LG 55EC930V OLED - 3 Second Power No Display
  • Billsy
    • Oct 2018
    • 53
    • United Kingdom
    Good evening all
    I could do with some help if you don't mind. I've pickup up a LG 55EC930V OLED curved set that clicks on with no display or sound then off after 3 seconds. The LG bezel logo is on for the 3 seconds then fades out. The previous owner said the screen went white then powered off and he assured me there was no screen damage. I have tried a replacement main board and there's no change. So, before I buy a TCON board,
    Is there a way to check that the main board isn't in some kind of lock-out mode?
    Am I right in thinking DRV-ON is the signal back from the main board and should be 3.5v?
    Can I manually apply 3.5v to DRV-ON? What should I expect?
    During the 3 seconds of activity the PS is outputting the following:
    3.5v = 3.54v
    12v = 11.8v
    24v = 25v
    PWR-ON = 3.4v
    DPC = 0
    DRV-ON = 0.08v
    Thanks for your help
    Billsy
  • dick_barton
    • Aug 2015
    • 6643
    • Wales
    Re: LG 55EC930V OLED - 3 Second Power No Display
    If you disconnect the mainboard does the backlight come on. If not then with the mainboard still disconnected use a 1K resistor and connect between 3.5V and power on and a second 1K resistor between 3.5V and DRV_ON.
    • Diah
      • Feb 2013
      • 6614
      Dear friend dick_barton , this is OLED Set.
      disconnect the LCD driver complete from MB ( LVDS) and the Power socket on the left side and turn on.. check it will remain ON ?
      • budwich
        • Jul 2015
        • 3097
        read thru this thread, is probably your best bet.
        https://www.badcaps.net/forum/showth...led+freakaftr8
        Further, because of the design of OLED sets and the great potential for the set to "fire", the design is to shut down if there is any issue with the panel, unlike LCD sets which can be powered up in various forms. Hopefully, you will find an answer.
        • Diah
          • Feb 2013
          • 6614
          there are no special things to trouble shoot OLED TV if you able to repair Smart Mobile
          • dick_barton
            • Aug 2015
            • 6643
            • Wales
            Hi Diah, I should have taken notice that it was an OLED so no backlights.
            • Billsy
              • Oct 2018
              • 53
              • United Kingdom
              With the two resisters in place and main board disconnected, the power board stays on with all outputs steady including the 24v to the TCON. Screen remains black.
              With the main board connected, tcon receives 0v
              With the four panel ribbons disconnected from the tcon, still 0v to tcon
              I tried this prior to jumping the pins and it had no effect. off after 3 seconds.
              Thats a big discussion. His fix was replacing the tcon. I might try that but would be nice if I could eliminate a duff panel.
              Thanks guys
              Please keep the ideas flowing.
              • nomoresonys
                • 12332
                • U.S.
                Do you have voltage on each side of the tcon fuse?
                • budwich
                  • Jul 2015
                  • 3097
                  IF you follow thru the discussion (and if I follow it), the "bad tcon" was a problem on the NOS panel. Freak then used his "original one" to get the NOS to work... But I don't think he got the original set / panel to work.... at least at the mid point of the thread. He did have to "reset" the main board via the service menu to get it out of lock out" which is something that you should try.
                  • Diah
                    • Feb 2013
                    • 6614
                    Thanks guys
                    LG Panel in General the SOS signal return feed go back via the last ribbon cable between driver ( you call it T-CON ) and panel. at yours case as first photo the last one on the right side. disconnected it via trouble shooting always to avoid SOS Sig.
                    • Billsy
                      • Oct 2018
                      • 53
                      • United Kingdom
                      So I just tried to get into the service menu using the AnyMote app on an old IR enabled Galaxy tab. In AnyMote I selected "LG Most Models" and the resulting remote actually has buttons for EZ-ADJUST, INSTART & INSTOP. None of them worked tho, screen stays black, and no voltage to the tcon. The TV is however responding to PWR ON, CH+, CH- and number keys, by way of the bezel logo illuminating then fading out.
                      • Diah
                        • Feb 2013
                        • 6614
                        your tv turn off after the 3 second in protect mode. LG service menu work only when the TV work and you have picture on the screen
                        • Diah
                          • Feb 2013
                          • 6614
                          how about you take out the metal plate on the panel driver ( T-CON ) and post here photo
                          • Billsy
                            • Oct 2018
                            • 53
                            • United Kingdom
                            Rest of pics are rotated by the forum for some reason.
                            Thanks guys
                            • Billsy
                              • Oct 2018
                              • 53
                              • United Kingdom
                                Could you take a picture of the bottom side of the board? Curious about something.
                                • Diah
                                  • Feb 2013
                                  • 6614
                                  EVSS_CON_ out driver IC burned
                                  • Billsy
                                    • Oct 2018
                                    • 53
                                    • United Kingdom
                                    Here's the back side
                                    • Diah
                                      • Feb 2013
                                      • 6614
                                      if i am i will change this board.
                                      • Billsy
                                        • Oct 2018
                                        • 53
                                        • United Kingdom
                                        Evss_con_ out
                                        From different angle
                                        • learnmore
                                          Lg oled 55ec930v automatically turns off after 1-2 seconds
                                          by learnmore
                                          Hi Community,
                                          I've got the above model that activates the relay (clicks) and powers on the LG logo power light on when turned on. It then almost immediately turns off. I not noticed any image on the screen or heard any sound during this brief period.
                                          Checks show:
                                          3.5v on SMPS on (in off state, no other voltages present incl pwr on)
                                          On pressing power button > the 3.5 pwn on voltage, 12v and 24v lines appear on the SMPS connnector between the main the SMPS but then all drop the zero in 1-2 seconds
                                          Disconnecting 24 to TCON connector and powering on shows...
                                          05-08-2024, 02:42 PM
                                          ASUS VivoBook Vivobook Pro 15 OLED D3500QC-L1351W Notebook Pro 15 OLED Specification for Upgrade or Repair
                                          This specification for the ASUS VivoBook Vivobook Pro 15 OLED D3500QC-L1351W Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Vivobook Pro 15 OLED D3500QC-L1351W boardview and Vivobook Pro 15 OLED D3500QC-L1351W schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that...
                                          09-07-2024, 04:30 AM
                                          Gigabyte AERO 14 OLED BMF-72ESBB4SH Notebook Specification for Upgrade or Repair
                                          This specification for the Gigabyte AERO 14 OLED BMF-72ESBB4SH Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 14 OLED BMF-72ESBB4SH boardview and 14 OLED BMF-72ESBB4SH schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                                          09-07-2024, 07:12 AM
                                          Gigabyte AERO 16 OLED BSF-A3LA964SP Notebook Specification for Upgrade or Repair
                                          This specification for the Gigabyte AERO 16 OLED BSF-A3LA964SP Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 16 OLED BSF-A3LA964SP boardview and 16 OLED BSF-A3LA964SP schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                                          Gigabyte AERO 14 OLED 9MF-E2USBB4SH Notebook Specification for Upgrade or Repair
                                          This specification for the Gigabyte AERO 14 OLED 9MF-E2USBB4SH Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 14 OLED 9MF-E2USBB4SH boardview and 14 OLED 9MF-E2USBB4SH schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                                          09-07-2024, 06:40 AM
