Asus X54UVK Rev 2.0 Bios dump
  • speggio91
    • Apr 2020
    • 83
    • Italy
    by suggestion of a member of this forum, I dumped the bios of this machine and attach it there. I request for a check of the image if its corrupted,
    thank you very much.
  • lapfix
    • Mar 2020
    • 2732
    • my workshop
    Re: Asus X54UVK Rev 2.0 Bios dump
    Try ..
    • speggio91
      • Apr 2020
      • 83
      • Italy
      Originally posted by lapfix
      Try ..
      Thanks. I can't get it to flash to any software, i am using the ch341A mini programmer with Neoprogrammer and when it has to verify the image it give a verification error.
      I think is the software that doesn't have in its database the bios chip i have (gigadevice 25B64CSIG).
      Is there any software that has that chip in the database?
      Or I can add it manually on neoprogrammer but I don't have the parameters.
      • peste
        • Dec 2016
        • 12852
        • ROMANIA
        try this..
        https://www.badcaps.net/forum/showpo...6&postcount=10
        • speggio91
          • Apr 2020
          • 83
          • Italy
          Originally posted by peste
          That software seemed to have worked because it completed the flash process even if it couldn't verify the chip.
          But after soldering the chip back to the board there is no power, if i press the power button nothing happens.
          Before flashing the bios, the board turned on by itself just with the red led of the charger even if no battery was connected and when I pressed the power button the board powered on for a second then shut down.
          I believe the bios did not flashed correctly. I will try again or I'll buy a better programmer.
          Link to the repair board topic:
          https://www.badcaps.net/forum/showth...ghlight=x54uvk
          • razor_amd
            by razor_amd
            12-15-2020, 07:07 PM
          • jbonavita
            by jbonavita
            Some issues
            Things I tried
            04-29-2025, 09:38 PM
          • Habble7
            by Habble7
            Suspected Cause:
            Troubleshooting Attempts:
            05-22-2025, 07:28 AM
          • Anchar777
            ASUS P1412CE need BIOS DUMP
            by Anchar777
            Sorry for creating a second post, I didn't understand how to fix the error in the message. I need help, laptop ASUS P1412CE (P1411CEA-EK0395X) SN: N4NXCV033901146. There was a failure during BIOS flashing, and the laptop stopped turning on. The original, non-working BIOS is attached. Unfortunately, I was unable to correctly generate the BIOS from what is presented on the Asus website. Help me make a dump. Thank you....
            06-26-2025, 03:39 AM
          • kcp0085
            Request BIOS dump for ASUS FA617NS-A16.R77600
            by kcp0085
            Aloha, I'm trying to recover my ASUS TUF Gaming A16 (FA617NS-A16.R77600)
            I have the CH341A programmer and can flash the BIOS chip directly. I need a verified full .bin dump (2MB or full SPI region) for this specific model.
            Specs:
            - ASUS TUF FA617NS-A16
            - CPU: AMD Ryzen 7
            - BIOS chip: Winbond W25Q16JVSIQ (2MB)
            If anyone has a full dump or can share from a working unit, it would be hugely appreciated.
            Thanks in advance!​
            05-02-2025, 12:52 AM
