Imac 2020 a2115 no image after reblays T2 Security chip
This topic has been answered.
  • mich6el
    • Dec 2015
    • 18
    • Ukraine
    Hello! Has anyone encountered problems on the Imac 2020 27 inches with a T2 chip? I had to replace 2 T2 chips on two iMacs, the first one was successfully replaced, tested and given to the client. The second iMac after replacing the T2 is flashed, the system is installed through the target mod, it boots into the system, you can hear me tapping on the keyboard, but the image does not display (and to an external monitor​). I reballed the T2 chip, changed the processor, RAM, display. No positive result! My friend said that he had 2 such devices and on both of them, after replacing the T2 boards, they either did not boot into the system or showed artifacts.Maybe this board has a factory defect? ​​Who has encountered this?
  • Answer selected by mich6el at 04-23-2025, 02:39 AM.
    noipi
    • Aug 2017
    • 85
    • Singapore
    i have almost same problem, but for me i replaced another t2 chip instead of i reballed it...try to replace a new one again
    • noipi
      • Aug 2017
      • 85
      • Singapore
      • mich6el
        • Dec 2015
        • 18
        • Ukraine
        I returned my native t2 chip, but there is still no image.​
        • acedogblast
          by acedogblast
          11-02-2024, 05:13 PM
          Common SPI bios chip programming Questions and Answers
          by SMDFlea
          Q: I have a bios request,i can`t post my backup as i can`t read from the chip.
          A: If you can`t read from it how do you expect to write to it ?.
          Q: Why is my bios chip unreadable ?.
          A: The programmer is faulty or has a worn or broken zif socket.
          The USB cable is frayed,connector pins worn or some other physical damage.
          Not enough amperage or voltage to power the programmer properly.
          Bad...
          09-02-2021, 04:40 PM
        • DynaxSC
          ASRock B650M PRO RS - BIOS CHIP 25Q256JW BLOCKED BY STATUS REGISTERS
          by DynaxSC
          Hi
          I have then desoldered the chip, backupped the contents, and tried to earease the chip in order to program stock image, but the chip is locked by status registers SREG2 (TB) and SREG6...
          08-04-2025, 12:20 PM
        • BMCappelletti
          Asus Chromebox CN62 - wrong chip put on BIOS reader
          by BMCappelletti
          Long story short:
          - dad converted Asus Chromebox CN62 into Windows compatible, with mrchromebox BIOS, years and years ago
          - gave the computer to his son a couple years later
          - son now decided to revert it to Chrome OS, to sell it as original (re-writing BIOS with the backup one created by his dad)
          - too lazy to remove the board from the case, thought a voltage regulator was the BIOS chip (you know... it has 8 legs)
          (seems like the story was not that short)
          He used alligator clips to read the chip. No luck reading it. Removed chip and placed on a SOC-8...
          01-08-2025, 07:27 PM
        • premanpurimas
          Please help. need clean me region for iMac A2115 EMC 3194 27 inch 5k 2019
          by premanpurimas
          Hi friends.
          Please help to clean me for this bios file of iMac 27" 5K 2019 (A2115 EMC 3194)
          Board number 820-01236.
          Pulled the bin file that i attached in this post from a normal same model iMac
          But with that file in my current iMac always restarting after several minutes of operation.
          And also i already tried several method to clean the me region of this file, but always end up with file system state "error" at ME Analyzer.
          Any help would be appreciated.
          Thanks in advance...
          01-17-2024, 12:47 AM
