coby TFTV4025 POWER SUPPLY 24V NOT PRESENT
  • hmendez86
    • Jun 2015
    • 344
    • united states
    Re: coby TFTV4025 POWER SUPPLY 24V NOT PRESENT
    Ic1
    • hmendez86
      • Jun 2015
      • 344
      • united states
        Need to check the DCV VCC PIN 15 and GND, pin 12 and VC pin 13 and GND pin 12 to see if the IC is getting the Voltages to run, see spec sheet.
        IC1 is KA3525A.
        • hmendez86
          • Jun 2015
          • 344
          • united states
          On pin 15 numbers are just jumping up down
          • hmendez86
            • Jun 2015
            • 344
            • united states
            I got another chip to install same numbers but the top numbers don't match just the ka3525a
            • hmendez86
              • Jun 2015
              • 344
              • united states
              #26
              • CapLeaker
                Leaking Member
                • Dec 2014
                • 8352
                So what are these voltages that budm requested?
                • hmendez86
                  • Jun 2015
                  • 344
                  • united states
                  #28
                  They just jumping numbers they not read accurate.
                  • hmendez86
                    • Jun 2015
                    • 344
                    • united states
                    #29
                    Put black probe ground and red probe on pin 15,12,13 and just jumping numbers
                    • hmendez86
                      • Jun 2015
                      • 344
                      • united states
                      #30
                      What I notice is that when I connected the power and lefted for a while we're the heat sink is get warm it is were the rectifier the other heat sinks for the ac out put are cold no signs of over heating
                      • hmendez86
                        • Jun 2015
                        • 344
                        • united states
                        #31
                        Mean DC out put heat sinks
                        • hmendez86
                          • Jun 2015
                          • 344
                          • united states
                          #32
                          this were it gets warm....
                          • CapLeaker
                            Leaking Member
                            • Dec 2014
                            • 8352
                            Did you check the 2 small orange capacitors? One is next to the IC, the other one is under the heat sink in the primary that gets warm.
                            • Tynan Dill
                              by Tynan Dill
                              Assuming...
                              11-22-2024, 01:46 PM
                              by sam_sam_sam
                              03-31-2024, 02:12 PM
                              by sam_sam_sam
                              07-01-2024, 06:34 AM
                            • shamsudeen
                              Hi, Can we use SMPS Bench Power Supply for Laptop troubleshooting?
                              by shamsudeen
                              Hi all, I just need to know that, can i use SMPS type power supply to test and short circuit detection on a laptop motherboard?
                              I saw 95% of repair guys are using only Linear bench power supply. linear bench power supply is pricy, thats why i planned to get one SMPS supply.
                              i know that in linear power supply the noise will be very low comparing to SMPS supply....
                              07-19-2025, 07:14 AM
                            • JimBanville
                              Definitive technology SC 2000 subwoofer amp's power supply clicking and popping
                              by JimBanville
                              The sub developed a constant popping every couple seconds from woofer and power LED flickering with nothing but wall AC connected. Connecting an audio cable didn't change anything. It doesn't play but a second or two of audio in between the pops.
                              Opened it up and discovered the power supply is making a faint clicking or ticking sound.
                              I measured the amp's output to the woofer and it pulses up to 50mv DC to be driver. The pulses coincide with the power supply ticking/clicking.
                              I measured the power supply output going to the amp board and it too has this pulsing. Voltage cycles...
                              09-13-2023, 07:21 AM
