A2115 - 820-01779-3 (2020)
  • applejuice95
    • May 2023
    • 49
    Hi there, I currently have similar board with same problem. A2115 - 820-01779-3 (2020). New to Soldering and board diag.. We've located many shorted Caps using voltage injection and thermal.. This board is reading open circuit on Caps C7261-C7250 along with any other components on the PP12V_G3H_CPUCORE rail.. I however get no glowing component on the front or rear of the board.. Each of these Caps reads less than a V or Resistance when measuring directly across each one, and also beeps to ground on both sides on all of them.. This should be shorted correct? Is 1V-1.5V / 2A-5A injection to locate the short too low? Should we inject higher voltage?
  • reformatt
    • Feb 2020
    • 1547
    https://www.badcaps.net/forum/troubl...r-s-guidelines
    Review beginners guidelines. Low ohms on CPU Vcore is normal and new comers will often believe it's a short. Your fault is likely elsewhere.
    • Tynan Dill
      by Tynan Dill
      Assuming...
      11-22-2024, 01:46 PM
    • m1ch43lzm
      by m1ch43lzm
      05-12-2025, 08:37 PM
    • howardc64
      by howardc64
      07-24-2025, 05:17 PM
    • thedude943
      820-01869 (iPhone SE 2020) Board View
      by thedude943
      I am working on an iPhone SE 2020 motherboard. I am hoping someone is able to provide a close-up to help me better see what this section is supposed to look like. I am including my digital microscope images. I am also looking for schematics. This is a v3 board I believe, and my schematics are for a v1 board only. You see this burned out area. Are you able to provide a digital microscope image for me of this section (problem area)?
      Thank you!
      Problem area:
      Front
      06-23-2025, 02:13 AM
    • Hakuu
      by Hakuu
      Hi There,
      More Details
      TV Model - LG OLED77G1PUA
      07-12-2023, 02:37 PM
