vizio vp50
    Re: vizio vp50
    The test is not sufficient, as you do not have cycling outputs, you have -low- outputs. These components very rarely fail shorted, they tend to drift instead.
    You need to set it up with 1kohm resistor from 35V~5V to K, then connect K-R, you should measure 2.495V +/- 2% across A-K.
    • heavymachines
      • Mar 2011
      • 1028
      Re: vizio vp50
      =tom66;304806]The test is not sufficient, as you do not have cycling outputs, you have -low- outputs. These components very rarely fail shorted, they tend to drift instead.[/QUOTE]
      so to make sure we are on same page, your saying because i have low voltage output on power board, the tl431 may pass the bench dmm test but still can be bad because of leaking current from the tl431 thus causing "drift" in voltage..
      and it being right next almost butted to the heat sink probably cause this malfunction perhaps? likely scenario?
      You need to set it up with 1kohm resistor from 35V~5V to K, then connect K-R, you should measure 2.495V +/- 2% across A-K.[/QUOTE]
      I wish i knew exactly what your saying,,, how to set the 1kohm and k-r etc...is there a demo how to do this ? i mean via youtube or net somewhere.. i am kind of a hands on person once i do it and understand what i am doing...the more i like doing it... still quite green horn in comparison to many on this forum..
        Re: vizio vp50
        No, I am saying that you have low outputs for some reason.
        I don't know why but it could be the TL431.
        The best thing to do is to test the TL431 using the method I described, so it can be ruled out.
        All I know is these LGs had a batch of dodgy xx431 and it was causing my problem with an LG plasma -- clicking on and off, no power. I bypassed the opto but a TV friend of mine told me it's a common issue and the proper fix is to replace the 431.
        • heavymachines
          • Mar 2011
          • 1028
          Re: vizio vp50
          i tried edit the post and its not highlighting your statements apologies ahead of time..
            Re: vizio vp50
            Can you get hold of a breadboard?
            http://www.ebay.com/itm/Red-Solderle...item5651cbea9d
            You can put the component on it and wire it up. All the columns (except for at the break) are connected to each other.
            • heavymachines
              • Mar 2011
              • 1028
              Re: vizio vp50
              okay just so you know it's a samsung.. but i guess very possible samsung got some dodgy ones as well.. being a brand specific TL431
              okay i will do that test will be monday when i get back to the rest of the tv..
                Re: vizio vp50
                Yeah budm pulled one from a Samsung monitor too, low rail voltages.
                • heavymachines
                  • Mar 2011
                  • 1028
                  Re: vizio vp50
                  Actually i think i can.. my cousin 15 miles from me has a big breadboard..their dad passed some time ago and he was a electronics engineer.. and they still have a lot of his equipment ..rat shack i imagine has some that's closer.
                  • heavymachines
                    • Mar 2011
                    • 1028
                    Re: vizio vp50
                    okay got a bread board and 1 k resistor... ready for instructions thanks for helping me and i am eager to learn...
                    its this one if it means anything http://www.radioshack.com/product/in...ductId=2734155
                      Re: vizio vp50
                      Plug in xx431 so it goes across multiple columns.
                      Pin 1 is the leftmost pin you see when you look at the device directly on label side front, curved side back.
                      Pin 2 is middle, pin 3 is rightmost.
                      Pin 1 goes to pin 2, use wire.
                      Pin 2 goes to ground, use wire to connect to rail at bottom of board.
                      Pin 3 goes through 1kohm resistor to positive supply, use rail.
                      You need a 5V~35V supply; a 9V battery, phone charger, lab power supply etc will all work.
                      Take photo of configuration before you turn it on.
                      • heavymachines
                        • Mar 2011
                        • 1028
                        Re: vizio vp50
                        never mind i found what you meant by
                        pin 1 reference (R)
                        pin 2 anode (A)
                        pin 3 cathode (k)
                        okay see what my results will be....and can use anywhere from 35 volts to 5 volts for input?
                          Re: vizio vp50
                          yes.
                          • heavymachines
                            • Mar 2011
                            • 1028
                            Re: vizio vp50
                            so i loop pin 3 with 1k resistor back to pin 1 use rail.. if i am understanding correctly?
                            • heavymachines
                              • Mar 2011
                              • 1028
                              Re: vizio vp50
                              never mind dumb question..
                              • heavymachines
                                • Mar 2011
                                • 1028
                                Re: vizio vp50
                                okay what you think for first try?
                                  Re: vizio vp50
                                  Looks good! Measure the voltage pin 3 (or opposite end of resistor, not end on positive rail) to ground.
                                  • Baileybum1234
                                    • Sep 2012
                                    • 245
                                    Re: vizio vp50
                                    Whats the white resistor looking thing guys?
                                    Repaired: LG50PQ6000
                                    • heavymachines
                                      • Mar 2011
                                      • 1028
                                      Re: vizio vp50
                                      okay the worn down 9 volt battery is outputting 7.64 volts
                                      measurement at pin 1 and 3 on tl431 is reading 7.64 volts
                                        Re: vizio vp50
                                        That is not right; is battery definitely the right way around?
                                        • heavymachines
                                          • Mar 2011
                                          • 1028
                                          Re: vizio vp50
                                          there is the 1k resistor with color bands and the white jumper wire in line with it as the white wire in this is positive in this setup... to the battery er power source...
                                          • u666sa
                                            HP Envy x360 13-bf0013dx (i7, 8gb) ipa32 la-m024p rev 1b short near PJ1802, type-c not switching to 19 volts
                                            by u666sa
                                            Laptop is HP Envy x360 13-bf0013dx, hp website link, it's an i7-1250U with 8 gig onboard ram.
                                            Platform: ipa32 la-m024p rev 1b
                                            Originally you'd plug power supply into it and it would take up to 1.2 amps and then drop to 200 milliamps and then go back up again to 1.2, staying all the while at 5 volts. Pressing power button would results in power LED blinking amber 3 times. 3.3 volt rail, 5.1 volt rail present, main power rail 8.8 volts. Power button test pads near EC chip 2.7 volts.
                                            I found a short on the other side:
                                            10-04-2025, 05:03 PM
                                          • mrtek
                                            Vizio M65-C1
                                            by mrtek
                                            Hi.
                                            picked up another TV. This time is a Vizio M65-C1. TV does not turn on. I had repaired another 60 inch vizio , Bad main board.
                                            When power button is pressed, the Power led indicator on the bottom right, turns for a few seconds and then it fades away. No backlight or Vizio logo on screen. Removed back cover and repeated test.
                                            This is the TV This TV is a little different from the Samsung I have worked on. Power supply is on the Left side, Main Bd is on the right side, T-CON , not in the picture is on the bottom. I am assuming that the boards in the middle are the LED...
                                            07-14-2025, 07:28 PM
                                          • supermattch
                                            HP 15dy-2021nr wont power on mystery volts
                                            by supermattch
                                            Hi everyone.
                                            I am diagnosing my personal laptop, because it wont power on and no leds light up.
                                            At the dc-in there are 8 pins, 1 and 2 shows healthy 19.66 volts. The next three are ground, but the 6th one shows .283 volts. This is strange to me, it should be 3.3 or 5 or aome volts not 0.283v. As I am new to this, I would like some guidance. Please someone advise me on what to check next.
                                            Oh the boardview and schematics I am using is for a similar model as I cannot find the proper one anywhere. Quanta DA0P5HMB8F1 rev F. Nowhere on the internet.
                                            09-23-2025, 12:13 PM
                                          • howardc64
                                            Vizio M65Q7-H1 Red Vertical Strips fixed by tape blocking LC1 signal to half of the panel
                                            by howardc64
                                            Failure Symptom
                                            No picture, just red vertical stripes. Google search shows quite common problem for these recent Vizio M series although red vertical stripe pattern may differ. Some call it "Netflix" boot screen haha.
                                            Where is the short?
                                            Panel has 4x buffer boards. Quickly found the 1/4 panel buffer board with the problem by selectively disconnecting buffer board flex cables.
                                            Having recently fixed another Vizio with similar symptoms that was a shorted ESD diode array ( link ) Probed the ESD diode array but...
                                            05-27-2025, 02:56 PM
                                          • MisterAIL
                                            PS5 digital / No Power / No Beep / Good power supply
                                            by MisterAIL
                                            Hi everyone,
                                            Brought a non functionnal PS5. Apparently only a bad PSU...
                                            No beep, nothing.
                                            After some tests i found this :
                                            - PSU is fine (12 volts stable)
                                            - 12 volts line is shorted
                                            - DA9065 was fried, F7003 also => Replaced both of them, short is gone on 12 volts line, no dead short anywhere else.
                                            - By the way, nothing change. No signal, no power, no beep.
                                            Mesuring all rails with my workbench psu (12 volts input)
                                            - 0.00 amp drawing
                                            - 12 volts, 5 volts, 2 volts, 1,15 volts are presents (suppose new DA9065 do is...
                                            03-12-2024, 03:24 PM
