no led outputs wakes up...
          • nomoresonys
            • 12214
            • U.S.
            as long as you're sure, I had an old kdl sony from 2010 that does same as samsung, so it's NOT just the samsungs that self test in that manner, not saying you're wrong, just saying it isn't only samsungs that have that feature.
            • PowerAmpFreak
              • 982
              • Sweden
              as long as you're sure, I had an old kdl sony from 2010 that does same as samsung, so it's NOT just the samsungs that self test in that manner.
              I believe you, but in this case MB has to pull PS_ON to high at least to power up the power. It seems to be the case also for the BL_ON, but I cannot at all be sure without a service manual or other advice.
              • nomoresonys
                • 12214
                • U.S.
                would probably have to test it as stand alone, using resistors, Diah knows a lot about that process, he helped me test my sony but I forgot the procedure, the memory is the first to go.
                • PowerAmpFreak
                  • 982
                  • Sweden
                  Anyone know how to test the PSU standalone ?
                  • Diah
                    • Feb 2013
                    • 6417
                    yours TV android. so MB need 12V always on like any android STB box / reciever.......to test the PSB als stand alone. you need external stepdown circuit but in case you don't have one. you can use the MB stepdown circuit. you need to unplug the socket between PSB & MB from MB side.. and just bring one wire from PSB 12V which STB and feed it to the assigned pins at MB socket. look after DC to DC on MB you will find the 3.3V there.. use it to power the PSB as you like.. don't forget BL_ON need DiM pin active too.
                    • PowerAmpFreak
                      • 982
                      • Sweden
                      In this set, it appears MB only needs 3V3 as STBY.
                      I did disconnect cable between PSU and MB on MB side and pulling PS_ON and BL_ON to 3V3, but I never did with DIMMER so will try again.
                      New try:
                      BL_ON
                      PS_ON
                      DC_DIM
                      all connected to 3V3 does not generate any backlight.
                      Also, 12V T-CON is not on.
                      • nomoresonys
                        • 12214
                        • U.S.
                        a backlight tester would be handy in this instance, about 20 bucks on ebay or amazon.
                        • Diah
                          • Feb 2013
                          • 6417
                          always photo on the whole back and the PSU socket pins map will be helpfull if t-CON recieve 12V from PSU direct or via MB. if its from PSU then should have pins like T-CON on
                          first post you wrote 12V only come to MB so the MB have DC/DC stepdown to producse 3.3V which you take it for test
                          • PowerAmpFreak
                            • 982
                            • Sweden
                            Attach pictures.
                            12V T-Con is coming directly from PSU.
                            PSU generates +63V to dual boost converters to generate led backlight voltage. But boost converters are off.
                            No led is flashing.
                            PSU generates PFC voltage of 393V and 12V output is 12.7V.
                            STBY supply is 3.5V
                            • nomoresonys
                              • 12214
                              • U.S.
                              this tv is 8 years old or so, I would suspect backlights.
                              • Diah
                                • Feb 2013
                                • 6417
                                yours photo
                                so now its clear you have 3.3V STB.
                                STB- with Power On you will have REG12V this must be inplace to do further
                                STB with T_CON ON you will have T-CON VCC12V
                                STB with BL_ON will post BL
                                PM Dimmer need R as its low or high
                                • PowerAmpFreak
                                  • 982
                                  • Sweden
                                  yours photo
                                  Todays test:
                                  3V3 STB connect to PS_ON will make REG12V @ 12.7VDC
                                  3V3 STB connect to TCON_ON will make T-CON @ 12.7VDC
                                  3V3 STB connect to BL_ON does not change anything.
                                  3V3 STB connect also to DC_DIMMER does not change anything.
                                  I would suspect the boost converters to go active? At this point I have not applied anything to PWM DIMMER points.
                                  • Diah
                                    • Feb 2013
                                    • 6417
                                    Todays test:
                                    yours PSU look fine.. put all sockets as it should and capture the V on BL sockt between each group of LED+ & LED- at start up ( boot ) check the high and low messurments to compare the groups reading after you finish the test.
                                    • PowerAmpFreak
                                      • 982
                                      • Sweden
                                      During boot, the maximum voltage applied from led driver is 63V (two outputs). I think I could power up each led group by a separate powersupply capable of 120V current limited ?
                                      • Diah
                                        • Feb 2013
                                        • 6417
                                        you have BL_error on the sockt. if its goes high at boot then you need to be ready for the hard work BL LED
                                        • mmartell
                                          Sony KDL-65W850C is this a Mainboard issue ??
                                          by mmartell
                                          This sat around for quite some time after the backlights died with the six blink error code. I bought replacement strips and eventually swapped them in.
                                          Backlights appear to be working fine now. However the tv only powers on with the "Sony" logo for about two seconds after which it goes away and the panel with backlights stay powered for about twenty more seconds then it shuts off. Tv can only be powered again after power cycling at the outlet.
                                          It will not program via usb, the stick flashes but there is never any indication that it has entered programming...
                                          11-19-2023, 10:27 AM
                                        • TerraPhantm
                                          Sony A8H to A80J mainboard upgrade possible?
                                          by TerraPhantm
                                          I have a Sony 65A8H. Always bothered me that it doesn't have HDMI 2.1. I noticed the A80J board appears quite similar. And comparing some wiring diagrams in the service manuals (albeit A9G vs A90J since I couldn't find the A8/80 manuals), things appeared quite similar. And my understanding is the panels between the two TVs are more or less the same.
                                          So I decided I'd experiment a little bit.
                                          I bought an A80J board. Left the speaker connection unplugged because it doesn't fit. Changed the power connector to fit the new board. Plugged in everything else.
                                          When...
                                          08-15-2023, 08:10 AM
                                        • noinimod
                                          Sony 55X900E no standby light, no power. Replaced mainboard already
                                          by noinimod
                                          No standby red light, nothing
                                          This Sony has a separate AC->DC power adapter supplying 19.5V to the TV power board (JK3)
                                          Disconnected JK3 power board from main board, checked voltages on all the pin outs
                                          At a few pins I can see the power supply providing 19.5V to the main board
                                          Based on the service manual triage.. it seems to be pointing towards the power board (JK3) being the most possible culprit
                                          LED light turns on when I disconnect LED driver board ribbon from mainboard (so i thought it is the mainboard,...
                                          12-22-2021, 12:58 AM
                                        • Carlos#2003%
                                          Schematic de una Sony VAIO PCG-41217u, Sony VPCSB45FL (MBX-237), 1p-0117j01-a012 mbx-237.
                                          by Carlos#2003%
                                          Buenas mi nombre es carlos me uni al foro porque estoy buscando el schematic de una sony vaio pcg-41217u otras formas de escribirlo son 1p-0117j01-a012 mbx-237 numero de placa revision 1.2 o Sony VPCSB (MBX-237), en fin me gustaria y ayudaria un monton si alguien me puede dar dichi svhematic para hacer las mediciones de una laptop de la mencionada anteriormente(Sony VAIO PCG-41217U) con el fin de repararla dejo de funcionar solo prende el led de la bateria al pulsar el boton de power el disco empiesa a hacer ruido de actividad pero los leds del frontas no reflejan acividad y no enciende la pantalla....
                                          02-15-2024, 07:52 PM
                                        • dkneyle
                                          Sony KDL-46HX850 Can't upgrade/update firmware
                                          by dkneyle
                                          Diagnosed this TV as having a failed main board which I've replaced with one from a KDL 55HX850. They are (supposedly) the same board.
                                          Being 'Smart TV' it requires a firmware reboot when you swap out boards such as T-Con or main board. It starts with a black screen and flashing yellow and green LEDS, indicating it needs that firmware boot. The procedure described all over the web is to put the software into the root directory of a FAT32 formatted USB drive and it should load that up once plugged into USB1 port. But not for me. I can see the LED on the USB chip flash for about...
                                          09-25-2024, 10:44 PM
