Sony Bravia KDL-46EX723 - 4 blink code
  • Toasty
    • Jul 2007
    • 4171
    Re: Sony Bravia KDL-46EX723 - 4 blink code
    Metered the current on each of the 4 outputs. Got 80-84mA on each for about 1 second until it shutdown. That seems to suggest that the strips are okay and equal.
    Any ideas?
    T
    veritas odium parit
    • freakaftr8
      • Oct 2012
      • 3743
      Sounds like it. I have a small 22 inch funai built magnavox edgelit led tv that has a flickering led strip. All leds are working but still some odd issue. Turned out.to be a mainboard issue somehow. As it goes if you jumped the appropriate connections you should be able to get that tv to stay on. But the driver ic needs to be tricked.
      • Toasty
        • Jul 2007
        • 4171
        Replaced the LED driver board and unit is back in operation. Total investment $16 plus time.
        Sony A-1804-042-A LDBLK Board
        Attached images courtesy of ShopJimmy.com
        T
        veritas odium parit
        • tibimakai
          • Jan 2012
          • 3680
          Nice cheap fix. Mine it was more, but still happy that the driver board was at fault and not the LEDs.
          This was mine, much more complex then yours:
          Sony ST4055YL-S01 YL Board
          • Toasty
            • Jul 2007
            • 4171
            Wow! That's a bugger
            I would have tried the bypass on the chip, but as you can see nothing is marked except the IC's and the components are super small. The board is only 7.5" x 3" (19cm x 8cm) and the transistors I'd have to work with are 1mm x 2mm (left of IC1004).
            T
            veritas odium parit
            • sriram.janu
              • Aug 2016
              • 1
              • india
              #26
              [Check PANEL_FAIL at pin 7 of CN6002 on the B* Board]
              - Below 0.84v = B* BOARD
              - Between 0.84V to 2.65V [Change G* Board]
              -so if CN6002 is between 0.84v to 2.65v should change main bord?
              • cdubz
                • Oct 2016
                • 1
                I have the same exact problem. Or at least I did until I bumped a pin with my multimeter. I was just going to replace the LD board and/or the BATV board based of of what I saw online.
                I assume we check pin 7 (BL_ERR) to pin 1 (GND) correct? When looking at the BATV board and CN6002 is in the top left corner. What is the pin layout. Is 1 at the top or bottom?
                I was getting about 3.61V one way and 0.00V the other way.
                I understand what most of the boards are BATV, T-CON, LD, G4B (power) but with is the "B*" and "G*" board? Does this correspond to BATV & G4B?
                Seeing as I couldn't make sense of 3.61V I tried to sneak my meter in the pin connector on the power board where the harness from the BATV board meets and I think I bumped into pin 8 and 10 at the same time. I heard a relay click or pop sound followed by a high pitch electrical noise. Now all I get is a hissing noise when the TV is plugged in and no power. I hope I didn't screw anything up
                • ahmedsam
                  • Oct 2016
                  • 1
                  • Saudi Arabia
                  #28
                  thanks to much ,good information sir,
                  i am luck join you'r group
                  thanks again
                  • azmansex
                    • Oct 2010
                    • 2
                    #29
                    I do have the same problem,I change the 1-883-300-21 and fix my set...
                    • nomoresonys
                      • 12330
                      • U.S.
                      #30
                      Originally posted by freakaftr8
                      Your the one I was thinking about when the op posted this thread.
                      Is it just me or does it seem like just a slight possibility here that these new led TVs gave a very limited window for led wear? I mean with LCD TVs with CCFL backlight they seem to go on and on and on until the one of the backlight ccfl's fail. These TVs seem to have no room for led wear when they start to differ on balance they automatically send a code and won't work anymore.
                      +1000, I won't buy an led tv, I'll go straight from lcd to oled.
                      • nomoresonys
                        • 12330
                        • U.S.
                        #31
                        Just for clarification what is the 1-883-300-21?
                        • Tynan Dill
                          by Tynan Dill
                          Assuming...
                          11-22-2024, 01:46 PM
                        • m1ch43lzm
                          by m1ch43lzm
                          05-12-2025, 08:37 PM
                        • cheeky2
                          Sony RB2G Chassis KDL-55W815B MAIN BOARD 2 Blink Error issue resolved! Happy days :)
                          by cheeky2
                          For anyone interested just repaired this Sony Main board TV that had a 2 blink error code, the chassis is a RB2G which is common to quite a few different Sony models. The Ceramic 10uF 25V X7R 1206 capacitor C9114 was shorted which took the smd 2A 0603 fuse out F9101. This was powering the Buck converter TPS54332 which caused no 5V output from it.
                          See the attached picture of the locations of both components. I also attach the best service manual I found for this board for anyone else in a similar position of trying to repair this main board. It's not specific to the TV model however it gives...
                          01-08-2024, 05:56 AM
                        • jb_Bak
                          by jb_Bak
                          CN6401
                          Pin 01 NC
                          Pin 02 NC
                          Pin 03 "BL_ON": 0V
                          Pin 04 "N/C"
                          Pin 05 "STBY 3.3V": 3.5V
                          Pin 06 "GND": N/C
                          Pin 07 "AC_OFF"...
                          09-27-2021, 04:52 PM
                        • eclectric
                          Sony Bravia KDL-70W850B T-CON board / software update issue
                          by eclectric
                          Hi, I'm hoping someone can help me with this issue before I give up on this TV.
                          In short, I replaced the T-CON board due to an error code indicating that was the problem, after which it flashed a green and orange LED meaning software update required. I cannot get the tv to do the required update via USB, so I am stuck.
                          Here is a rundown of the symptoms and the steps I have taken to troubleshoot:
                          I inherited the TV with the symptom that it would turn on, then turn off after 5-10 seconds and a red LED flashed 4 or 5 times. Sometimes it would be 4, sometimes...
                          05-23-2022, 01:25 AM
