Go Back   Badcaps Forums > Troubleshooting Hardware & Devices and Electronics Theory > Troubleshooting Game Consoles & Other Weird Devices
Old 05-31-2018, 08:41 AM   #1
johnboy1313
City & State: Midwest
Default EGO 56V electric lawnmower, blown 40A 250V fuse
Good morning. I'm working on an EGO brand 56V electric lawnmower like this one.
https://www.homedepot.com/p/EGO-21-i...02SP/206515944
I found the 40A 250V ceramic fuse to be blown. I temporarily jumped it with a 35A blade fuse and it powered on and worked.
The fuse in question is a Schurter SUT series slow-blow fuse with pigtails for through hole mounting. When I look up the SUT series of fuses, they only show a range of 12A-30A. Iím having trouble finding an appropriate fuse. I donít have the knowledge to find a suitable replacement on my own.
Here is the data sheet for the SUT series of fuses.
https://www.schurter.com/en/datashee...SUT_6.3x32.pdf
I don't really care if the fuse has the same package as long as it works the same. I don't have the mower in front of me at the moment, but the PCB that the fuse was mounted to has pads for a smaller surface mount fuse if I could find one of the appropriate size. I'll measure the distance from pad to pad when I get back to the mower.
In the time being, I would really appreciate it if any of you with a better understanding could help me out.
Thanks guys.
johnboy1313 is offline   Reply With Quote
Old 06-01-2018, 07:17 PM   #2
CapLeaker
Leaking Member
CapLeaker's Avatar
City & State: Atlantic Canada
My Country: Canada
Line Voltage: Ground, 0Hz
I'm a: Hobbyist Tech
Default Re: EGO 56V electric lawnmower, blown 40A 250V fuse
The only thing that Digikey has that is similar is this: https://www.digikey.ca/product-detai...785-ND/2518690
However, this is a fast blow, not a slow blow...
Or this:
https://www.digikey.ca/product-detai...792-ND/2515916
https://www.digikey.ca/product-detai...0801-ND/701068
These are a slow blow.
I'd probably change the fuse holder to accept blade fuses and take a bunch of those fuses of the last link.
Old 06-01-2018, 08:55 PM   #3
budm
budm's Avatar
City & State: S.F. Bay area
Line Voltage: 120V 60Hz
Can we see the circuit board that the fuse is soldered on to?
Old 06-02-2018, 04:11 AM   #4
stj
stj's Avatar
City & State: Europe
if you can mount it, how about using a domestic circuit breaker??
or use the fuses sold for car audio.
Old 06-02-2018, 09:30 AM   #5
momaka
momaka's Avatar
City & State: VA (NoVA)
My Country: U.S.A.
Line Voltage: 120 VAC, 60 Hz
I don't know if either of those would be a good idea.
Looking at the product from the link in post #1, this appears to be battery operated (Li-ion) @ 56V. This means car fuses may not be a good idea, as the DC voltage is quite a bit higher and may arc-over badly in case of a quick-blow / disconnect event.
Likewise, a house breaker is rated for AC current, so again, I'm not sure if disconnecting high-current DC voltage would do it any good.
It's best to go with same rating and type of fuse. Of course, if you cannot find the same package / size of fuse but can otherwise match the current, voltage, and type of fuse, then going with a different package is okay - even if you run the fuse with thick wires / leads to get it connected properly.
Old 06-02-2018, 12:03 PM   #6
johnboy1313
I found a Bussman 3AG glass fuse that should work. MDL-40. The data sheet only goes up to 30A. I'll have to mount the fuse a little differently as the replacements don't have any leads.
https://www.mouser.com/datasheet/2/8...ies-335847.pdf
I've attached a pic of the board.
Old 06-02-2018, 01:43 PM   #7
stj
stj's Avatar
the car audio fuses i'm talking about are big glass ones - they sometimes show up in other places like my old UPS.
not regular blade fuses.
Old 06-02-2018, 03:09 PM   #8
sam_sam_sam
City & State: Sunny Jacksonville FL
Line Voltage: 120 Volts 60 HZ
Originally Posted by CapLeaker View Post
Thank for posting this I need something like this for a cooling fan for a machine at work
I looked at what Little Fuse has in that type of fuses the lowest amperage fuse is 30 I need a 15 amps ones
Originally Posted by johnboy1313 View Post
This is in response to what you posted above
If it were me
I would use this one and do away with the pcb board and fuse holder
9 PC LCD Monitor
6 LCD Flat Screen TV
10 Desk Top Power Supply
1 Dell Mother Board
15 Computer Power Supply
1 Over Head Crane Current Sensing Board
All of these had CAPs POOF
sam_sam_sam is offline   Reply With Quote
Old 06-03-2018, 07:20 AM   #9
CapLeaker
Leaking Member
CapLeaker's Avatar
My Country: Canada
If it were me
you're welcome!
Old 06-03-2018, 02:07 PM   #10
johnboy1313
Thanks for the help guys I'll report back once it's working again
Old 06-03-2018, 05:50 PM   #11
budm
budm's Avatar
You have room on the PCB you can use this one:
https://www.homedepot.com/p/Cooper-B...R-40/100170316
Just wrap and solder solid wire to each eand.
Old 06-07-2018, 09:31 PM   #12
tibimakai
City & State: Los Angeles/San Dimas, CA
Line Voltage: 120VAC 60Hz
This maybe useful for me as well, I have the same mower, but it haven't fail yet.
Why this fuse may have failed in the first place?
tibimakai is offline   Reply With Quote
Old 06-08-2018, 05:26 AM   #13
stj
stj's Avatar
a good question.
Old 06-08-2018, 05:37 AM   #14
johnboy1313
He said he was mowing wet, tall grass when it quit working.
Old 06-08-2018, 12:18 PM   #15
stj
stj's Avatar
well if the extra load took out the fuse, it didnt have much headspace!!
Old 06-08-2018, 12:36 PM   #16
johnboy1313
It would seem that way.
Old 06-27-2018, 02:12 PM   #17
johnboy1313
Thanks CapLeaker. I went with the first link after the "40A 250V" fuses I ordered on eBay turned out to be 40A 32V fuses. It's working again.
Old 06-29-2018, 08:42 PM   #18
CapLeaker
Leaking Member
CapLeaker's Avatar
My Country: Canada
A1! I like seeing things work again!
Badcaps.net Technical Forums © 2003 - 2018
Copyright ©2000 - 2018, Jelsoft Enterprises Ltd.
