Please Bios for Asus X510UNR Rev 3.0..thank you
Asus X510UNR
Re: Asus X510UNR
Post your bios backup here . -
Re: Asus X510UNR
here its working bios Asus s x510Attached Filesif you find these attachements useful please consider making a small donation to the site
Re: Asus X510UNR
tested 100% ok
Re: who can clear ME for me
try..Attached Filesif you find these attachements useful please consider making a small donation to the site
Every donation made will go towards server fees and maintenance costs.Comment
Re: ASUS X510U (MB X510UNR Rev: 3.0) not display at all
Ok, attached is the ORIGINAL BIOS de-soldered BIOS Chip from the motherboard Any help will be greatly appreciated. ThanksAttached Filesif you find these attachements useful please consider making a small donation to the site
With this BIOS update the motherboard turns on, I can see the Keyboard Power LED lit, but the amps on the ampmeter is stuck to 0.03, no movement at all & CPU is cold., With my previous BIOS file it would take around .40 ~ .20 amps up & down fluctating & the CPU used to get warm & then fan turned on. I think that the re-build BIOS is not updated well.Comment
Post a good clear picture of the white sticker on the ram slot .With this BIOS update the motherboard turns on, I can see the Keyboard Power LED lit, but the amps on the ampmeter is stuck to 0.03, no movement at all & CPU is cold., With my previous BIOS file it would take around .40 ~ .20 amps up & down fluctating & the CPU used to get warm & then fan turned on. I think that the re-build BIOS is not updated well.Comment
Re: Asus X510UNR
If the bios hasn`t been flashed or updated with the wrong one then the bios posted by @peste should be ok.Try this one anyway .Attached Filesif you find these attachements useful please consider making a small donation to the site
Re: Asus X510UNR
If you post the serial number one of the members who works for asus service might post an F1 engineering biosComment
Re: Asus X510UNR
Thanks "SMDFlea" I really appreciate your help. Now with the BIOS file you send me, all came back to normal, I see the fan running, CPU getting warm & the motherboard taking 0.40 amp which I think is right, but still no display. I can clearly view that the backlight turns on & off & it goes throught the initial septup process like all ASUS do, but I cannot get the image on the screen., Even with the External monitor NO Display. I am assuming still it's the BIOS issue as I can even measure that all voltages are present on the motherboard to turn on. Thank in advance.Comment
Re: Asus X510UNR
Is someone there to update this BIOS for me??? The notebook is not giving any display.. Other than this notebook turns on fine & I notice LCD backlight turns on. ThanksComment
by razor_amdWith ASUS, not everything is quite so simple. I will show you my way. It may be longer or harder but it is the right way to do it in my humble opinion.
This is the picture of 3 similar ASUS motherboards, all of them being X555LD...-
Channel: BIOS Requests ONLY!
by grimacelordHello,
Anyway, I took dumps of both chips and then downloaded the latest update for this motherboard from ASUS's website...-
by TyMercerApologies if this is the wrong forum, but I'm not looking for a specific BIOS file, I'm trying to understand how one makes a clean BIOS file. So here's the background. I have 2 HP EliteDesk 800 g2 mini 35w pcs. One is working fine; the other doesn't have display out or working USB's nor does it have any flashing error lights. The CPU does get worm enough to cause the fan to spin up, so I think it's posting, but I just don't know. I had it working at one point but trouble started when I tried to put in a drive caddy that had a cooling fan on it. I thought it would be compatible but wasn't...
Good Day Masters! Anyone have working bios for ASUS E410MA? i tried reading the BIOS Chip and the programmer cant detect it i think the bios chip is dead... i already tried 2 programmer but same still cant detect the chip. Thanks in Advance
Model: ASUS E410MA-TB.CL464BK
SN: N8N0CX06E199324
BoardModel: E410MA R7.1-
i need working bios for Asus x71SL the laptop work but it freez when enter to bios...
11-15-2025, 05:18 PM -
- Loading...
