PN50C550 vertical colored lines
  • paulstef
    • Dec 2013
    • 724
    Is this as bad as it looks like?
    Anything I can test? The lines are on top of the menu too...
  • rccrasher65
    • Mar 2014
    • 626
    Re: PN50C550 vertical colored lines
    Bad plasma panel.
    • paulstef
      • Dec 2013
      • 724
      Originally posted by rccrasher65
      Bad plasma panel.
      I assume you mean the driver ICs on the the flatcables going from X-board to the panel?
      • ReeceyBurger123
        Never Give Up !
        • May 2014
        • 7325
        • Britain
        Yes not fixable as they are bonded to the panel.
        • paulstef
          • Dec 2013
          • 724
          What does it take to repair this?
          Isn't this stuff similar to what they sell here? :http://www.iccfl.com/product_info.php?products_id=18483
          • budwich
            • Jul 2015
            • 3097
            I guess the "not fixable" isn't the answer you want. You can try some thermal pads "pressuring" on the bond area to see if some pressuring changes / helps the problem.
            The issue with trying to replace the bonded flex cable is that the alignment is a significant factor along with the bonding such that "field replacement" is not "practical". Of course, you have to find the exact replacement flex tab cables.
            Since you likely have a bad panel and nothing to loose other than some time and maybe a "dollar or two", do your own "experiment"... who knows you might be successful. I am sure you will be a "forum hero" thereafter and everyone will be extremely interested in your achievement since this type of failure (flex tab issue) kills a lot of panels.
            • dbier63
              • Aug 2015
              • 157
              • usa
              I think I'll jump in here. I agree with paulstef. I'm going to try replacing a tab ribbon cable bond with one from a set with a broken screen.
              • ReeceyBurger123
                Never Give Up !
                • May 2014
                • 7325
                • Britain
                I dont thinks that possible not on the vertical hight drivers. I however have been able to do it on the horizontal tabs well I repaired the traces in it.
                • Stanley1843
                  by Stanley1843
                  06-29-2024, 11:54 AM
                • pni
                  LG 49uf695v vertical coloured lines
                  by pni
                  Hi guys…I need your help. My cousin ask me to fix her tv. The tv when I went to pick up showed 3 horizontal black line. So I know it was a bad panel issue but I could try to fix with the tape method so I said her I could fix easy. When I come back to home, I turned on the tv and now the tv show vertical line colored….and the problem is that I unplug the ldvs cable, first the right side then the left side I still have the lines. The lines never disappear. When the right side is plug in I don’t have nothing on the screen only this vertical lines, when the right side is unplugged I have picture...
                  11-14-2025, 03:15 AM
                • Falki
                  Colorful LCD Vertical Lines on Samsung ue55es8090
                  by Falki
                  Hello there, ive recently found an older 55inch Samsung SmartTV.
                  A similar issue has been posted as well but also with no actual response ...
                  08-12-2025, 04:19 AM
                • visionbluedemon
                  Help. Sony kd-65x85dj vertical lines
                  by visionbluedemon
                  First. it has no picture at all. i solved it by covering the ckv lines using tape to to block the connections
                  Second. now has picture but with vertical lines that follow the image. tcon board ic overheating
                  tried blocking LC lines too, but same results
                  is it lcd panel issue or tcon board issue?...
                  07-25-2025, 04:56 AM
                • gpo23
                  Sony KDL-40V3000 - Vertical lines
                  by gpo23
                  i order a t-con because i had bad colors on my SONY KDL-40V3000 :
                  With the new t-con the color are good but there are vertical lines on all the screen :
                  I've tried the old t-con and it returned to the initial issue (bad colors but no vertical lines)
                  Is there a way to fix the vertical lines on the new t-con ?
                  Thank you for your help
                  gpo23...
                  10-04-2023, 09:11 AM
