Gigabyte Aorus 1080ti - card not initialising
  • benwaterson
    • Aug 2008
    • 202
    • United Kingdom
    Re: Gigabyte Aorus 1080ti - card not initialising
    Examining a working 1080FE, drain is 0.9v until the GPU initialises and then pulls to 0v
    • benwaterson
      • Aug 2008
      • 202
      • United Kingdom
      So I created a new problem probing GPIO pins for voltages. Tried to check pin 39 on uP9511 (VID) which is connected to GPIO0_NVVDD_PWMVID on the core.
      Card then stopped outputting any voltages (5v,1.8v etc). Checked the MP1475 buck convertor that generates 5v and its shorted VIN (12v) to gnd.
      Not sure why it suddenly failed (unless i shorted some pins with the probe on uP9511, but seems unlikely as they are seem unrelated in that area of the chip (pgood, vid and refadj).
      Removed the chip and its shorted (had removed a couple of caps to test between VIN and GND as i thought they were causing it, but no, short was still present)
      Now have to wait for some replacement chips from aliexpress to arrive at the end of the month (bought 10)
      • Bozog
        • Jan 2022
        • 125
        Damn, just when you were getting somewhere, hate waiting for supplies from China, lol
        • Traptor
          • Nov 2021
          • 111
          • Magyarország
          So, the gpio10_fbvref_sel is not needed for working, only to the start?
          How did you check this? With oscilloscope?
          • benwaterson
            • Aug 2008
            • 202
            • United Kingdom
            I checked with multimeter, and watched the voltage drop to 0v on the mosfet as the GPIO pin went high. I haven't checked any further to see if this changes with the card in use.
            I might hook it up the the oscillopscope and monitor if it changes whilst running MATS on the 1080FE.
            It its a constant 0v once initialised then pulling the pin up manually to 1.8v might help get the 1080ti card going again, not sure if the fault is with all GPIO lines or just this one. Won't be able to test that until my delivery from aliexpress arrives.
            Will report back.
            • benwaterson
              • Aug 2008
              • 202
              • United Kingdom
              #26
              Ok. hooked up the scope to pin 3 of the mosfet (drain)on the 1080FE.
              Its high for a second or two as PC switches on, then pulls low. Booted up and ran MATS for a minute or so, pin remains low all the time.
              This is looking hopeful that it can be manually tricked by hooking 1.8v to the gate pin (1)
              • benwaterson
                • Aug 2008
                • 202
                • United Kingdom
                #27
                Given up waiting for aliexpress (delivery date now showing may 5th!).
                Have ordered 2 chips from UK for £16 with delivery, will hopefully be here tomorrow/thursday.
                • benwaterson
                  • Aug 2008
                  • 202
                  • United Kingdom
                  #28
                  Out of interest, here is the scope output for the GPIO pin on the working card (i just used auto ranging on the scope).
                  It's not a PWM signal as far as I can see as waveform does not change, and neither does the voltage on the MOSFET.
                  • Bozog
                    • Jan 2022
                    • 125
                    Looks a bit dodgy, is your scope isolated from the mains?
                    • benwaterson
                      • Aug 2008
                      • 202
                      • United Kingdom
                      #30
                      It's usb powered (using front usb connector on pc). Shows freq of 316khz. Tested the crystal on the card with this set up and it reported a pure 27mhz sine wave (no interference).
                      • Bozog
                        • Jan 2022
                        • 125
                        Strange yeah should be OK if scope has the same ground reference. Still looks like interference, since surely this is a digital signal.
                        • benwaterson
                          • Aug 2008
                          • 202
                          • United Kingdom
                          #32
                          Try this one (used USB charger instead of PC) - reported voltage is way better too
                          • Bozog
                            • Jan 2022
                            • 125
                            Yeah that looks more like it, still hasn't helped much with finding out what the problem is tho, hmm...
                            • benwaterson
                              • Aug 2008
                              • 202
                              • United Kingdom
                              #34
                              Once i get the replacement chip and get the voltages back on the broken card I can continue testing on that
                              • Bozog
                                • Jan 2022
                                • 125
                                Well good luck with it, hope you find out what's wrong(and it's fixable)
                                • benwaterson
                                  • Aug 2008
                                  • 202
                                  • United Kingdom
                                  #36
                                  I am having a hell of a time finding this 5v short to gnd.
                                  Chips arrived, soldered it in - tested for resistance - 1.1ohms to gnd on pin 3 (SW).
                                  Have removed :
                                  U27
                                  C265
                                  C248
                                  C249
                                  C251
                                  Lifted output leg of L15 choke.
                                  Short is to the right of the choke (as after lifting leg there is no short on u27 or c265 now), so unless it's U6 that's shorted then I am running out of ideas!
                                  R327 is measuring 10.7k
                                  • Bozog
                                    • Jan 2022
                                    • 125
                                    Probably the uP9511 unfortunately You can try voltage injection and see what warms up.
                                    • benwaterson
                                      • Aug 2008
                                      • 202
                                      • United Kingdom
                                      #38
                                      Yes, my next idea was voltage injection as removing and resoldering parts on this card is a pain
                                      • ss45
                                        • Jun 2019
                                        • 119
                                        • Brazil
                                        #39
                                        Maybe sign of GPU failing or bad GPU.
                                        I have had identical 970 in the past. One was cool while idle, the other was 50 c while idle.
                                        Both were repasted
                                        While gaming the bad one initially would play just fine, after a while it would crash, the more I used it for gaming each time the earlier the crash would happen during subsequent game launch. From there it was only going down.
                                        • benwaterson
                                          • Aug 2008
                                          • 202
                                          • United Kingdom
                                          #40
                                          Yup, it's UP9511 and possibly 2 of the DRMOS chips also.
                                          Annoyingly it heats up quicker in the bottom left area where I was trying to probe for GPIO voltages.
                                          Tempted to give up at this point...
                                          • myth77
                                            UV solder mask - high temp resistent, recomendation?
                                            by myth77
                                            Can someone recommend any good UV solder mask? But i need a solder mask that will stand high temperetures. The thing is...sometimes i have a bigger cooper ripped from the board, lets say mosfet pad... i reconstract it with cooper sheet, then i "glue it" with solder mask...then i use UV light...and let it cool a bit. After, i try to clean the cooper of extra solder mask..and till that part all is ok. But, when i use a soldering iron to solder that pad/cooper...the solder mask gets weaker or destroyed and finally the pad is ripped again from the board .
                                            Is there any solder mask...
                                            03-28-2022, 04:04 AM
                                          • janos666
                                            Pioneer LX5090 - 2x Red blink after auto-shutdown
                                            by janos666
                                            I was trying to reset the Pulse Meter and re-adjust the Panel-1/2 settings in the SM on an exceptionally old Pioneer LX5090 (51k power-on hours according to it's SM). I did this many times on much less aged specimens (with 10-20k hours) without issues. After following the usual workflow, I noticed the darkest gray shade showed up black with bright sparkles. I tried to adjust some other parameters but it didn't disappear. Then I went on and restored the old values of the parameters I don't usually touch (although I did this from memory, so I might have made an error). After that, I started going...
                                            03-26-2023, 11:20 AM
                                            NVIDIA GeForce GTX 1080 1080Ti Schematic & Board View
                                            The GeForce GTX 1080 was a high-end graphics card by NVIDIA, launched on May 27th, 2016. Built on the 16 nm process, and based on the GP104 graphics processor, in its GP104-400-A1 variant, the card supports DirectX 12. This ensures that all modern games will run on GeForce GTX 1080. The GP104 graphics processor is a large chip with a die area of 314 mm² and 7,200 million transistors. It features 2560 shading units, 160 texture mapping units, and 64 ROPs. NVIDIA has paired 8 GB GDDR5X memory with the GeForce GTX 1080, which...
                                            10-02-2024, 07:37 AM
                                          • Grouickman
                                            boardview and/or schematics for EVGA 1080Ti ftw3 ?
                                            by Grouickman
                                            I'm looking for boardview and/or schematics for EVGA 1080Ti ftw3.
                                            thanks.
                                            07-01-2025, 07:18 AM
                                          • nubinator
                                            Tape mask on samsung RU7100
                                            by nubinator
                                            I got boot looping 65RU7100 and did tape mask and got image back. I narrowed down the problem to 1 pin it was pin 16 on left side which is CKVB1 so I masked that pin as well as CKV1 cause I read should do them in pairs. Image is pretty good but I get horizontal scan lines on bad side of panel, any way to fix this? When I was experiementing with blocking CKV pins I noticed the more I blocked the more color loss I got on bad side of panel
                                            05-21-2025, 06:49 AM
