Request for A2115 iMAC 2020 5K schematics
  • mon2
    • Dec 2019
    • 14677
    Hi. Have a request for schematics / boardview files for this model. Will check the logic board # once at the office but unit has been toyed with another repair shop and has no power. No onboard LEDs so suspecting the 300W Delta power supply is defective after a power brown out event.
    Have another confirmed good power supply in transit for testing later today / tomorrow.
    Will appreciate any feedback and schematics, if available.
    Thanks.
  • mon2
    • Dec 2019
    • 14677
    Re: Request for A2115 iMAC 2020 5K schematics
    Update: Logic Board 820-01779-A
    1) replacement 300W power supply arrived from Amazon - it is a generic 300W unit that is NOT Delta and is NOT LiteON but looks identical. Sold by ICTION from Shenzhen whom we have used for assorted products with success. The cost was very fair to buy it locally and was received the next day.
    Bad news: The fault of this 2020 iMAC 5K is NOT the power supply.
    The unit does not show any sign of life / no leds / no fan spin after a brown out event. Probing assorted caps and each is with 0 volts. 12VDC does indeed enter the logic board through the molex cable harness.
    Will review with the original power supply after this setup shows some sign of life.
    2) After watching this great video:
    https://www.youtube.com/watch?v=GIHSyamWnh4
    have the logic board out. Was not as elgant of a procedure as shown in the video but it is out.
    3) Found that the ACE controller onboard is the CD3218 x 2 on this logic board. That is a new one to me. Next thorn in the ACE line of devices.
    4) So far, unable to locate the schematics so will compare against the A1419 schematics which shows that there is a voltage regulator to create the PPBUS_G3H. Work for tomorrow.
    • grmac5
      • Dec 2020
      • 5
      I have an iMac with exact same problem. Just died. I thought would be Power supply but opened and no LED on but yet PowerSupply is sending 12V. Checked mine with infrared while in the housing and nothing getting hot on screen side anyway. Wondering if this could be a T2 issue? Thinking of trying to restore DFU. Not sure if that makes sense.
      • grmac5
        • Dec 2020
        • 5
        I ended up finding a shorted Cap on the backside of the board. One of the big coils at the bottom of the board (above the 3v3 coil) was shorted direct to ground. Pulled the coil and diode checked which side. Applied very low voltage and discovered nearby cap was getting hot. Replaced it and mine is running again.
        • mon2
          • Dec 2019
          • 14677
          Thanks for your feedback @grmac5. Have not had time to revisit the repair but will inspect before Friday. Will update the thread once there is a resolution.
          • mon2
            • Dec 2019
            • 14677
            Just got back to this repair. Found a shorted cap on the 5v rail. Replaced it and now can confirm that the rail is without the 0R4 (0.4 ohms) to ground short.
            Applied a known good power supply -> 12v from the power supply is fine and reaches the logic board. No other power rail is showing in the testing.
            Will appreciate if anyone has schematics or bv files for this model. Will continue to compare against the older models as this logic board appears to be similar.
            The very first DEBUG LED is not ON which denotes that the AC is plugged in. This LED is powered from (using older schematics), the PP3V3_S5 rail so we can logically assume that this rail is not available. This rail (from older schematics) is based on the ISL6238 which also supplies the PP5V_S4_REG and this 5v rail is also missing. Will investigate to see if this common regulator is onboard and its status.
            • smzlwan223
              • Mar 2022
              • 20
              • 中国
              通用领域
              生物医药
              试试文档翻译
              A2115,初步看了你的维修过程,这个机器的上电时序的先弄明白,要不然,修起来很吃力,虽然这款机器没有电路图点位图,但是可以很确定的是,大致的上电流程和以往的机器差不了多少,1,待机部分,也就是主板4个灯第一个灯,灯亮代表,主板待机正常,维修修这个部分,可以参考,A2159主板待机部分来修,因为,T2,与A2159类似。待机上电时序,大概是,1,公共端12v正常之后,给3.3v,待机IC供电,输出3.3v,再给T2主电源供电,T2电源再输出,相应的电压,如果是后继有短路,就会保护没有电压输出,你维修的时候,可以用可调电流表,来修复图,把电压调制为12V 电流最好是10A,当然前提测试12V公共端,是否有短路。希望能帮到你!
              A2115, after a preliminary look at your maintenance process, you should first understand the power on timing of this machine. Otherwise, it will be very difficult to repair. Although this machine does not have a circuit diagram and a bitmap, it can be sure that the general power on process is not much different from that of previous machines. 1. The standby part, that is, the first light of the four lights on the mainboard, means that the mainboard is in normal standby. This part can be referred to for maintenance, The standby part of the a2159 mainboard is repaired because T2 is similar to a2159. Standby power on sequence, probably after 1, common terminal 12V is normal
              • mich6el
                Imac 2020 a2115 no image after reblays T2 Security chip
                by mich6el
                Hello! Has anyone encountered problems on the Imac 2020 27 inches with a T2 chip? I had to replace 2 T2 chips on two iMacs, the first one was successfully replaced, tested and given to the client. The second iMac after replacing the T2 is flashed, the system is installed through the target mod, it boots into the system, you can hear me tapping on the keyboard, but the image does not display (and to an external monitor​). I reballed the T2 chip, changed the processor, RAM, display. No positive result! My friend said that he had 2 such devices and on both of them, after replacing the T2 boards,...
                04-22-2025, 02:05 PM
              • Stephen
                iMac 27” 2020 Boot issue
                by Stephen
                Customer came in for data recovery, came to find out data is soldered on to this iMac (learn something new everyday) this is a 2020 T2 iMac so I was surprised because the iMac Pro has a T2 chip and it isn’t soldered on. Anyways, the iMac boots to Apple logo and then restarts, before it turns off you hear a quarter fan spin then it repeats itself. I decided to do a DFU revive to restore any hardware firmware issues and it was successful in reviving the device however the issue persists in boot looping. It shows the Apple logo for like 40 seconds then turns off and fan spin rinse repeat. I...
                08-16-2024, 09:32 AM
              • premanpurimas
                Please help. need clean me region for iMac A2115 EMC 3194 27 inch 5k 2019
                by premanpurimas
                Hi friends.
                Please help to clean me for this bios file of iMac 27" 5K 2019 (A2115 EMC 3194)
                Board number 820-01236.
                Pulled the bin file that i attached in this post from a normal same model iMac
                But with that file in my current iMac always restarting after several minutes of operation.
                And also i already tried several method to clean the me region of this file, but always end up with file system state "error" at ME Analyzer.
                Any help would be appreciated.
                Thanks in advance...
                01-17-2024, 12:47 AM
              • applejuice95
                A2115 - 820-01779-3 (2020)
                by applejuice95
                Hi there, I currently have similar board with same problem. A2115 - 820-01779-3 (2020). New to Soldering and board diag.. We've located many shorted Caps using voltage injection and thermal.. This board is reading open circuit on Caps C7261-C7250 along with any other components on the PP12V_G3H_CPUCORE rail.. I however get no glowing component on the front or rear of the board.. Each of these Caps reads less than a V or Resistance when measuring directly across each one, and also beeps to ground on both sides on all of them.. This should be shorted correct? Is 1V-1.5V / 2A-5A injection to locate...
                01-22-2025, 08:25 AM
              • Eleways
                Imac 27" A2115
                by Eleways
                Hi there,
                I've an Apple iMac 2019 model A2115. Sometimes works fine, but many time doesn't works, the fan spinning but no chime e no video output.
                The diagnostic Led (3+2) are the same: 1-off 2-on 3-on 4 off 5 on
                Any idea?
                Ty ...
                05-17-2024, 05:51 AM
