coby TFTV4025 POWER SUPPLY 24V NOT PRESENT
  • hmendez86
    • Jun 2015
    • 344
    • united states
    Re: coby TFTV4025 POWER SUPPLY 24V NOT PRESENT
    Ic1
    • hmendez86
      • Jun 2015
      • 344
      • united states
        Need to check the DCV VCC PIN 15 and GND, pin 12 and VC pin 13 and GND pin 12 to see if the IC is getting the Voltages to run, see spec sheet.
        IC1 is KA3525A.
        • hmendez86
          • Jun 2015
          • 344
          • united states
          On pin 15 numbers are just jumping up down
          • hmendez86
            • Jun 2015
            • 344
            • united states
            I got another chip to install same numbers but the top numbers don't match just the ka3525a
            • hmendez86
              • Jun 2015
              • 344
              • united states
              #26
              • CapLeaker
                Leaking Member
                • 8146
                So what are these voltages that budm requested?
                • hmendez86
                  • Jun 2015
                  • 344
                  • united states
                  #28
                  They just jumping numbers they not read accurate.
                  • hmendez86
                    • Jun 2015
                    • 344
                    • united states
                    #29
                    Put black probe ground and red probe on pin 15,12,13 and just jumping numbers
                    • hmendez86
                      • Jun 2015
                      • 344
                      • united states
                      #30
                      What I notice is that when I connected the power and lefted for a while we're the heat sink is get warm it is were the rectifier the other heat sinks for the ac out put are cold no signs of over heating
                      • hmendez86
                        • Jun 2015
                        • 344
                        • united states
                        #31
                        Mean DC out put heat sinks
                        • hmendez86
                          • Jun 2015
                          • 344
                          • united states
                          #32
                          this were it gets warm....
                          • CapLeaker
                            Leaking Member
                            • 8146
                            Did you check the 2 small orange capacitors? One is next to the IC, the other one is under the heat sink in the primary that gets warm.
                              by sam_sam_sam
                              03-31-2024, 02:12 PM
                              by sam_sam_sam
                              07-01-2024, 06:34 AM
                            • shamsudeen
                              Hi, Can we use SMPS Bench Power Supply for Laptop troubleshooting?
                              by shamsudeen
                              Hi all, I just need to know that, can i use SMPS type power supply to test and short circuit detection on a laptop motherboard?
                              I saw 95% of repair guys are using only Linear bench power supply. linear bench power supply is pricy, thats why i planned to get one SMPS supply.
                              i know that in linear power supply the noise will be very low comparing to SMPS supply....
                              07-19-2025, 07:14 AM
                            • CMCM
                              Russound CA4 Power Supply Repair
                              by CMCM
                              Hello Everybody,
                              Trying to repair a power supply from a Russound CA4 Multizone Controller (picture attached)
                              Russound no longer supports it but were kind enough to provide a schematic of the power supply (pdf attached).
                              The outputs marked 12v and 20v are all measuring only 1v.
                              The board is clicking, which I think means it is in something called hiccup mode when the flyback transformers switches because of an internal problem or something else on the board Overloading it.
                              The capacitors physically look clean (no bludgesor leaks) and...
                              07-03-2025, 01:12 PM
