Panasonic TX-L55ET60B
  • snopy44
    • Aug 2015
    • 12
    • uk
    hi can any one help could you tell me is this a T-CON board fault or a panel fault
  • budwich
    • Jul 2015
    • 3097
    Re: Panasonic TX-L55ET60B
    disconnect, one at a time, the cables going from the tcon to the panel and see if it changes what happens to the display and go from there.
      Panel fault
      • snopy44
        • Aug 2015
        • 12
        • uk
        so is there nothing can be done to repair the panel
        • budwich
          • Jul 2015
          • 3097
          do the suggested test and go from there
            Most likely it is not fixable but worth trying the test before condemning it
            • snopy44
              • Aug 2015
              • 12
              • uk
              thanks for the help this is the result of the test
                This would appear to confirm a bad panel.
                • snopy44
                  • Aug 2015
                  • 12
                  • uk
                  thank so there is no fix at all has you see ribbon faults or lose
                  • Andrew F. Ali
                    • Jan 2014
                    • 2450
                    • Trinidad & Tobago
                    Not too sure what you meant here but you have a bad panel, confirmed.
                    • snopy44
                      • Aug 2015
                      • 12
                      • uk
                      on u tube it shows packing ribbons on panel with rubber and re fitting is this just a load of rubbish
                      • budwich
                        • Jul 2015
                        • 3097
                        that method works where there is a bonded tab problem and pressing on a troubled tab can change the result. Your problem is probably worse than that. Further, the second picture that you posted is rather unusual as it shows a white half that has "wave" on the side. That looks like someone disassembled the set to fix an issue with backlighting and then during re-assembly, didn't put the diffusing material back properly. IF this is true, then based on how well (NOT) this panel was handled, it is unlikely that it can be saved.
                        • snopy44
                          • Aug 2015
                          • 12
                          • uk
                          thanks for the fast reply got the tv from a site they said it was t-con board so just wanted to make sure before I ordered a board and wasted more money
                          • kca
                            by kca
                            Hello all ~
                            08-31-2025, 06:38 AM
                          • netgearnetgear
                            TCL 43S423 TCON OR PANEL FAULTY???
                            by netgearnetgear
                            Good day, I have a TCL TV: Model 43s423. After turning ON the TV, the ROKU TV logo appears with fine lines over the whole screen, then after a while there are vertical bands in the middle of the screen top to bottom and the TV tries to update its firmware but I do not have the remote to connect it to my new network connection. Also the Power ON light blinks 2 times in quick succession. When I remove the ribbon on the right of the tcon board the left side of the screen shows but with fine lines. If I remove the left side ribbon and connect the right side ribbon the whole screen is blank with...
                            08-20-2025, 06:04 PM
                          • x_orange90_x
                            TCL 50S535 bad tcon or panel issue?
                            by x_orange90_x
                            Just bought this for 10 bucks yesterday hoping to fix it. The guy said water dropped inside from a dehumidifier hose and it started showing black and white vertical bars then went blank. When I got it home and turned it on it came on fine and displayed correctly but I was noticing faint vertical bars in the image. After a little bit I turned it off and back on and it was a black screen again. I opened it up to check for water damage and corrosion but didn't find anything of the sort. I cleaned the ribbons anyway and reconnected them but still got a blank screen. If I disconnect the right side...
                            03-29-2025, 11:02 PM
                          • advant
                            by advant
                            02-03-2020, 12:25 AM
                          • iglitare
                            Sony KD-75XF9005 grey Picture but Sound. TCON or panel?
                            by iglitare
                            i want to repair a Sony KD-75XF9005 TV that initially only showed a grey picture.
                            Backlight seems to work, Sound (Setup menu after reset) works.
                            If i dissconnect the left FFC cable from TCON to panel i have half a screen on the right. If left cable is connected always only the grey screen.
                            Interchanged the cables, its always only the right side that is working. Always grey if left side is connected.
                            With my small knowledge i would think at least the cables are good.
                            Can this happen because of a bad tcon board?
                            Or is it always a bad/shorted...
                            09-04-2025, 07:13 AM
