Inverter Welder Strangeness
  • Crystaleyes
    • Sep 2021
    • 493
    • Brazil
    #81
    Re: Inverter Welder Strangeness
    The black carbon is conductive and gets worse if high humidity is in the game. You have to get all that black stuff removed using a rotary tool or cut it out and fix the hole and the trace. It's a wide trace, so it needs to support a lot of current.
    I've cleared out all the carbon, which left a fair hole, so that has been filled with resin and is now setting. I'm not gonna attempt to repair the traces, but rather use flex wires to bridge the points of contact.
    I'll be back tomorrow when it is all dry and fixed.
    • CapLeaker
      Leaking Member
      • Dec 2014
      • 8352
      Make a few runs using solid core.
      • Crystaleyes
        • Sep 2021
        • 493
        • Brazil
        #83
        The AC mains wires to the pcb are 4mm stranded, so I was thinking of that, or perhaps even desoldering wick, mainly for ease of use, but are you suggesting to use two or three solid core wires instead?
        I have 2.5mm solid core here for sure. I suppose 3 of these would be more than enough.
        • CapLeaker
          Leaking Member
          • Dec 2014
          • 8352
          You could use stranded, just make sure to soak it all the way with solder. But I prefer solid core.
          • Crystaleyes
            • Sep 2021
            • 493
            • Brazil
            #85
            This was actually why I thought of desoldering wick. I have some already soldered all the way along...
            This trace only goes from the mains switch wire to both the 2200UF caps, so it shouldn't be such a problem (he says...)
            • petehall347
              • Jan 2015
              • 4449
              #86
              add a fuse if your mains plug hasn't already got one
              also check the caps aren't shorted
              • Crystaleyes
                • Sep 2021
                • 493
                • Brazil
                #87
                Gonan do that
                • Crystaleyes
                  • Sep 2021
                  • 493
                  • Brazil
                  #88
                  OMFG!
                  It Lives!
                  It's alive, I tell you!!!
                  Fuck yeah!
                  So, after four months, I think it is safe to say that the problem was poor connections between the mains input and at least one of the 2200uF caps.
                  Remember that this welder was bought (broken) in order to learn how these inverters work (at least more or less) and that mission has well and truly been achieved.
                  Just returned from the garage, where the welder laid super clean welds for the first time since I bought it.
                  Ok.. It took a carbonised pcb to finally reveal that the problem was hidden under the green varnish, but these are all invaluable lessons.
                  Performing resistance tests today from each point of the mains input/rectification section, revealed that two of the traces had breaks in them, even though before the burnout they had 'appeared' (to the eye) fine.
                  Invaluable lessons in my electronic repair journey...
                  I wanna thank all who have given their time in this thread, but especially CapLeaker, as he dissuaded me from scrapping the welder when I was itching to do just that!
                  Posting the pics of the pcb repair, for posterity...
                  ... Or was the problem solved because I changed the red (stop) on/off switch, for a green (go) one?
                  • petehall347
                    • Jan 2015
                    • 4449
                    #89
                    well done
                      • Jul 2011
                      • 6070
                      Yes very well done
                      • CapLeaker
                        Leaking Member
                        • Dec 2014
                        • 8352
                        I said in the beginning, that sometimes you have to take a break and look at this later again. Congratulations to finally fix this thing and now you have learned quite a few lessons. Given it did take quite some time, but you gained quite a bit of knowledge and got as a result a cheap working welder!
                        • Crystaleyes
                          • Sep 2021
                          • 493
                          • Brazil
                          #92
                          All true.
                          Perhaps the most valuable lesson here has been not to rely 100% on a pcb being good just because it recently came from the factory, and was essentially 'as new'.
                          After the initial pwm section repair, I had been going in circles and getting lost lookng for bad components, when the problem was hidden under the varnish on the actual board.
                          I suppose that considering I took two months off in the middle, and probably another month waiting for parts, then it's not soooo bad, but I need to speed up if I ever want to work as a repair tech.
                          Once again, big thanks for the input, as well as yours and everyones patience.
                            • Jul 2011
                            • 6070
                            You have to gain experience and what you when through is how gain the experience
                            • CapLeaker
                              Leaking Member
                              • Dec 2014
                              • 8352
                              Originally posted by Crystaleyes
                              All true.
                              No problem. Just remember the snapping noise and I told you to investigate where it comes from. Always fix what you know isn't right or looks off, before you go down different rat holes. It's always good to take a breather and go back to the basics. Look at my plasma cutter repair or a few other complicated devices that I did… it all took some time, but it got fixed at the end. Sometimes you got to trust yourself a bit better. You'll get there… maybe not fast, but in time you will. You get faster as you gain experience. More experience, more $$$.
                              • petehall347
                                • Jan 2015
                                • 4449
                                #95
                                i did wonder about that solder joint but dismissed it as i thought it had been sorted along the way
                                • Crystaleyes
                                  • Sep 2021
                                  • 493
                                  • Brazil
                                  #96
                                  Thanks for all the comments, and yes, lessons have been learnt and invaluable experience gained.
                                  Just a final word regarding this welder as I've never used one of these new-fangled contraptions before, and that is that this welder is a beast!
                                  Not sure if it's just because I've never welded using DC, however this welder is way more powerful than I had imagined. It's easy to see why they are so popular.
                                  Light, therefore portable, and capable of welding metals to an impressive thickness for its size.
                                  That said, having worked my way through it's circuitry, it is also clear that in the future there will be a steady supply of inverter welders needing repair.
                                  • petehall347
                                    • Jan 2015
                                    • 4449
                                    #97
                                    being dc it should weld stainless steel
                                    • Crystaleyes
                                      • Sep 2021
                                      • 493
                                      • Brazil
                                      #98
                                      Apparently so. In the user manual, it lists 2.5mm as the correct SS electrode.
                                      It also has an optional TIG capability
                                      • edugimeno
                                        Repair an inverter welder
                                        by edugimeno
                                        Hi! I got this (see pics) welder which wouldn't work at all at the welding leads. I tested output voltage and got 0v
                                        Opened it and found a diode that was busted (missing resin...). Ref RHRP1560.
                                        I believe this diode protects one of the IGBT's that drive the transformer
                                        His twin diode wasn't physically damaged but measured OL on both polarities so both will be replaced
                                        Now, after watching some videos on welder repairs, it seems that the IGBT's usually fail together with the diodes, is this true? I tested IGBT with multimeter-diode mode, still on board, and got OL on...
                                        07-19-2023, 07:28 AM
                                      • spleenharvester
                                        Reverse engineering of DoCreate DHJ567 handheld spot welder
                                        by spleenharvester
                                        Hello everyone
                                        I attach a schematic and teardown photos for the DoCreate DHJ567 handheld spot welder. I bought this welder for temporary use while my supercapacitor welder was waiting for replacement parts. It cost only £24, though there is a screenless version available for £17.
                                        Performance: The absolute maximum it can handle appears to be 0.15mm of pure nickel. Reliability was not great - welds were very inconsistent, ranging from weak attachment to burning through the strip. However, I was able to build a 5S2P pack without losing any cells. It's a bit difficult getting...
                                        05-08-2025, 02:52 PM
                                      • Ross Kohler
                                        Diagnosing South Bridge (FH82H370) on Asus H370-Pro Gaming Motherboard
                                        by Ross Kohler
                                        I'm learning about motherboard repair and I believe I've traced the issue down for the South Bridge on the particular motherboard I'm working on. My path of concluding that:
                                        - There's no sign of any attempt to power on when pushing the power button.
                                        - No PSON signal is reaching the 24-pin ATX connector.
                                        - The Super IO chip is receiving the PS_SWITCH signal from the power button and is relaying this signal back to the South Bridge.
                                        - The Super IO is not receiving the S_SLPS#_R signal back from the South Bridge
                                        - If I pull the Super IO S_SLPS#_R pin...
                                        04-16-2024, 09:36 AM
                                      • x_orange90_x
                                        Vizio E55-E1 bad backlights or bad inverter?
                                        by x_orange90_x
                                        I just got this tv today and it appeared to have no backlight on. After taking off the rear cover and checking again in the dark I can see that MAYBE one quadrant is lit.. But still it's quite dim. I was going to check the LEDs with my tester, and I found LED 1 and LED 2 + pins on the wire from the inverter, but I couldn't identify a ground. Nonetheless I tried using a mounting screw on the inverter board and also the chassis as ground but regardless my tester reads 300 which is what it reads when there is no voltage draw.
                                        I don't know how exactly to test the inverter itself. Is it...
                                        01-29-2025, 09:24 PM
                                      • Dannyx
                                        Inverter welder help
                                        by Dannyx
                                        Good day folks. It's been a while since I've actually repaired anything, so today I have something I haven't worked on before: a friend of mine gave me this small inverter welder to look at. It powers on, but doesn't work.
                                        I took the cover off and immediately noticed the problem: two dead G40N60 transistors, along with some SMD resistors in what I think is the gate drive for the trannies. One IGBT is dead-short, the other reads fine, but it's missing a chunk of the casing, plus its SS14 diode is also gone, so it's safe to say we'll be replacing both.
                                        The SMD resistors...
                                        12-11-2020, 04:42 AM
