Samsung 4K led model UE50NU7445U no picture
  • Diah
    • Feb 2013
    • 6614
    Re: Samsung 4K led model UE50NU7445U no picture
    yours Panel Taiwanese AUO. the driver board and the response to firmware (main boards action)are the one on the left side (if you look on the tv from the back with out cover) check if you have the 8 pin chips. write down its label and upload focused photo to the area around it over here in this forum .. please don't use external server for upload.
    • Davi.p
      Hobbist Tech
      • Sep 2009
      • 4544
      • Italy - Milan
      #42
      Originally posted by PowerAmpFreak
      I would assume there would be a unbalance if one of the led strips were bad, right ?
      it seems so.. this if the lamps are lit...
      • PowerAmpFreak
        • 982
        • Sweden
        #43
        Here is a photo of the chip.
        It's placed on the left side of the panel (looking at it from backside)
        Tried to insert in post, but no joy...
        https://www.bildtagg.se/bild/dxykrfx8xd8ikr8ztxhqgf7r
        • Diah
          • Feb 2013
          • 6614
          25Q32JVSIQ take it out.. dump it and flash new chip with yours dump and put it on the board.
          at future use GO Advanced so you will be able to upload photos as jPG format
          • PowerAmpFreak
            • 982
            • Sweden
            #45
            Thanks Diah, could you direct me to a flash programmer that is compatible with this chip?
            • Diah
              • Feb 2013
              • 6614
              the cheap one CH341A with clip can do the job..
              you can test the chip on the tv as it had beside as SPI contain I/O function.. firsts read the voltage on VCC PIN ( PIN 8 ).. then try freez it or heat it then turn on... hope yours screen will come on
              • PowerAmpFreak
                • 982
                • Sweden
                #47
                VCC is ok (3V4) also SPI, CLK, CS, MISO, MOSI has "activity" and no abnormal waveforms.
                Thermal cycling of the chip does not change behaviour...
                NOTE! When boot fails -> Standby led blinks TWO times. Then it all repeat...
                • PowerAmpFreak
                  • 982
                  • Sweden
                  #48
                  Followed this vid:
                  https://www.youtube.com/watch?v=E6gkuTP7Lt0&t=900s
                  Screen is OK!!!
                  Now I need to find new ESD diode packs to remount.
                  • kevinallein
                    • Dec 2010
                    • 32
                    #49
                    Can you please explain, which pins exactly you blocked with tape ?
                    • PowerAmpFreak
                      • 982
                      • Sweden
                      #50
                      https://www.bildtagg.se/bild/0m64i6ybovlhznm0xg54mh01
                      This is the ribbon to the right buffer board if looking at the tv from backside.
                      I have no clue what signals this is, or what effect it will have.
                      • kevinallein
                        • Dec 2010
                        • 32
                        #51
                        I am trying to count, but it looks like you are blocking 13 lines starting from PIN 16 ? Is that correct ?
                        That totally confuses me. I thought you would only block the CKVx and CKVBx lines, which should be 8 in total ?
                        Where did you get the info, what to block ? Could you please explain ?
                        I found a Samsung KS Service Manual, slightly different from the one I have, but here is the pinning info I found in there.
                        • PowerAmpFreak
                          • 982
                          • Sweden
                          #52
                          I am just a surprised as you how this could actually work.
                          The tape is blocking 12 lines from start pin 16.
                          I was looking at the youtube vid and decided to give it a go.
                          Did not look very carefully how much pins to block and from where actually.
                          The first try I made resulted in a properly working tv, with no picture side effects.
                          I will try, by your pinout information, to see what signals I actually blocked.
                          Could you upload the complete service manual ?
                          And what does the CKV lines do ?
                          • Davi.p
                            Hobbist Tech
                            • Sep 2009
                            • 4544
                            • Italy - Milan
                            #53
                            you probably blocked clk signals due to the fact that your gate driver circuits connected to the clocks are s/c..
                            • lotas
                              • Jan 2016
                              • 4899
                              • Russia
                              #54
                              The CKV signals control the on / off frequency of each line. (CKV line switching signal in line drivers)
                              • kevinallein
                                • Dec 2010
                                • 32
                                #55
                                I did actually find a NU Service Manual, that is probably more appropriate for you. Am I allowed to upload here ?
                                • PowerAmpFreak
                                  • 982
                                  • Sweden
                                  #56
                                  Could you expand your reasoning please.
                                  From looking at the pinout for connector CN1802 (right side) and assume this also applies to my set I can tell those below signals are blocked:
                                  I will now try to narrow the blocking down to the smallest amount of signals needed for picture
                                  • diif
                                    • Feb 2014
                                    • 6978
                                    • England
                                    #57
                                    Click go Advanced, click on the paperclip and add the image not the url.
                                    • Diah
                                      • Feb 2013
                                      • 6614
                                      the supject become more interset.. i think if you block only ASG_MON_R_MB4 with its respose STV_MP4 would enough... but let see these pins where are going.. as there no diagram i think they are return signal to MB.
                                      • PowerAmpFreak
                                        • 982
                                        • Sweden
                                        #59
                                        Thanks... I was trying to "insert image"...now it makes sense
                                        • PowerAmpFreak
                                          • 982
                                          • Sweden
                                          #60
                                          Going for Diah's advice blocking only 3 pins made the bootloop come back.
                                          Explanation:
                                          Blocking all blue markings - set is OK
                                          Blocking only the red markings - Set goes into bootloop
                                          Now extend blocking to cover a few of the CKV lines aswell. Stay tuned.
                                          • TR103
                                            by TR103
                                            - it keeps rebooting
                                            01-22-2025, 04:12 PM
                                          • JJAAMM
                                            by JJAAMM
                                            Problem
                                            07-06-2023, 06:01 AM
                                          • Mgiffune
                                            by Mgiffune
                                            06-09-2024, 10:28 AM
                                          • Dodgethis
                                            Samsung QN75Q6DRA, No Picture, Has BL, and Sound
                                            by Dodgethis
                                            Hello all,
                                            This is my first post, but long term lurker on the form learning as much as possible about these TV's. I was given this TV as due to a power outage of constant On/off of power to TV. The TV originally would just click on and off (Typical Reboot Cycle). I opened the back of the TV, and troubleshooted by taking the 96 pin LVDS off one at a time to see if I had a picture on either side. I finally fixed the reboot cycle by finding the error on the left side of the screen off connector CN 1301, and the TV would stay on. Further troubleshooting led me to the driver boards where...
                                            09-11-2024, 07:39 AM
                                          • YellowJacket
                                            Samsung QE55Q60RAT - no picture
                                            by YellowJacket
                                            Hi friends,
                                            a friend of mine gave me this TV to fix, with common SAMSUNG TV issue - damaged panel. Turning on, sound is present, but no picture. So I went directly to standard process, connecting two pads together with a wire ( see in the picture ), and then removing flex cables. With right flex connected, there was half screen working, but still no picture ( disappearing colors and similar weird stuff ) + working sound. With left flex connected, TV is restarting + working sound. I supposed, left side is damaged, so I then blocked all 8 CLK pins ( going from 0R resistors on the second...
                                            07-30-2024, 01:31 PM
