EGO 56V electric lawnmower, blown 40A 250V fuse
  • johnboy1313
    • Nov 2012
    • 1959
    Good morning. I'm working on an EGO brand 56V electric lawnmower like this one.
    https://www.homedepot.com/p/EGO-21-i...02SP/206515944
    I found the 40A 250V ceramic fuse to be blown. I temporarily jumped it with a 35A blade fuse and it powered on and worked.
    The fuse in question is a Schurter SUT series slow-blow fuse with pigtails for through hole mounting. When I look up the SUT series of fuses, they only show a range of 12A-30A. I'm having trouble finding an appropriate fuse. I don't have the knowledge to find a suitable replacement on my own.
    Here is the data sheet for the SUT series of fuses.
    https://cdn.badcaps-static.com/pdfs/...21042e2a76.pdf
    I don't really care if the fuse has the same package as long as it works the same. I don't have the mower in front of me at the moment, but the PCB that the fuse was mounted to has pads for a smaller surface mount fuse if I could find one of the appropriate size. I'll measure the distance from pad to pad when I get back to the mower.
    In the time being, I would really appreciate it if any of you with a better understanding could help me out.
    Thanks guys.
  • CapLeaker
    Leaking Member
    • 8352
    Re: EGO 56V electric lawnmower, blown 40A 250V fuse
    The only thing that Digikey has that is similar is this: https://www.digikey.ca/product-detai...785-ND/2518690
    However, this is a fast blow, not a slow blow...
    Or this:
    https://www.digikey.ca/product-detai...792-ND/2515916
    https://www.digikey.ca/product-detai...0801-ND/701068
    These are a slow blow.
    I'd probably change the fuse holder to accept blade fuses and take a bunch of those fuses of the last link.
      Can we see the circuit board that the fuse is soldered on to?
        • 31302
        if you can mount it, how about using a domestic circuit breaker??
        or use the fuses sold for car audio.
          master hoarder
          • May 2008
          • 12175
          • Bulgaria
          I don't know if either of those would be a good idea.
          Looking at the product from the link in post #1, this appears to be battery operated (Li-ion) @ 56V. This means car fuses may not be a good idea, as the DC voltage is quite a bit higher and may arc-over badly in case of a quick-blow / disconnect event.
          Likewise, a house breaker is rated for AC current, so again, I'm not sure if disconnecting high-current DC voltage would do it any good.
          It's best to go with same rating and type of fuse. Of course, if you cannot find the same package / size of fuse but can otherwise match the current, voltage, and type of fuse, then going with a different package is okay - even if you run the fuse with thick wires / leads to get it connected properly.
          • johnboy1313
            • Nov 2012
            • 1959
            I found a Bussman 3AG glass fuse that should work. MDL-40. The data sheet only goes up to 30A. I'll have to mount the fuse a little differently as the replacements don't have any leads.
            https://cdn.badcaps-static.com/pdfs/...e500281c7a.pdf
            I've attached a pic of the board.
              • 31302
              the car audio fuses i'm talking about are big glass ones - they sometimes show up in other places like my old UPS.
              not regular blade fuses.
                • Jul 2011
                • 6070
                Thank for posting this I need something like this for a cooling fan for a machine at work
                I looked at what Little Fuse has in that type of fuses the lowest amperage fuse is 30 I need a 15 amps ones
                Originally posted by johnboy1313
                This is in response to what you posted above
                If it were me
                I would use this one and do away with the pcb board and fuse holder
                • CapLeaker
                  Leaking Member
                  • 8352
                  If it were me
                  you're welcome!
                  • johnboy1313
                    • Nov 2012
                    • 1959
                    Thanks for the help guys I'll report back once it's working again
                      You have room on the PCB you can use this one:
                      https://www.homedepot.com/p/Cooper-B...R-40/100170316
                      Just wrap and solder solid wire to each eand.
                      • tibimakai
                        • Jan 2012
                        • 3680
                        This maybe useful for me as well, I have the same mower, but it haven't fail yet.
                        Why this fuse may have failed in the first place?
                          • 31302
                          a good question.
                          • johnboy1313
                            • Nov 2012
                            • 1959
                            He said he was mowing wet, tall grass when it quit working.
                              • 31302
                              well if the extra load took out the fuse, it didnt have much headspace!!
                              • johnboy1313
                                • Nov 2012
                                • 1959
                                It would seem that way.
                                • johnboy1313
                                  • Nov 2012
                                  • 1959
                                  Thanks CapLeaker. I went with the first link after the "40A 250V" fuses I ordered on eBay turned out to be 40A 32V fuses. It's working again.
                                  • CapLeaker
                                    Leaking Member
                                    • 8352
                                    A1! I like seeing things work again!
                                    • Babbar
                                      by Babbar
                                      04-12-2024, 01:12 AM
                                    • drscoot
                                      HP X360 convertible battery blown fuse error, not charging
                                      by drscoot
                                      HP Modelnumber: 14-dh0061nb​
                                      This laptop had a shorted cap on a Vcore section. After replacement is works again. But there is still a battery issue.
                                      The battery is HT03XL and with the built-in component test from HP, in the Power section, I get an error: Logic State: Calibration required (20), Charge state: Blown Fuse (42)
                                      I have another same battery, also with error: Logic State: Very Weak (70), Charge state: Blown Fuse (42)
                                      And a third battery TF03XL (looks identical) with error: Logic State: OK (0), Charge state: Blown Fuse (42)
                                      All these 3 batteries are charging...
                                      12-15-2023, 05:54 AM
                                    • beetle1303
                                      Carver CM-1090 - Power relay clicking on & off, then fuse blown after 20-30 seconds of power cycling.
                                      by beetle1303
                                      I gotten a Carver CM-1090 amplifier from a friend who has kept it in storage for decades. Opened it up, thick layer of dust cumulated everywhere. Vacuumed it semi-cleaned, and blown off as much as possible the remaining dust. This is a 220V version.
                                      On initial powered up with nothing connected - it works with all the lights and button indicator lit up as pressed, etc. I then powered off, connected a CD player into the CD RCA input and powered it on. It seemed to work for a short while and when I turned the volume up and down to see the the VUs works, the power started to clicked off...
                                      01-13-2025, 08:49 PM
                                    • jesterace
                                      Samsung UE46ES8000 Blown fuse but no other signs of short
                                      by jesterace
                                      Hi I wonder if anyone might be able to steer me in the right direction. I have this Samsung UE46ES8000 TV and it went bang during use. The main fuse on the PSU board is open. I've checked every diode/mosfet/transistor I can see and nothing appears to be short to cause the fuse to go. The DC output of the bridge rectifier is not short either. I've seen online that some of these models are known for having their PFC mosfet or other mosfets shorting and blowing the fuse but i'm not seeing that here. If anyone aware of these models having any issues to cause this? I'm reluctant to just replace the...
                                      09-11-2024, 03:14 PM
                                    • whc14765
                                      Gigabyte 980TI Windforce - Blown PCIE Fuse
                                      by whc14765
                                      Hey,
                                      I have a Gigabyte 980TI Windforce. No shorts on the main 8 pin PCIE power connectors. The 8 phase buck converter inductors are showing 2.5ohms.
                                      The card doesn't power up at all - no lights, no fans, nothing. I noticed that all of the 8 phase inductors are showing 0V. I couldn't find a fuse for the 8pin power connectors.
                                      I did notice that the PCIE x16 connector 12V line has a fuse F3 (10A marked on it) which is blown. It is reading 16ohms on one end.
                                      1st Question: Is there some logic on the board that checks the 12V on the PCIE x16 bus connector...
                                      04-08-2022, 06:22 PM
