Westinghouse WD40FW2490 not powering up
  • Mr_Slim
    • Jun 2018
    • 23
    Hi All,
    this is a Curbside special, so I'd really like to troubleshoot the issue before breaking down and replacing the main board.
    It has an ST6308RTU-AP1 main board, like Seiki, and others, with I assume specific firmware for this particular model of Westinghouse TV. This is an all in one board with both power supply and logic on it.
    Here's what I've done so far:
    Tried some of the Reset sequences found on other sites, with no success.
    Checked for the 5 volt standby voltage as per Bud's troubleshooting doc, not found on the connector pins, so I think this is the best place to start.
    Has anyone found a schematic for this board?
    Any other suggestions appreciated.
    Re: Westinghouse WD40FW2490 not powering up
    If you upload good clear pictures of the boards and how they are all connected together that will be a good start.
    • Mr_Slim
      • Jun 2018
      • 23
      Thanks, here's a big picture view of the connections, and a couple of closer ones, flash and no flash.
      • Andrew F. Ali
        • Jan 2014
        • 2450
        • Trinidad & Tobago
        This is one of those Chinese universal boards. So you will not find any service information per say. These boards are used in other TVs and can different software are used for different Panels. Since you have no Standby voltage that would be the place to start. Are you getting 125Vac in? What voltage are you getting across the big filter cap and are the fuses OK?
        • Mr_Slim
          • Jun 2018
          • 23
          I'm getting 120Vac in, yes. And the fuses appear to be ok. The voltage across the big filter cap is 165V DC..
          I found two connectors at 4:00 from the yellow transformer, that have 5VS,12VS and ground on them. 5VS is zero, and the 12VS measures around 3V..
          • Andrew F. Ali
            • Jan 2014
            • 2450
            • Trinidad & Tobago
            Test the HOT/Primary side components for any faults. I believe this is an always ON type PSU. We would need to see pics of the board's underside, also.
              https://www.badcaps.net/forum/attach...4&d=1528206069
              Waht DCV do you have at the Cathode of D2014, and at D2012's big metal tab with ref. to the chassis GND?
              • Mr_Slim
                • Jun 2018
                • 23
                OK.. The Cathode of D2014 is 0V DC with ref to Chassis Ground.
                The tab on D2012 starts at ~3.15 V DC and then starts going down, like a capacitor is being drained..
                  OK, check the RESISTANCE of those diodes in both directions, report the resistance readings.
                  • Mr_Slim
                    • Jun 2018
                    • 23
                    D2014 and D2011 (beside it) appear to be shorted (0 ohms in both directions).
                    D2012 is shorted between the two small pins on top, and connection from each pin to the big tab appears to charge and discharge via the circuit around it depending on the polarity of the meter leads.
                      D2014 and D2011; Remove them and tested them off the board.
                      D2012 two small pins are joined together so the reading is correct, it looks OK.
                      • Mr_Slim
                        • Jun 2018
                        • 23
                        Both 2014 and 2011 measure about 900K in a positive direction (+ on the Anode and - on the Cathode) and open in the opposite direction. They are MUR460 diodes.
                          Measure the empty pads where those two diode are to see if it still show as shorts as reported when measured with the diodes in place. The shorts may be on the board itself since the diodes did not show as shorted off the board.
                          • Mr_Slim
                            • Jun 2018
                            • 23
                            Yep, the pads show a short.
                              So the resistance between the Anode pad and the Cathode pad shows as shorted, remove that small blue disk cap sitting between those two diodes to see if the short will go away or not, that snubber cap is connected in parallel with those two diodes.
                              • Mr_Slim
                                • Jun 2018
                                • 23
                                After pulling the snubber cap, the resistance across the diode pads is about 1.7 ohms.
                                The cap itself seems to charge/discharge on the Megohm setting on the meter, and does not show as a short on any setting. There are 3 x 150 ohm resistors in parallel underneath the diodes that measure ~50 ohms, so that seems right also.
                                  I have a feeling there is shorts circuit on the Cathode side of the Diode, you can verify that by checking the resistance between GND and the Cathode pad.
                                  • Mr_Slim
                                    • Jun 2018
                                    • 23
                                    So, cathode to ground on both diodes shows about 1.5 ohms, while Anode to ground is .1 ohm, which is the same as the resistance of the meter leads, so effectively a short..
                                    • R_J
                                      • Jun 2012
                                      • 9548
                                      If the diodes are out, what you are measuring on the anode side is the transformer winding which will be .1 -1 Ω. you have something shorted on the cathode side somewhere. Check the transistor Q2054
                                      • Mr_Slim
                                        • Jun 2018
                                        • 23
                                        OK, so the right pin (source) to the tab is .8 ohms. and the left pin (gate) to the tab is 384 ohms. (both directions). I presume the Drain (middle pin) is tied to the Tab?
                                        • Tynan Dill
                                          by Tynan Dill
                                          Assuming...
                                          11-22-2024, 01:46 PM
                                        • m1ch43lzm
                                          by m1ch43lzm
                                          05-12-2025, 08:37 PM
                                        • howardc64
                                          by howardc64
                                          07-24-2025, 05:17 PM
                                        • ShadowAi12
                                          ASUS ROG STRIX B550-F GAMING — Board not powering on properly
                                          by ShadowAi12
                                          I recently bought an ASUS ROG STRIX B550-F GAMING motherboard that was listed as "dead, not powering on." However, it does show some signs of life. I've performed several basic measurements and would like to share the results.
                                          • The board enters a "ready to power on" state after plugging in the PSU.
                                          • Pressing the power button increases power draw.
                                          • Sometimes, touching the RSMRST_L pad with a multimeter probe causes the board to shut off and return to standby.
                                          Measurements:
                                          (taken after pressing the power button, while the board is attempting to start)
                                          • H_SKTOOC#
                                          06-11-2025, 01:05 PM
                                          Tankless hot water heater controller board not powering up when power is applied
                                          by sam_sam_sam
                                          I recently bought a used tankless hot water heater and the controller board is completely dead no power up when power is applied the display board works however the main controller board does not work correctly at all the fuse is good
                                          I bought a used replacement controller board that also had issues that I was able to fix and now the tankless water heater works correctly now
                                          However I would like to know if I could figure what happened to this controller board if possible
                                          Tomorrow I will take some better pictures of both side of both boards
                                          The...
                                          12-09-2022, 09:14 PM
