Inverter Welder Strangeness
  • Crystaleyes
    • Sep 2021
    • 493
    • Brazil
    Hola peeps.
    I'm placing it in this topic, because from what I can see, it is essentially a modified SMPS, but please move if there is a 'correct' forum section.
    Recently, I bought an essentially brand new, but defective, 155 amp inverter welder.
    The unit would turn on fine, with the digital display and fan doing their thing, however when attempting to strike an arc, the rod would merely spark or just get stuck onto the steel.
    Now I know that many (if not most) in here would simply not have bought it, but I am still learning this trade and had never even looked inside one of these before, so for the equivalent of 25€, it is a good opportunity to learn.
    Other than not striking arcs, the only other noticeable oddity was that after switching the neon illuminated mains switch off, the neon would remain on until the large capacitor(s) had discharged. And the plug pins would also give a sharp shock
    Normally, the lack of arc symptoms could be simply a dirty or poor connection on the main leads, and there was actually some play in the two large bars which connect the pcb to the hefty 16mm cable terinals on the front panel, although tightening made no difference.
    So without removing any parts, I looked for any obvious damge and basic tested the obvious for shorts... The large caps, the two IGBT's, the PCT, main relay, the two output diodes, etc. There is no fuse protection. One resistor next the the 7805 has almost no markings left on it.
    After several attempts at welding down in the garage, I put the open unit on the bench to have a probe around and take some voltage and frequency readings.
    When the welder had been turned on a few minutes, but before I had done any readings, there was a puff of smoke from the area of the relay and the unit switched off. Including the previously ever-glowing neon on/off switch.
    Now, I haven't yet understood how this welder should be working, but with my somewhat limited understanding of SMPS design... IF it is based on the switching supply system, then the PWM controller not functioning correctly would limit the main current output, and any arcing capability.
    Anyway, this puff of smoke event, took out the two 45 amp IGBT's and their two SS14 smd diodes.
    The only chip in the region of the smoke is an LNK626 'ffline switcher' which I don't really understand what it is doing, but it isn't the PWM controller as that is an SG3525 which is located towards the end of the board,
    So today, I put the unit back on the bench with the intention of drawing out some kind of circuit diagram in order to see if a better understanding could be gained.
    What stood out immediately is that the two large electrolytic filter caps are connected before the bridge rectifier. This is a new one on me...
    Even more unusual in my world of limited electronics understanding, is that one of the bridge rectifier AC terminals has no AC going to it, nor is the terminal connected to any other part of the PCB
    I have drawn a very basic sketch of the first part for people to have a look at.
    What is going on with the bridge rectifier, why are the caps before the bridge, and does anyone have any suggestions as to what else to check?
    Thanks in advance
  • petehall347
    • Jan 2015
    • 4448
    • United Kingdom
    Re: Inverter Welder Strangeness
    check continuity from the bridge rectifier to the mains plug .
    caps looked connected as normal to me .
    • eccerr0r
      Solder Sloth
      • Nov 2012
      • 8711
      Did any caps split open and "VEHT" ?
      • Crystaleyes
        • Sep 2021
        • 493
        • Brazil
        Split and vent.. no
        That is not to say that one or more of the caps isn't bad on the ESR side of things. I'm kinda limited with capacitance testing right now.
        check continuity from the bridge rectifier to the mains plug.
        There is no continuity.
        The mains input either goes to one side of the relay contact (and then on to one pin of the bridge AC), or to one side of both caps.
        Filter caps are normally found 'after' rectification, no?
        And speaking of that... How can the AC supply be 'rectified' if it is not actually connected to the rectifier?
        In the following photos, it can clearly be seen that the AC terminal next to the -ve pin, goes precisely nowhere, nor has any input.
        How on earth does that work?
        • CapLeaker
          Leaking Member
          • Dec 2014
          • 8352
          As long as she works, but having a weak output, I would suggest the big caps are leaky. If there would be a short on any of these fets, the unit wouldn’t be working like that. Problem with properly testing these kind of caps, you’d need to do a leakage test. ESR wouldn’t do you any good here.
          If you want you can read up on a plasma cutter that I repaired. Maybe that gives you some hints.
          • Crystaleyes
            • Sep 2021
            • 493
            • Brazil
            Leaky big caps could well be the case. One of the 2200uF caps measures only 2000uF..
            .. In fact looking online, they, along with the IGBT's are commonly sold as the repair solutions for these welders.
            One other thing which I was wondering is whether the SG3525A PWM controller might be bad?
            I've never actually tested this part of a circuit in a working SMPS however this controller is reading around 160KHz, with around 30% Duty Cycle, on both of the outputs, and doesn't change as the current control knob is adjusted.
            Surely that should change?
            I would have expected to see some change in the output of that chip, but I'm here to learn.
            Had a good read through that, thanks, and unless someone declares that the PWM is working correctly, then I'll have a probe around on the board for bad components.
            • CapLeaker
              Leaking Member
              • Dec 2014
              • 8352
              What’s the make and model of this darn thing?
              • Crystaleyes
                • Sep 2021
                • 493
                • Brazil
                It's called a Pro Euro GP-155A - 127 volts
                Sold in Brazil - Made in China (manual included below)
                Seems to me to be a basic generic design. It certainly isn't the most robust piece of kit, but I bought this to learn how to repair it.
                The situation update is that as mentioned, the two IGBT's blew for no apparent reason, whilst the unit was running. Last night I installed two new ones and ran the unit on the bench for a good hour without issue, at first through the dimbulb and then through the normal socket. The display was fine and the fan was blowing , whilst there was 30 VDC across the output terminals. When I first got the unit which wouldn't arc, there had been around 70 VDC.
                This morning I took it to the garage to see if it would now weld and as soon as I switched it on, there was a flash the wall socket and the unit went dead. A quick test shows that the IGBT's are once again shorted, and checking the plug, it had been burnt in the socket.
                The only difference between running the welder last night on the bench, and this morning in the garage, is that the garage socket is a bit oxidised. Whether the unit is so fragile that a poor plug contact would blow the transistors is surely doubtful, so I need to start thinking about what other fault would cause the IGBT's to blow when not under load? And seemingly an intermittent fault...
                Do PWM controllers fail intermittently? As mentioned yesterday, taking readings last night showed no variations as the current controller was adjusted and after the incident this morning, there is no longer any output from the PWM controller.
                Anyway, I now have to reorder the transistors which is a fucking pain.
                Onwards and upwards
                  • Jul 2011
                  • 6070
                  I personally would replace PWM if I were trying to repair this device unless you for sure that it is functioning correctly
                  It possible that the IGBT module might have taken a shit because of the PWM controller chip malfunction in some way or some other device malfunction
                  • Crystaleyes
                    • Sep 2021
                    • 493
                    • Brazil
                    Agreed.
                    Earlier today I'd decided to replace the pwm controller along with the IGBT's and both of the fat caps, so shall get on with that. One of the recommendations in the manual, for low power output, is to change the large capacitors,
                    Correct me if I am wrong, however it seems to me that this welder uses pwm switching in much the same way as an SMPS would, and therefore, if there is no (or limited) 'pulsing' then the full circuit current will go through the IGBT's and fry them.
                    One thing I have to admit that I don't understand is the AC mains input not taking a direct path to the bridge rectifier, nor even connecting to one of the AC input pins on that rectifier.
                    That is a new one on me, and I'm struggling to see how the DC supply can be acheived in this way? As in, creating a two wire +ve and -ve DC supply from one AC wire?
                    As far as the PWM controller goes, would I be correct in assuming that controller would have a measurable signal on Outputs A and B, without the IGBT's being in circuit?
                    • CapLeaker
                      Leaking Member
                      • Dec 2014
                      • 8352
                      If the IGBTs shorted to the gate, then it dumped full load to the gate drive circuit. So you have to inspect everything in that gate drive circuit, including the PWM. Is there a way to see a pic of the IGBT with the gate drive?
                      • Crystaleyes
                        • Sep 2021
                        • 493
                        • Brazil
                        I would imagine so.
                        Not quite sure what you mean by 'Gate Drive'?
                        Are you referring to the circuitry between the pwm controller and the IGBT gate?
                        • CapLeaker
                          Leaking Member
                          • Dec 2014
                          • 8352
                          Yes. PWM, all component’s between it and the IGBT.
                          • Crystaleyes
                            • Sep 2021
                            • 493
                            • Brazil
                            Yes. PWM, all component's between it and the IGBT.
                            Roger that!
                            Let's give it a go... (again... as the pics refuse to upload - grrrrr)
                            The first pic #981 shows the view from the SG3525AP pwm controller across to the board which sends the signals to the IGBT's gates. IC2 is an LM358 (I believe)
                            #998 is the view from directly above
                            #985 shows that the two pwm outputs A & B (pins 11 and 14) cross through the board to the other side.
                            #994 shows the hole on the reverse side and that it connects to pin 1 of the perpendicular 'comms' board
                            #995 shows the PWM output B connecting to pin 5 of the same board.
                            #996 shows the board in question. Pin 1 is at the bottom. VT1 and VT2 are 4688 MOSFETs (datasheet below). The two yellow wires are the outputs to the inductor before the IGBT's.
                            #997 is just another angle
                            #989 shows where the yellow wires go to, and that one leg passes through capacitor C26
                            #877 shows the 6 pinned transformer/inductor. The two yellow wires connect to the right hand side.
                            #991 Shows the underside of the 6 pins. The left hand pair connect to the yellow wires, Without confirming, I believe that the centre pair connect to the IGBT Emitters, and the right hand pair connect to the IGBT Gates via two SS14 diodes and some resistors
                            #803 shows the board with the IGBT's and heatsinks removed. The two diodes are the SS14's
                            More to come but it is late here
                            zzzz
                            • CapLeaker
                              Leaking Member
                              • Dec 2014
                              • 8352
                              #991 is what I am looking for. So on the gate drive are these resistors and a diode. Check these very carefully and make sure they are within their tolerance. If there is anything not right in that stage, the IGBT will blow.
                              • Crystaleyes
                                • Sep 2021
                                • 493
                                • Brazil
                                Cool. I'll check all that later.
                                As for the pwm controller, should it have a detectable output, with the shorted IGBT's still in circuit?
                                I'm thinking of whether to just replace it before confirming it is fecked?
                                • CapLeaker
                                  Leaking Member
                                  • Dec 2014
                                  • 8352
                                  Nope. But you can remove the IGBT’s and check the gate drive.
                                  • Crystaleyes
                                    • Sep 2021
                                    • 493
                                    • Brazil
                                    Nope. But you can remove the IGBT's and check the gate drive.
                                    So that is what I did...
                                    Without the IGBT's connected the fan and display once again return to life..
                                    None of the resistors, nor diodes on that part of the Gate drive show any obvious deviations.
                                    Up until the two yellow wires leave the small horizontal board, the frequency and voltage measurements are very similar.
                                    Once the two yellow wires connect with main pcb however, the two channels' readings deviate away from each other.
                                    As it is Silly O'clock here now, I'll post some actual readings and photos of the components in the morning...
                                    Definitely something strange going on here
                                    • CapLeaker
                                      Leaking Member
                                      • Dec 2014
                                      • 8352
                                      You’re making some progress. These Chinesium inverter whatever thingy’s are complicated to understand first, but once you figured it out how it works it isn’t that bad. Was the same with that plasma cutter that I repaired.
                                      Follow the 2 yellow wires a bit around on the main board and see what connects to them. There has to be a feedback circuit somehow, maybe it is fuxed.
                                      When you replaced the IGBT’s you did replace them in a pair with the exact same part numbers, right?
                                      • Crystaleyes
                                        • Sep 2021
                                        • 493
                                        • Brazil
                                        Couldn't get the exact same IGBT's (this is Brazil) but did make sure the replacement were also 'Trench' type with the diode.
                                        Datasheets below. The original was the 45T60.
                                        As for the readings in the gate drive. Resistors and caps were measured in-circuit, the diodes were lifted.
                                        The photos reveal the gate drive components with the IGBT's removed. The two yellow wires in question are to the right of the transformer, in the first photo.
                                        R4 and R6 connect directly to the gates.
                                        The C25 and C26 caps are in parallel.
                                        Taking frequency measurements with a basic DMM at the diodes revealed those numbers.
                                        R4 (10R0) 10.16Ω
                                        R5 (10R0) 10.16Ω
                                        R6 (10R0) 10.16Ω
                                        R7 (10R0) 10.17Ω
                                        R18 (20R0) 20.15Ω
                                        R19 (5R10) 5.25Ω
                                        R20 (5R10) 5.25Ω
                                        R21 (20R0) 20.14Ω
                                        D7 (SS14) 0.2071v 93 KHz
                                        D8 (SS14) 0.2041v 58 KHz
                                        C52 OL (on DMM)
                                        C53 OL
                                        R31 (2000) 201Ω
                                        C25 0.0310 nF
                                        C26 0.0310 nF
                                        I'll take more readings today, however the frequencies were matching up until the R31, C25, C26 cluster.
                                        • edugimeno
                                          Repair an inverter welder
                                          by edugimeno
                                          Hi! I got this (see pics) welder which wouldn't work at all at the welding leads. I tested output voltage and got 0v
                                          Opened it and found a diode that was busted (missing resin...). Ref RHRP1560.
                                          I believe this diode protects one of the IGBT's that drive the transformer
                                          His twin diode wasn't physically damaged but measured OL on both polarities so both will be replaced
                                          Now, after watching some videos on welder repairs, it seems that the IGBT's usually fail together with the diodes, is this true? I tested IGBT with multimeter-diode mode, still on board, and got OL on...
                                          07-19-2023, 07:28 AM
                                        • spleenharvester
                                          Reverse engineering of DoCreate DHJ567 handheld spot welder
                                          by spleenharvester
                                          Hello everyone
                                          I attach a schematic and teardown photos for the DoCreate DHJ567 handheld spot welder. I bought this welder for temporary use while my supercapacitor welder was waiting for replacement parts. It cost only £24, though there is a screenless version available for £17.
                                          Performance: The absolute maximum it can handle appears to be 0.15mm of pure nickel. Reliability was not great - welds were very inconsistent, ranging from weak attachment to burning through the strip. However, I was able to build a 5S2P pack without losing any cells. It's a bit difficult getting...
                                          05-08-2025, 02:52 PM
                                        • Ross Kohler
                                          Diagnosing South Bridge (FH82H370) on Asus H370-Pro Gaming Motherboard
                                          by Ross Kohler
                                          I'm learning about motherboard repair and I believe I've traced the issue down for the South Bridge on the particular motherboard I'm working on. My path of concluding that:
                                          - There's no sign of any attempt to power on when pushing the power button.
                                          - No PSON signal is reaching the 24-pin ATX connector.
                                          - The Super IO chip is receiving the PS_SWITCH signal from the power button and is relaying this signal back to the South Bridge.
                                          - The Super IO is not receiving the S_SLPS#_R signal back from the South Bridge
                                          - If I pull the Super IO S_SLPS#_R pin...
                                          04-16-2024, 09:36 AM
                                        • x_orange90_x
                                          Vizio E55-E1 bad backlights or bad inverter?
                                          by x_orange90_x
                                          I just got this tv today and it appeared to have no backlight on. After taking off the rear cover and checking again in the dark I can see that MAYBE one quadrant is lit.. But still it's quite dim. I was going to check the LEDs with my tester, and I found LED 1 and LED 2 + pins on the wire from the inverter, but I couldn't identify a ground. Nonetheless I tried using a mounting screw on the inverter board and also the chassis as ground but regardless my tester reads 300 which is what it reads when there is no voltage draw.
                                          I don't know how exactly to test the inverter itself. Is it...
                                          01-29-2025, 09:24 PM
                                        • Dannyx
                                          Inverter welder help
                                          by Dannyx
                                          Good day folks. It's been a while since I've actually repaired anything, so today I have something I haven't worked on before: a friend of mine gave me this small inverter welder to look at. It powers on, but doesn't work.
                                          I took the cover off and immediately noticed the problem: two dead G40N60 transistors, along with some SMD resistors in what I think is the gate drive for the trannies. One IGBT is dead-short, the other reads fine, but it's missing a chunk of the casing, plus its SS14 diode is also gone, so it's safe to say we'll be replacing both.
                                          The SMD resistors...
                                          12-11-2020, 04:42 AM
