Sony Bravia KDL-60R550A- distorted picture
  • dsswhiz
    • Sep 2018
    • 6
    So the story with this set is I got it free as water damaged. When I first got it I had no picture or sound only had backlight. After some troubleshooting and voltage checks, I narrowed it down to a short in the left side of the panel.
    i'll list the steps i've done so far.
    1) Checked audio with a headphone on audio out jack and got audio.
    2) Check the temp of Tcon chip, was ice cold.
    3) Disconnected the left side of the panel at the TCON and got the right side to display an image- however the image was slow and distorted.
    4)Dissembled the panel and checked the left connector, found a short in one of the ribbon cables. Cleaned and reassembled got the full panel to have a image.
    5)Checked audio setting and after changing to Tv speaker got audio going.
    So where i'm at is the panel displays image, audio works but image is distored and the image is refreshing extremely show, like extreme slow motion. Seft test returned a two TCON errors but i'm not sure if those errors are from when i had the left panel disconnected or if this is a failed TCON or Mainboard processor. Has anyone seen these symptoms before and what cause it?
    https://ibb.co/dDxTLU
    https://ibb.co/b5sHEp
    https://ibb.co/n7uVZp
    https://ibb.co/jgtPup
  • tvtimmy
    • Mar 2015
    • 1160
    • usa
    Re: Sony Bravia KDL-60R550A- distorted picture
    I had a 50" version of this tv and it was the panel. Got another that wouldnt start so I replaced the main, power, and tcon and all was good.
    • dsswhiz
      • Sep 2018
      • 6
      I'm hoping it not a failed panel, it seems weird that all four segments would fail. Disconnecting each section yielded the same results. I'll see if anyone has any more idea before dumping it.
      • budwich
        • Jul 2015
        • 3097
        your problem is likely a panel issue given the water ingression.
        the pictures that you posted are too "busy" to see whats up. If you can input a color bar test signal and you will likely see a highlight on the display of some horizontal lines that shouldn't be there... potentially like your last picture... maybe which shows a "fading line" just about the "checks". Further, another picture appears to show vertical lines down in the corner... but again the display has too much to determine if it is a "hard display issue" or something else (ie. display not updating... a symptom of the panel problem).
        The set may be saveable depending on what the actual problem is... that is IF it is only the side.
        PS. lots of threads with similar type issues of many sets as the panel usually is the same manufacturer / technique.
        • dsswhiz
          • Sep 2018
          • 6
          So update with a colour bar screen test, cant really see any lines but not sure what am looking for. The colour bleed is from the slow image. Still cant get any change by pressing the bond tabs. I know it seems like a panel failure but what has me scratching my head is how is it affecting the whole screen and not just the damaged section. Am i wrong to think each half of the screen is Isolated when the ribbon cable is disconnected at the TCON? Has anyone tried fixing one of these panels? I have access to a digital microscope. If replacing the tab could fix it i might have a go at it.
          https://ibb.co/ddz9Up
          • budwich
            • Jul 2015
            • 3097
            ok... if I see the "still picture" correctly... you can see that there is a mid section where there is a shift in the "timing" such that it appears to "time delayed". That portion has a tab this is impacted such the applied signal shows up just a bit late causing the shift. In your case it is a significant section, not just a line, as a result it is having major impact on the rest of the display timing.
            As indicated, there are numerous threads about this type of failure. It is likely that this sony uses a sharp panel which have a common failure with or without watering... :-)
            Anyways, post a good picture of the lower corner of the panel which shows how the panel is connected to the lower / bottom edge boards (note that depending on the build, it might actually be on the top instead). Similarly, post a picture of the side of the panel which hopefully shows the bonded tabs and if there are any edge boards along the side (may or may not be)... go from there. Your problem is on the left side of the screen and possibly the lower corner(s).
            One other question: is there multiple edge boards along the bottom .... that is more than 2 (ie. one per "side")... if there are more than one per side, they are interconnected by a "u" like flat ribbon that is unclampable. IF so, you can unclamp said ribbon and see if that changes the results... this test isolates the side that is no longer connected for signals and may tell you more about your problem area.
            PS... in terms of what to look for, feed that same "static test pattern" into a normal set / display and you quickly see where there is issues.
            • dsswhiz
              • Sep 2018
              • 6
              Thanks budwich, your input is greatly appreciated. I follow up with more pictures. If this is going to be a scrap i might try to see if i can rework these connectors. The panel is a "Sharp JE600D3LC5N" Only bonding tabs i see are at the bottom which connects to the driver boards 8 in total. The tabs on the side arent connected to a board they just hang there. I'lll post up pictures.
              • JDC
                • May 2015
                • 273
                Sony KDLs in my opinion are mostly panel issues. As soon as a customer says KDL I cringe.
                • budwich
                  • Jul 2015
                  • 3097
                  with the water ingression, you may be fighting a losing battle. Because there are no side edge boards, there is no easy way to isolate the side tabs to see if things improve. further, water doesn't necessarily have to cause an issue with the tabs as it can ingress anywhere along the edge of the panel which is layered and leave "deposits" when dried.
                  one thing you can try is "fire up" the set and then use your "touch" to see if you can detect any of the side tabs being hotter than others as that is one sign that things around that tab are not happy. Of course, be careful playing with tabs as the bonding isn't the strongest, hence issues on many panel fronts.
                  • jjanssen7
                    • Nov 2012
                    • 252
                    Tconn error count of 2 also indicates a possible panel problem. I'd look very closely at the bottom ribbons and driver board on the panel for corrosion give the water damage history.
                    • Davi.p
                      Hobbist Tech
                      • Sep 2009
                      • 4359
                      • Italy - Milan
                      i had a similar issue on a big Sony, are you happy to experiment? There are some long passes to do. if you are unfamiliar with electronics repair then.. leave it to more expert users, please.. if not i can tell you the steps, but keep in mind them are experiments, no warranty of success..!
                      • dsswhiz
                        • Sep 2018
                        • 6
                        My next step is to check if i have the correct voltages at each bond tab on the board. I'm good with electronics repair. my next step is to try tese steps https://www.youtube.com/watch?v=9UrTVEC5LkA&t=119s
                        But Davi if you have something in mind let me know, but a big deal if it gets screwed. The panel is already almost dead.
                        • Davi.p
                          Hobbist Tech
                          • Sep 2009
                          • 4359
                          • Italy - Milan
                          First thing to do is to test the screen by connecting the tcon>panel flat cable one at a time to see if you have a combination where you see half image of good quality, the the other one is the faulty side as probably you have some gate drivers that are not working and make the work harder for the drivers of the good side. Then save the content of the tcon's eeprom, this for safety reasons.. next step is to locate the VCC of the cofs, i need an hires shiny picture of the tcon, silkscreens well visible, i can help you identify it. It is most likely a 3,3v or 1,8v that goes to the panel. Then when you found it, trace it to the panel where it enters the last COF of the fault side, it enters in many points, you have tu cut the lines where VCC enters the tab but passes through without entering the chip (COF) ie on the side traces of the tab that flows directly to the glass and then to the vertical COFS. Now switch on the tv with all the flat cables attached, probably the tv can self shut off for protection, now switch it fully off. Then join the cut traces, retest the tv and let me know what it does..
                          • CyberPhoenix
                            Issue with picture quality of Sony bravia TV
                            by CyberPhoenix
                            Hello, Last week I bought the 50" Sony X80j tv everything was working fine, untill I plugged the tv in a ups power supply 650va the tv remote control became unresponsive and the TV became laggy after a while the picture quality isn't the same as before the tv seems less brighter and the picture is somehow blurry, people's faces don't look as natural as before, there is a mini orange-pink tint to the edge of people's faces especially in NETFLIX Dolby Vision like in One Piece ep1 Alvida skin tone, my intention was to protect the tv but something went wrong I checked the ups with a multimeter,...
                            01-22-2024, 02:08 AM
                          • Spc.
                            Sony Bravia KD43XF7596BAEP - Android no picture
                            by Spc.
                            Greetings everyone.
                            I also have Sony Bravia, model:
                            Sony Bravia KD43XF7596BAEP - Android.
                            What happend is that image dissapeared while we were watching tv.
                            Diagnostics:
                            1. TV turns on, no errors
                            2. Backlight turs on, no errors
                            3. Power indicator turns on, white color, no errors
                            4. Menu works on android, you can hear sound while switching channels
                            5. Volume up and down works via TV remote and via buttons
                            6. Tunner works, HEVC / MPEG-4 decoder works
                            7. I get audio from channels
                            8. No picture is present,...
                            05-19-2022, 04:28 AM
                          • KYBOSH
                            Trying to Save - SONY BRAVIA KD-75X780F - No Picture BUT there’s sound
                            by KYBOSH
                            Previous owner said TV just went blank one day.
                            They attempted to open the back panel and yanked the power connector off the power supply in the meantime.
                            Easily fixed that and got the TV to turn on. Backlights come one with everything connected. Good Sign.
                            The mainboard shows signs of life (red light on digital audio out is on) but that's about it. Good Sign.
                            There is not blinking LED and the most importantly there is LED response and sound when I press the MENU button on remote control. GREAT Sign.
                            I just downloaded the Sony KD-75X7800F Service Manual and...
                            11-19-2024, 10:12 AM
                          • lmcancu
                            Sony Bravia 65x900F BL On but not picture
                            by lmcancu
                            I was watching youtube yesterday, when I paused it to go to the washroom. When I came back, the right side of the screen was showing half of the youtube channel and the left was black. I powered off/on the unit with the remote and now I have no picture whatsoever except for the bluish backlight. I did the factory reset (power + vol down), and now I when I power on I get the startup music, backlight but no picture.
                            I took the back cover off, and reseated all cables but unfortunately same issue. I took some voltage measurements on the main 2 headers from the power supply board and...
                            10-30-2023, 07:01 PM
                          • Ven
                            SONY KDL-48WD653 - Distorted Picture, Can you help by photos?
                            by Ven
                            Can you help me please what can be wrong with this distorted picture?
                            Thank you....
                            09-17-2023, 06:13 AM
